Question about Zanussi Dishwashers
Hi I have a Zanussi ZD604W which is a built-in model but it is 14 years old so not sure if it is even made now. The problem is that it is not filling with water, everything else seems to be working ie. the element is heating & its making all the right noises!
Rotu
  • 175 Answers
SOURCE: Asko D1796 will not start properly
It sounds as if you may have A bad control board. It could be causing the heater element to come on when its not supposed to (usually a stuck relay) and not filling the machine with water. you could also have a bad control board AND a bad fill valve, as a stuck relay for the heater shouldn't affect the fill valve circuit. The bad news is that these asko control boards are $350 to $450 for just the part, the good news is that the control board is under a 5 year warranty (for only the part, not the labor to change it) as are the pump motors and any timers. Also, if you are just out of warranty, find your date of installation, as asko warranties start when you install it, not when you buy it (if you moved into the house and it was there when you moved in, and you are the first owner, submit a date of occupancy and that's when your warranty started)
Posted on Jan 13, 2007
  • 38 Answers
SOURCE: No water filling up in the dishwasher when programme set
your pump needs replacing
Posted on Mar 20, 2007
  • 35 Answers
SOURCE: Water not filling up the icemaker
it sounds as tho you do have solenoid prob.but it could also be an ice over sit at your water inlet tube that is situated near icemaker.
Posted on Jun 25, 2007
  • 641 Answers
SOURCE: Water isn't heating up and not drying
Check with a multi-meter for voltage (220/115v) on heating element's tags. If you can read this voltage on tags - you should replace the heating element In case you can't read voltage on its tags, disconnect one of the wires from its tag (you should unplug first your machine's power cable!) and test for element's resistance - If you can read its resistance, you should replace the thermostat. In case of no resistance - you should replace element and thermostat Good luck!
Posted on Aug 03, 2007
Falling Down
  • 67 Answers
SOURCE: problems! zanussi zsf6120
You can check the heating element with an ohmmeter and it should read a few hundred ohms. Don't know about the thermostat but it should be inline electrically with the heating element and should ohm as a short when cold.
Posted on Nov 30, 2007
My 5 year old zanussi 1449 E washing machine is not taking in water on any programme. water feed is ok
Water pump has quit. You can fill manually until you can replace pump or washer
Aug 04, 2013 | Zanussi Washing Machines
Zanussi ZWF 1020W front loading washing machine - filling o.k., draining o.k. but drum will not rotate & machine will not spin - any help gratefully received
Hi from retired Englishman in SW France @ 21:17 Sat evening,
I presume that you could turn the drum by hand? Also how old/used is it, please?
Can you hear a sound as if the motor is turning? If you can it could be that the belt has broken/come off. If you cannot hear it it could be that the motor is not working.
WITH THE POWER OFF-
have the back removed so that the belt (and motor) can then be seen easily.
If belt is OK then it is likely to be the motor especially if the machine is quite a few years old and well used. Often the motor brushes wear down to the extent that they do not run on the commutator and the motor stops- or, as in our case just before Xmas, becomes intermittent. Although it is possible to go the least costly way and have the brushes changed, it is false economy in the long run. The new brushes will not bed in correctly and will only last a fairly short time (I've heard of 1 month!). A replacement motor (ours cost £250- and I replaced the belt at the same time- both were 15-20 years old) should last for many years.
I hope this assists,
Cheers,
John C
Jan 29, 2011 | Zanussi FJD1666W Front Load Washer
No water in dishwasher
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Jun 06, 2010 | Tecnik TDW2677 Built-in Dishwasher
My zanussi dishwasher (4 years old) does not turn on anymore
Was this all of a sudden or was it going through a cycle at the time?Have you checked that there is power at the powerpoint?
May 13, 2010 | Zanussi 24 in. DA6141 Built-in Dishwasher
Zanussi zwf1211w
are the water supply taps fully on ? check that it is filling quick enough. let my know how you get on. also is it heating the water?
Feb 16, 2008 | Zanussi ZWF1430W Front Load Washer
Fridge does not cool
lo1972
Sounds like ice built up on the evaporator coils inside the freezer. thus hindering air flow to the refridgerator section. Is there ice build up in the freezer? This is assuming the temperature control didn't get changed inadverttily.
Hope this helps
handiman518
Jan 16, 2008 | Zanussi ZEBF250W Bottom Freezer...
Zanussi dishwasher
hi there sounds like a possible dry joint on the pcb repair and try first
Nov 26, 2007 | Zanussi ZT485 Built-in Dishwasher
Dishwashers Logo
51 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
