Question about Kenmore 73102 Gas Dryer
I have a Kenmore dryer model 110.76662501. It runs fine but will not continuously heat up - it will heat up for a while then go cold. I have replaced the Thermal Fuse and the Ingnitor - again it ran for a while but then goes cold. I have blown out the lines and the cleaned out the dryer itself. I'm stuck - any suggestions. Thanks!
  • 1 more comment
  • rkreece Nov 09, 2010
    How do I check for continuity on the thermostat?
    How do I check fot the continuity on the thermostat?
    How do I check for the continuity of the thermostat?
  • 4,323 Answers
Hi
There are three more things to check for: High limit thermostat, cycling thermostat and the flame sensor. You can start with checking the thermostat and check for continuity, if there isn't any then it is bad thermostat and a replacement is required. Hope this helps...please let me know if you require further assistance.
Daniel
Posted on Nov 09, 2010
  • Daniel Scott
    Daniel Scott Nov 09, 2010
    Hi
    Sorry about the late response. Somehow, I missed your emails. You'll need to use a multimeter to check the continuity of the thermostat. Disconnect the wires from the thermostat to be tested. Set the multimeter to Ohms (Rx1 or Rx10). A good thermostat will display resistance as infinite or OL. If it shows some didgits or values or Xero then it is faulty and needs to be replaced. Hope this helps... Please post back if you need more information.
    Daniel
Kenmore Dryer 300 Series No heat , I check continuity to all parts , it ok , but still no heat on dryer What's wrong?
What is the model number?
Exactly which parts did you check?
Also, check the breakers. The breakers are 220 and one of them may have thrown not allowing it to heat but the dryer will run.
Oct 17, 2012 | Kenmore 400 6942 Dryer
Kenmore gas dryer...Model 110.76832500: Heat up when cold, but will not maintain flame more than a minute or two. When cools down will begin again, only after restart. all else continues to run fine.
Sorry to read about your problem, I hope this helps you out.
you may have a defective gas/flame sensor. this tells the unit, the the pilot worked and the gas started.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | Kenmore Dryers
Kenmore Dryer model 110.62932100
First, make sure that there is no ventilation issue and that the vent is clean and clear. If the dryer isn't heating, check for a blown thermal fuse or a faulty heating element. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty component. Both components are located in the rear of the dryer. The thermal fuse is about an inch long and is usually attached to or near the exhaust duct. Remember to disconnect the dryer from the power source before attempting any repair.Sorry for your trouble and I hope this helped. Best wishes.
Sep 29, 2009 | Kenmore 659 Electric Dryer
Kenmore Model 11070852990. Will not heat. Not
could be three things. 1st) 240v should enter the unit. if 120v is missing then the unit will run but will not heat (on an electric dryer).
2nd) the thermal cut-off is not showing continuity and therefore not allowing voltage to travel to the element. 3rd) could be the element itself not showing continuity.
If it's a gas dryer, it's most likely a thermal fuse or the ignitor. please let me know if i can be of better help. good luck :)
Jul 13, 2009 | Dryers
Kenmore electric dryer, 600 series, runs but does not heat.
check you're thermostats for continuity, they are normally 3 thermostats, reset stats have a button on them please press, if not thermostat its your heating element
Jun 20, 2009 | Dryers
Dryer wont run
Check the door switch for continuity.
Check the thermal fuse on the heat canister for continuity.
No continuity, bad part.
Mar 03, 2009 | Kenmore 72982 Gas Dryer
Kenmore gas dryer model#73022 no heat when running
The first thing is to look at your tech manual and do a continuity test on the thermistor.
Oct 23, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 73102 Gas Dryer Logo
158 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
