Question about NEC DTU 8D-2 Corded Phone
When a call comes in the ringer doesn"t ring
On an incoming call the ringer wont ring. the volume is up and the DND is canceled. please help
  • amandarheabr Dec 14, 2008
    my business phone is doing the same thing.....the light blinks but you can't hear it ring.......
  • 149 Answers
You need to have the phone programmed to ring. ldtsnj.com can help
Posted on Jan 02, 2009
Can't turn the ringer on to notify when a call is coming in.
Without the model, I can't be sure of the method you need to enable the ringer.
Some Uniden phones toggle on a Silent Mode if you press and hold the # key (below 9 on the keypad) for 3+ seconds on one handset. When turned on, the phone will ask how long (1-9 hours) you want the ringer to be disabled for the handset. If no key is pressed within 5 seconds, the handset will not ring until the # key is pressed and held again.
Other Uniden phones have a Do Not Disturb mode. This disables the ringer on all handsets.To disable this, press and hold the DND button on the base. The answering system will be turned on if it isn't already on when DND is in use.
The other options to mute the ringer include the volume down on the handset when the phone is in standby. Some phones will also adjust the ring tone volume in the menu.
I hope this helps. Please add a comment with the model of your phone for additional information.
Apr 29, 2016 | Uniden Cordless Phone
How to I turn the universal volume on a Norton Networks T7316E Phone?
Have you tried to call the phone and adjust the volume on the set while the call is coming in? I think the only way you can adjust the ringer volume is if the phone is ringing.
Jun 25, 2015 | Nortel Networks T7316E Telephone Platinum...
Phone does not ring on incoming calls. The manual suggests "make sure ringer is on." Where is the ringer?
Ringer On/Off and Ringer Volume 1. Make sure your phone is in idle mode. (not in Talk mode) 2. Press the VOL (- or +) button to activate the ringer volume setting. 3. Press either the LINE 1 or LINE 2 Soft key to select the desired line. 4. The LCD will display the volume range and currently-selected volume in an ascending series of bars. 5. Press the VOL (- or +) button up or down to increase or decrease the volume in steps. 6.The system will retain the last entry, it is not necessary to save or acknowledge your selection from this mode.
It is also possible you have set the DND (Do Not Disturb) feature which will also caution your phone not to ring when a call comes in.
Have a great day. Hope this helps.
Jul 05, 2011 | RCA ViSYS 2-Line Speakerphone
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
My uniden powermax 5.8 ghz set itself to Do Not Disturb.
The do not disturb feature (DND) allows you to mute the ringer, the base, and any registered handsets at the same time. The phone must be in standby mode. Press and hold do not disturb on the base. You will hear a confirmation tone, and the DND LED illuminates. To cancel the DND feature, press do not disturb again. You can also mute the ringer tone while the phone is ringing by pressing do not disturb on the base.
Activating the DND while the answering system is off will turn the answering system on automatically. The answering system setting will reset to the original setting when you cancel the DND.
If you press answer on/off when the DND and the answering system is on, both of the DND and the answering system will turn off.
To mute the ringer tone temporarily for each handset or the base, when the phone is ringing, press the MUTE soft key on the handset or the base. The ringer tone will return to the previous setting starting with the next incoming call.
May 28, 2009 | Uniden 5.8GHz Dual Cordless Phone
My Ringer is Silenced Please help me...
Goto the base station and press the Don Not Disturb button (DND) This should solve it.
May 07, 2009 | General Electric 28223EE2 Twin Cordless...
Phones do not ring
Check the DND button- it's the far right button on the top row. If DND is not on, your ringer volume is probably turned down.
The volume is set independently per line. To set the volume:
1. Press Conf, then using the dialpad, press either 1, 2, 3 or 4 to indicate which line you want to adjust.
2. Press one of the VOLUME buttons to increase or decrease the ringer volume.
Apr 01, 2009 | AT&T 954 Corded Phone
Phone wont ring on incomming calls?
Could be two things, first is DND or do not disturb. Make sure that its turned off by either pressing the DND button or feature #85.The second is that the ringing wasn't turned on in programming.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should sat line 001: appear only press CHNG til it says appear &ring.
press next key (lower right arrow)
The display should say line 002: appear only
Repeat same procedure as line 001 til all available lines are done
press the release key when finished
Mar 26, 2009 | NorStar M7310 Corded Phone
NEC DTU 8D-2 Corded Phone Logo
2,112 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
