Question about RELIANCE ELECTRIC WATER HEATER
I have to keep pressing the reset button. It lasts about a day. The unit is 6 years old
  • 7,733 Answers
This will help you obtain a manual for just about any electronic device out there, provided it was files with the FCC (which is nearly every legal device). This will work for everything from Mobile Phones to Bluetooth Devices to TVs and Universal Remotes to Applainces and just about any other device you can think of.
Just follow the below steps.
Locate the FCC ID, either on the product or the packaging.
Examples: BCGA1241 or DZL201678 or YPD-HF300
Note: hyphens (-) are counted as part of the FCC ID and it's a good idea to have the model number though most time you can figure it out after the search.
Goto FCC Search Site: https://gullfoss2.fcc.gov/oetcf/eas/reports/GenericSearch.cfm
Enter FCC ID, including hyphens (see image below).
First Field: (First three characters of FCCID)
Second Field: (Remaining characters of FCCID)
Locate your specific model, then click the "Detail" link.
Then, select User Manual (usually a PDF fI have to keep pressing the reset button. It lasts - 3ecaa2d.png will need a reader).
Note: If this helps you, please remember to give me a vote and rating.
Thanks.
Posted on Nov 12, 2010
Reduced Hot Water
Water heater 14 years old, probably has never been flushed, Flush recommended at least every 6 months, Build up inside tank may be to late to flush, but you can try or replace heater.
press the helpful button
Feb 11, 2016 | Element Water Heaters
I have a Reliance 501 HWH, 15 yrs old. Nary a problem until now. Yesterday, HW was very hot. Today, no HW. I'm thinking of replacing both elements and thermostats due to the age. Sound reasonable?
At fifteen years of age it would be less cost over time and labor to replace the whole tank. How efficient is your old one and being it runs hot all the time you could have a tank that will not last very long anyway. Mine sprung a leak at 18 years and made a big mess.
May 15, 2014 | Reliance Water Heater #6-50-DJRT 50GAL...
Reset button on water heater keeps tripping
Need a new thermostat to keep the unit from tripping
Feb 13, 2013 | Bradford White CF-50-6 50 Gallon - 119,000...
Continuous ignition failure code comes up every day have to shut off powervent switch and on and unit will instantly turn on. problem began intermittently now happens every day. tired of resetting switch...
Hello
You need to unlock disply by holding down the up and down buttons until the lock flashes then goes away.
Once inlocked you can press mode button to resume normal operation.
Here is a link for your HW heater.Note pgs 22 to 24.
http://globalimageserver.com/fetchDocument.aspx?id=a92c7d0e-8a95-48ba-8810-cd714f33d47a
Aug 26, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water leaking observed from the bottom of the tank. What's the problem? Should I replace the old 21V40-2 unit? if so, what kind of tank is ok to replace the present unit? What's the price and installation...
If water heater is leaking, then open following 2 links to avoid tank rupture and troubleshoot leak:
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
http://waterheatertimer.org/Water-heater-is-leaking.html
Open following link if you want to install your own gas water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
To have gas water heater installed, can run $2-300 for installation plus cost of heater.
40 gallon natural gas water heater at Lowes starts at $300+, and tanks with longer warranty cost more and last longer.
If you maintain the tank: keep chemicals out of same room as water heater, attach bare copper ground wire between hot and cold pipes, flush tank each 6 months, clean burner each year as shown in manual, read the manual entirely for specific information about your model, and inspect/replace anode rod every 2-3 years then basic 6-year tank can last much longer.
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Apr 07, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Ge electric water heater. 3 years old. keep tripping reset. both elements show 13 ohms, with no gronding out condition. help!
Have you replaced the thermostat they will short out and keep tripping to they go bad. Check the ends of the elements also for any bad places. Ran along this a few times and it ends up being a bad thermostat causing it to trip. You will reset it and it may last a day or more and keep resetting it and eventually it will short out or burnt out. So please check it out and this helps you.
Mar 13, 2011 | General Electric Water Heaters
I have a Servi-star 40 Gal. electric SN# SS 0496B15258, How old is this unit? Thanks, Jim
http://www.buyerschoiceinspections.com/water-heater-ages
There seem to be 2 possible answers: Servi-star vs Servistar
Answer #1: Servi-star by American
1st 2 digits are year, 2nd 2 digits are week
This means water heater was made year 2004, 96th week ....it seems wrong.
Answer #2: Servistar by Craftmaster
1st 2 digits are month, 2nd 2 digits are year
This would mean your water heater was made 4th month of 1996
Which answer is true? 6 years old or 14 years old
If tank had 12 year warranty and came with 2 anode rods, and you have good water, and no stray current on pipes, then tank can last 14 years.
If tank had 6 year warranty and came with one anode rod, and you have hard water and a water softener, and you never changed anode rod or drained tank, then 6 years is a long life for the tank.
Oct 07, 2010 | Rheem Water Heaters
The pilot light has started going out and it has happened 3 times over the last two days. The Reliance phone rep says we need to get a new pilot light unit and install it ourselves. The heater is on 13...
your thermocouple is getting bad and shuts off the gas supply for safety,normally the thermocouple and the components come as a unit just repl all its easy with a few simple hand tools
Oct 07, 2009 | Water Heaters
I have a electric whirlpool 50 gal. energy saver water heater that is 3 months old. It keeps shutting off so i called whirlpool and sears came out and replaced the energy smart box on top. now it is...
the thermostat should be replaced it only has one on the upper eloement, it has the dial on it to set the temp, but if it is only 3 months old it comes with a 1 year parts 6 year tank warranty, if you call whirlpool and tell them about this problem they will have there own teck or sub contractor that they use to come out and fix it for free,,, first go to there web site and put in your serial number and it will tell you how old the unit is, sometimes they sit for a while and are actually out of warranty before it is installed,, also did you install it your self?? if you did di you fill it with water all the way till the water came out of the hot side on your faucet full force before turning on the electric,, if not you have fried the whole unit, you will need to replace both elements and the thermostat, the elements must be completely submerged in water before they have the power turned on,,,
Jun 25, 2009 | Water Heaters
RELIANCE ELECTRIC WATER HEATER Logo
128 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
