Question about Microwave Ovens
Plastic ring is broken inside coffee pot - replacement lid or complete pot is needed for 12 cup barrista unit. Thanks.
  • 3,083 Answers
I read in a web blog that Starbucks will send you the needed parts (for free) for the coffee pot if you contact them and let them know what your problem is. Here's their site:
http://www.starbucks.com/customer-service
Good luck, and hope this helps.
Posted on Nov 09, 2010
I lost the user manual to my 30 + cup coffee percolator and I need to know the amount of grounds to use when brewing coffee!
Use approx. 1/2 cup of coffee to 10 cups of coffee....so for a full pot use 1-1/2 cups... then adjust to taste..
heatman101
Sep 09, 2011 | Microwave Ovens
We have a 12 cup Mr. Coffee about a year old. We put 4 scoops of coffee in and the appropriate amount of water. Every day, the filter overflows and grains of coffee get into the pot. How do we keep this...
Because I own a espresso company,I believe I can help you. There is several things that can cause a coffee machine to over flow. 1, putting to much coffee in, where water can not drain through filter. 2. The grind of the coffee, if it is ground to fine, like ground for espresso, will not allow coffee to flow through filter , drip machine that are not under high pressure like espresso machines have to have ground more course. 3, wrong type of filters, not fine enough for water to flow, or made for high pump pressure machine such as espresso machine . 4, putting to much water in, is not an issue on a mr coffee, because even if you fill it to full cup line, it would have nothing to do with filter over flowing, besides the coffee grounds always absorb some of the water anyway. In conclusion, my positive professional diagnose is Grounds of coffee to course, and 4 scoops seem a bit to much for a filter of a mr coffee machine that holds only 12 cups. To test this is make a pot same way and use only two rounded scoops and see what happens, if does not over flow that solves that. But your saying I want it stronger, believe me I know. I too like my coffee strong and a flavorful . I have that solved too. Go to a good walk in espresso shop, like a star bucks, tell them you want some good strong blend and have it ( Ground for Drip) and then still only put two rounded scoops, it takes less do to the blend and kind of coffee. Please let me know if my advice worked, thanks mike. oh notice my screen name of mc1 bean, now you know, I know what I am talking about :)
Jun 07, 2011 | Microwave Ovens
I need a new lid for my Russell Hobbs 9702 Coffee Grinder but the item is no longer available and I can't find spares. The little plastic tab on the lid has broken off, this tab makes the grinder work...
fold a piece of paper or thin card board and put it in the hole the tab went in and you can have your coffee until you can find a replacement on ebay or amazon.
May 20, 2011 | Russell Hobbs Microwave Ovens
This morning when my wife went to make coffee. The clean light came on. we couldn't get it to shut off. She went through the clean cycle.The light came back on again. What should we do ?? Mr. Coffee...
I know this sounds like a pain but it takes a while to get that silly light to stop.
If you have problems call the 1-800 number below.
Decalcifying your MR. COFFEE® Coffeemaker Minerals (calcium/limestone) found
in water will leave deposits in your coffeemaker and affect its performance. It's
recommended that you regularly remove these deposits using MR. COFFEE® Cleaner
or vinegar. MR. COFFEE® Cleaner is available at many retail stores or by calling the MR.
COFFEE® Consumer Service Department at 1-800-MR COFFEE (1-800-672-6333).
1. Follow package instructions to prepare one batch of MR. COFFEE® Cleaner. Pour the
mixture into the water reservoir. Before decalcifying, remove the water filtration disk
from the machine.
NOTE: 4 cups or 20 fl. oz. of undiluted, white household vinegar may be used as a
substitute for the cleaner.
2. Place an empty MR. COFFEE® 10-12 cup basket-style paper filter
or MR. COFFEE® permanent filter into the filter basket and slide
the brew basket in place.
3. Place the empty decanter back in the unit.
4. Press the CLEAN button until the CLEAN indicator light turns on
(Figure 9). For your convenience the cleaning cycle is automatic.
The entire cycle will take 45-60 minutes to complete.
During the cleaning your coffeemaker will:
a. Slow brew approx. 3 cups of cleaning solution.
b. Pause for 30 minutes (the CLEAN light will remain on to alert
you that the process is active).
c. After 30 minutes, your coffeemaker will brew the remainder of the cleaning
solution.
d. When complete, the CLEAN light will turn off and your coffeemaker will turn off.
5. Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean, fresh water.
7. Place the empty decanter back on the coffeemaker.
8. Remove and discard the paper filter used during the cleaning cycle. If a Mr. Coffee®
permanent filter was used during cleaning, remove it and rinse it thoroughly before
replacing it in the filter basket.
9. Begin brewing and allow the full brew cycle to complete.
10. Repeat steps 5 through 9 one more time.
Mar 27, 2011 | Microwave Ovens
How do you go about "descaleing" the coffee maker? The water does not flow through the coffee capsule very well.
I know that most grocery stores sell a "cleaner" or two next to their coffee filters/coffee makers/kitchen appliances section. These are usually heavily acidic, and will do a great job of cleaining your coffee maker. I've always been wary of acid in my coffee though, so I just use white vinegar. It'll do a decent job of cleaning out the coffee maker. Run a 1:1 mix of water and vinegar through your coffee maker, drain it, then run water through at least twice.
Scaleing/deposits building up in a coffee maker are signs of imperfections in the water. All tap water has it, but if you don't want to worry about it, use bottled or filtred water in your coffee pot. Plus, your coffee will taste better!
Mar 16, 2011 | Microwave Ovens
I have a Black 4 cup Mr Coffee with luminate lighting and time display programer so that I can have coffee brewed in the morning when I get up for work at 4:30am my problem is the coffee pot has started...
I had a black and decker coffee pot do same thing and it was brand new. here is how I fixed it.
make sure the filter seated down good. If you look at the top of the coffee pot it should open up the little valve of the coffee filter holder. also mine had a little water spout above the coffee filter that swings over the filter. make sure it is over the filter. I know my coffee pot is different, but I think the problem is the opening from filter to coffee pot is not open some how so the water is flooding over the filter and going out the sides onto counter
hope this helps
Jan 28, 2011 | Microwave Ovens
We received a 14 Cup Delonghi coffee maker DC312T and the carafe leaks. We love the coffee maker, & do not wish to return the unit. It was ordered on-line... All we need is a replacement carafe. ...
Sorry to read about your problem, I hope this helps you out.
Contact Delonghi at Delonghi.com
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | DeLonghi Microwave Ovens
How much vinergar do put in a 12 cup coffee maker when cleaning it
Howdy, 1 part vinegar to 3 parts water. Pretend you are making a pot of coffee. It is recommended to do this every 2 months or so, more oftenif you have really hard water.
Regards,
Farmerbear at FixYa.com
Sep 11, 2010 | Microwave Ovens
How much coffee grounds should I use for 30 cups of coffee made in a west bend 30 cup coffee maker?
!/4 cup of coffee for every 8 cups of water or almost a full cup of coffe for your 30 cup pot...
heatman101
Sep 07, 2010 | Microwave Ovens
Bunn coffee pot brewing before lid is closed
I wonder if it may have a bad lid switch?
I would suggest you visit Bunn Customer Support for help.
Dec 31, 2008 | Microwave Ovens
Microwave Ovens Logo
91 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
