Question about Hotpoint Dryers
I have a hot point dryer model dlb265obdlwh not giving heat but will run
  • Hotpoint Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Nov 11, 2010
Hot point dryer drum does not turn, but the dryer will heat?
That might be bad glides on the front. Newer models have glides on top of the drum while older models have glides on the bottom. Both are easily replaceable. The belt might be broken because of the glides.
Not all hotpoint dryers are built the same but I made a few videos of these dryers to give an idea how to get into them:
More from my blog: Hotpoint dryer repair
Oct 26, 2012 | Dryers
Hi, i am experiencing issues with my Kenmore 80 series , model no. 110.76832500, natural gas dryer. The issue seems to be overheating or a faulty sensor. The dryer heats normally and spins fine when first...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Sep 06, 2011 | Kenmore Dryers
The heat coming out of ny dryer is to hot , the duct is way to hot to touch .model # yrel3613b(maybe 8)w2 thank-you
heatman101
Sep 06, 2011 | Roper Dryers
I have a bosch 500 that continually heats even in air only option...to the point where the reset needs to be pressed....any help ideas?
heatman101
Sep 05, 2011 | Bosch Nexxt WTMC 3300 Electric Dryer
Wont heat on low heat only on high heat and keeps running
heatman101
Aug 15, 2011 | Whirlpool Dryers
Dryer shuts off after 5 minutes.hose is clear..appears to get hot...also hot to touch on top
If your dryer is still heating, but your clothes aren't drying properly, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks, clogs, or excessive bends. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
In severe cases of dryer vent clogging, you may experience condensation inside the drum and/or vent exhaust. The dryer exhausts warm, moist air. If the heat and moisture have no where to go, it will condensate inside the drum and exhaust vent. Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer that is clogged, or has restricted air flow, will not dry efficiently and will cause the heating circuits to OVERHEAT. This eventually will lead to component failures and is the source of many fire hazards.
There are no adjustments that can be made to any of the internal thermostats or heating element to make it run at a higher temperature. All these components have a fixed setting. If the dryer still produces heat, this usually a good sign the heating element is working. If the dryer is clogged, however, the internal protection devices, such as the Hi-Limit Thermostat and Internal Bias Thermostat will shut the heating element off prematurely to prevent the dryer from overheating, and to prevent damage to the heating element. Eventually, the Thermal Cut-Out (TCO) or Thermal Fuse will trip and the dryer will not run.or produce heat.
NOTE: If you have already determined the exhaust ventilation is clear from the point where it leaves the back of the dryer to the point where it exits your home, you need to check the vent hose run to ensure there are no excessive bends or kinks that can be causing choke points that restrict air flow. If the vent line checks ok, then you need to inspect your blower fan housing inside the dryer to ensure it is not clogged. If you have any questions, please post back with your COMPLETE MODEL NUMBER and let me know. I hope you find this information helpful.
Dec 23, 2010 | Roper Dryers
Stopped heating
What I do is see if their could be an obvious reason for the dryer to quit heating. I determine how old the dryer is and ask if the heating element has been replaced and when, those sorts of questions then that give me an idea. I make it a point to clean and oil any dryer I work o. They all are going to have lint buildup in them and this lint is the main cause of heat failure. A small piece of lint gets on the heating element and causes a hot spot. The hot spot burns through interrupting the circuit93b855d.jpg
I unplug the machine and remove the rear cover. 1c9e8bc.jpg I 1. Hi Limit (small limit upper right hand side of this pic) the most frequent problem if dryer RUNS but no heat AND you have
checked the element and found it to be good. 2. Heater assembly. 7. Control thermostat(s). 5. Fuse(350F), if blown(open) the dryer will NOT run. 4. Heater element
(if you do not have a meter remove and inspect this heater coil for breaks). I remove the lint chute(that the thing the filter lives in) and I wash that out because it gets clogged over time. I check the heater and limits for continuity. Then I remove the front panel and drum. Completely vacuum out the dryer and oil the rollers. d4f393f.jpg
If this is a gas dryer you want to see if power is going to the gas assembly
If this fuseeda36f9.jpg is blown on a gas dryer the dryer will run but the heat will not, If the dryer heats a little but quits then these coils are getting hot and intermittent94fb1fe.jpgif your igniter is blown a54d451.jpgor your sensor is open5650218.jpgthere won't be no heat.
Apr 09, 2010 | Whirlpool LER5636P Electric Dryer
Does this model have two heating elements it get hot but not as hot as it should takes too long to dry cloths
An electric Estate dryer, manufactured by Whirlpool only has one heating element. If your dryer is STILL heating, but you are experiencing longer dry times and poor drying efficiency, the following link can give you some items to check before you assume there is a malfunction with your dryer:
The element should cycle on and off as the dryer cycle runs. If it is glowing steady and really bright, its a good sign that you may have a clog somewhere. The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
If you have any questions, please post back and let me know. Please include your MODEL NUMBER (if it is different from the one you listed this question under), so I can determine how your dryer is configured. I hope you find this information is helpful.
NOTE: If you thoroughly check everything and still have problems let me know. The problem could be related to a thermostat beginning to fail.
Feb 15, 2010 | Estate TEDS740JQ Electric Dryer
Dryer has to be ran 2 to 3 times to completely dry clothes.
If your dryer is heating, but you are experiencing longer dry times and poor drying efficiency, the following link can give you some items to check before you assume there is a malfunction with your dryer:
Feb 08, 2010 | Whirlpool LER4634J Electric Dryer
Hotpoint Aquarius Condensor Dryer not getting Hot
I don't know Hotpoint models but I do know Malber models very well which also have a condensing dryer. The dryer has a fan and a heating coil or heating element, similar to a hair dryer. If you are getting no air flow, then it could be the fan. If you are getting air flow but it is not hot, then it is probably the heating element which burnt out. In the Malber machine, the top cover comes off and you can see an aluminum duct on top with two terminals sticking out the side. These two terminals go to the heating element inside the duct, and the heater element is like the heating element in an oven. You have to remove the duct and then it splits into a top and bottom half, and then you can remove the heating element to replace it. The way to tell if it is bad is to run the machine in a dry cycle and see if there is 110 volts across the heating element terminals. If there is power, but no heat, then the heating element is bad. That element is usually the first thing to fail.
Feb 11, 2008 | Hotpoint NVL333EY Electric Dryer
Dryers Logo
47 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
