Question about Onkyo TX-SR875 Receiver
I have an Onkyo A-RV401 Integrated Amp; Sound from the left output goes off and then returns after a minute or two.
2 Suggested Answers
marsrover
  • 682 Answers
SOURCE: Onkyo TX-SR701 no Digital output sound!!
befor go to any direction please repeat your system setup as manual told you(for digital output setting)
Posted on Apr 09, 2009
ONKYO TX-SR701 - Hi When using the speaker config I can get output from all speakers but the Surround back speaker R does not work. I do get sound from Surround back L. It's a bit confusing as the...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR701-Receivers-manual/id/365ag222/t/2/
7.1 would have Surround Back L and R.
6.1 would have just one back there (SB). It defaults to the Left output on the Pre-Outs if you ever go that route.
This being a 6.1 receiver it does not support two SB channels BUT you can configure those amp channels for a separate Zone supporting 2 speakers. Confused?
The manual shows a single SB speaker connected to the left side on Page 27. THAT would be consistent with a 6.1 configuration.
Jun 04, 2011 | Onkyo TX-SR701 Receiver
I do not see any inputs to connect a subwoofer to my Onkyo A-9555 integrated amp. I would like to know if it is possible to connect it and what kind of subwoofer should I buy for that wit the best...
You amp has no OUTputs for a sub, but if you really want to attach a sub you'll need to get one that is self-amplified and accepts >>>stereo<<< High Level or Speaker Level inputs.
Otherwise your amp's volume control won't also control the sub's volume.
You would feed it full-range audio from the speaker terminals on your amp and its internal amp would use that to develop its own power output for the sub.
Here's one example.
http://www.ch.onkyo.com/files.download/skw-205_manual_e.pdf
Jan 29, 2011 | Onkyo A-9555 INTEGRATED DGTL AMPLIFIER...
Hi i have bought an onkyo ARV 401 amplifier and i
You can choose any speakers to go with your amp as long as
1) they will allow the amp to perform at its best ( impedance and power handling)
Ideally you will buy speakers which will handle the full amps output plus more, then when you turn it up LOUD, you will not break the speakers
2) you still like the sound when they are demonstrated, installed at your home.
Sound is a very individual thing, if you like it then its fine, after all you are the one listening to it most.
Hope this helps
Thanks for using FixYa
Aug 07, 2010 | Onkyo TX-SR875 Receiver
I have 1 center channel pre-out on back of my kenwood receiver. how do i hook it to the inputs on onkyo m-282 amp and then to center channel speaker?
Unfortunately can't connect it that way. The pre out is only meant to go directly into an amplifier that has all of the same inputs (front/rear, center and surround), not a standard receiver. (Pre amp to amp only, not pre amp to receiver) If your Onkyo doesn't have all the same inputs as your Kenwood preamp has outputs you will just use your standard left/right outputs from the Kenwood to your Onkyo input (CD, Tape, Phono,DVD etc) then use the outputs (front/rear, center and surround) from your Onkyo receiver and connect directly to your speakers..
Jan 01, 2010 | Onkyo M-282 2-Channel Amplifier
I need speakers for my Onkyo A-911M integrated amp
A+B speakers = 4 channels 2 right 2 left
100 watts/4 = 25 watts per channel
RMS watts / channel = 25 x .707 = 18 watts/channel which is your average consumer stereo system
I would use 8 or 16 ohm speakers (not 4 ohm) -- almost any set of stereo speakers will "work" -- these will be 8 ohm and about 5 watt minimum / 40 watt max thereabouts
May 07, 2009 | Onkyo Audio Players & Recorders
No sound output
Known problem w/Onkyo. Resolder Q710 transistor on DSP board.
Onkyo is aware of this problem.
Apr 11, 2009 | Onkyo TX-DS575 Receiver
Loss of video signal from Onkyo TX SR 875
Go to hardware set up and turn off the hdmi audio output,sounds daft but it should work,also make sure the B speakers are not on as this puts the menu up the left.
hope this helps.
CABLE GUY.
Jun 30, 2008 | Onkyo TX-SR503 Receiver
Very low ouput from subwoofer preout
The problem was that some subwoofers (inluding my velodyne model) cannot process the LFE signals through the line level inputs on its amps, so the other way to run your subwoofer is to run the front left and right speaker outputs from your receiver to the speaker-level inputs on your sub, and then plug your front and left speakers into the soeaker level outputs on the sub. you have to set the onkyo receiver to "Subwoofer: No". that way the LFE signals are sent through the front speaker channels and you will get the same BASS output as if using the line-level input. O So yes it does require a bit more speaker cable, but it works fine now.
Mar 18, 2008 | Onkyo TX-SR304 Receiver
Onkyo A-RV401 amp is not sending any sound to the speakers.
The protection circuit is self resetting, it operates only when there is a fault condition in the amp. there is most probably a failure in the output stages of the amp causing a dc offset condition in the speaker output. The protection cct operates to prevent damage to your speakers. It may be difficult to offer a solution to you for this, it gets a bit complex to fix from here...you may have dry solder joint problems in the output stages, or more likely, failed output components. if you have a transistor checker(ohms meter), then you may be able to determine if any output transistors have failed, I recommend taking the amp to a good HiFi guy for repair. Many (including myself) often replace the all transistors to the last 2 stages when outputs fail. assures reliability in the future to repair this way, but the cost goes up a bit also. expect at least $120 to repair is it is a failed output stage.
Jan 03, 2008 | Audio Players & Recorders
Open Questions:
See all Onkyo TX-SR875 Receiver Questions
Onkyo TX-SR875 Receiver Logo
130 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
