Question about HP DeskJet 1280 InkJet Printer
HP Deskjet 1280
Paper got jammed. I removed papaer carefully. Now when you press power button, green light comes on and goes off. Tried switching off power at mains and switching on again. have noted 4 others on this site have the same problem. This happens even if printer not connected to PC
  • 1 more comment
  • Anonymous Aug 02, 2008
    Yes have same problem but what box is the guest talking about?
  • Anonymous Aug 04, 2008
    I tried as metioned but doesnt work
  • Anonymous Aug 13, 2008
    Same problem
I have found you need to be very accurate with the placement of the of the paper guide box and ensure it is completely locked in to ensure the printer will turn on.
This is the manual feed box at rear of the printer.
Cheers
Yoga2
Posted on Aug 27, 2008
I am getting nowhere with this problem , i have taken the box out of the back , i can see when i turn the dial to lock the 2 lugs come out on each side ... but put it all back in place ( a bit difficult to turn to lock) and ..NOTHING .
if i disconnect the power cord then put back in , press power button ..just the green light for a split second then DEAD ....anybody can you help me
bar@brasero.co.uk
Posted on Sep 05, 2008
    Problem Solver:
  • 16 Answers
Excellent advice! it worked! What I did was take the box out and free the lock as becomes "set"
Thanks to Fixya the printer which had sat at another I.T staff members desk and apparently "stuffed" is now all go, after new ink carts and alignment.
Ensure you place the box behind the printer properly. There are sensors detecting the presence of that box. If it is not locked properly, the printer will not turn on.
Posted on Jul 11, 2008
Hp deskjet 948c. What Do The Button's Do
buttons and lights The HP Deskjet printer buttons let you turn the printer on and off, cancel a print job, or resume printing. The lights give you visual cues about the state of the printer
sayurisan20_33.jpgcancel button
print cartridge status symbol and light **The light above the Print Cartridge Status symbol flashes when a print cartridge is low on ink or incorrectly installed.
sayurisan20_35.jpg resume button and light
**The light above the Resume button flashes when an action is required such as loading paper or clearing a paper jam. When the problem is fixed, press the Resume button to continue printing.
sayurisan20_36.jpg power button and light **
The Power button turns the printer on and off. It takes approximately five seconds for the printer to turn on after you press the Power button. The green light above the Power button flashes when printing is in progress. Caution! Always use the Power button on the front of the printer to turn the printer on and off. Using a power strip, surge protector, or a wallmounted switch to turn the printer on and off may cause premature printer failure
Jun 17, 2011 | HP Office Equipment & Supplies
Paper jam hp deskjet 1280
Hi syarief03120,
Actually you can manually remove the paper from the printer. It can be pulled out from the feed area.
And to clear the paper jam message: You have to take the back cover off, there is a reset switch in the top left hand lock hole. Use an object to push in the pin hole. After that put back the cover on. This should help you fix the problem.
Hope it helps.
Thank you for using Fixya.
Apr 15, 2011 | HP DeskJet 1280 InkJet Printer
Carriage jam problem/1280 printer
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t6088190-hp_7400_displays
Sep 06, 2010 | HP DeskJet 1280 InkJet Printer
HP deskjet 1280 paper jam
Yes you can manually remove the paper. It can be pulled out from the feed area (pulled out backwards).
To clear the jam status....
Take the back cover off, there is a reset switch in the top left hand lock hole. Push a pen (or similar) into this hole, the switch will give slightly and be the same depth as the others.
put the cover back on, all should be well
Sep 11, 2009 | HP DeskJet 1280 InkJet Printer
Seems to have frozen after removing a paper jam
Please explain: when you push the ON/OFF button:
1) the green light will go on and remain on or
2) it will blink and go off after a short time ?
In case 2), remove the rear door and put it again in place correctly (make sure it is well seated in place).
If the door is not installed correctly, the printer will refuse to switch on.
Oct 17, 2008 | HP DeskJet 1280 InkJet Printer
HP DESKJET 1280
I had this problem too and found that the rear cover (the one that you remove to clear a paper jam) was not correctly fitted and locked. After resetting the vover and fully locking it worked! Try it.
Aug 23, 2008 | HP DeskJet 1280 InkJet Printer
My hp deskjet 1280 printer is not coming on
well..sometimes when a paper jam occurs, it shuts the whole system down..
you may wish to remove the s/w for that printer through control panel
go here for updates drivers
re install the s/w
run test page, calibrate and clean cycles.
Mar 27, 2008 | HP DeskJet 1280 InkJet Printer
Power problem
I'ts because there are a paper jam
I have the same problem and I solved it myself
-.... look into the lock behind the printer remove it then put it back again >>>>>>>>
Dec 17, 2007 | HP DeskJet 1280 InkJet Printer
Deskjet f340
You have a paper jam. get a torch and thoroughly check doen behind unit where paper goes after removing all paper. Oopen cover, let carriage move, once settled, check everywhere her too, all around, rollers, near carriage, teeth, sides, etc, and remember it can be the tiniest slip easily missed. Good luck.
Mar 06, 2007 | HP Deskjet F340 All-In-One Printer
Paper jam
Carefully pull it out. Try not to rip the paper, because you may get some stuck inside. It may be necessary to open the printer up and even remove part of the cover to get it all out.
Feb 13, 2007 | HP DeskJet 1280 InkJet Printer
HP DeskJet 1280 InkJet Printer Logo
319 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
