Question about Canon PIXMA MP540 All-In-One InkJet Printer
MP 545 with status error B200, please tell me what to do. Thank you Mia
5 Suggested Answers
cns assoc
  • 677 Answers
SOURCE: does not print error b200
Helo, found on web. Good Luck :0)
The error code is standard for many of the late model MPxxx printers. The B200 error is "Printhead Temperature exceeded", What this means that while you were printing some document, either one or more of the printhead ink wells ran out of ink and the printing continued. Printhing without ink in the wells will OVERHEAT THE PRINTHEAD NOZZLES and can potentially burn the out. The printer has a built in temperature sensor to detect the ambient temperature and to monitor the temperature of the head. This data is always collected and monitored and saved in the EEprom data and the Service Test print data.
If the error will not go away once you have unplugged the priner for at least 5 minutes, then there is the possibility that you have already burnt out the head. Remove the printhead and use a 5x magnification glass to look VERY CLOSE at all of the nozzles to see if you can detect any possible burnt out nozzle.
It many come down to need a new printhead.
HERE IS THE LINK, IF YOU HAVE PROBLEMS.
http://www.fixyourownprinter.com/forums/laser/13864
Posted on Nov 07, 2009
  • 12 Answers
SOURCE: ho una canon mp 540
b200 is bad printerhead. I replaced mine and everything is working now.
Posted on Dec 03, 2010
  • 12 Answers
SOURCE: i am getting error code
B200 IS BAD PRINTHEAD. i TRIED TO CLEAN CLOGS BUT IN THE END THE FIX WILL BE TO (REPLACE PRINTHEAD) IF UNCLOGGING PRINTHEAD OF DRY INK DOES NOT WORK. YOU CAN UNCLOG BY USING A PRINTHEAD CLEAMING KIT, BUT IF THIS DOES NOT WORK REPLACE HEAD. EBAY WAS CHEAP FOR ME 25 BUCKS PRINTER IS WORKING AGAIN.
  • 1570 Answers
SOURCE: Canon MP 630 Printer error B200
Hi
3 reason for these error.
1. Print Head is unclean or dirty, remove the print cartridge and clean the print head by rubbing into a piece of paper with alcohol until ink flows. Turn of your printer and then check if the error message disapper.
2. Print Carriage get jammed. Open the cartridge door and then turn off the printer. Use your hand to move the print head from left to right and from right to left for 3 times to clear the carriage jammed. Then close the cartridge door and Turn on your printer.
3.The internal temperature exceeds the specific value of the logic board. Try to replace that parts.
If not, try a hard reset of the printer may clear the error. Here is how to perform the hard reset:
1.Shut down the computer.
2.Open the top cover of the printer and remove the print cartridges.
3.Close the top cover of the printer.
4.Press the power button on the printer to turn the printer off.
5.Disconnect the communications, (USB or Parallel), cable from the back of the printer.
6.Disconnect the power cord from the back of the printer for one minute.
7.Reconnect the communications cable to the printer.
8.Reconnect the power cable to the printer.
9.Press the printer power button to turn the printer on.
10.Open the top cover and reinsert the print cartridges.
11.Close the top cover and print the calibration page.
12.Restart the computer.
Let me know if you need more help
Posted on Mar 13, 2011
The Ricoh Mp 2000 copier displays "Error occured Sc:545 Functional problem"
It's a fuser overheat error enter service mode to clear, if it comes back service call ( push in sequence clear modes(yellow) 1 0 7 hold down stop for 5 or so seconds, screen will change, power down, red switch. -Carl
Jan 30, 2014 | Ricoh Aficio MP 2000 Black and White...
Canon pixma MP 287 has B200 error
GIMANA YA CARA MENGATASI PRIN ERROR B200 PADA PRIN MP 287
Jan 24, 2013 | Canon PIXMA MP287 ALL-IN-ONE INKJET...
Error B200 canon mp250
Please remove the both catridge and replace again... I think it may help you. thanks
Aug 11, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
B200
Hi there!
If you're getting the error code B200 when you try to print on your Canon PIXMA MX850, there is nothing you can do except to have it repaired. This error code indicates a Voltage High Error of the Canon printer. If the printer is still under warranty, please contact Canon for further assistance.
Jun 26, 2011 | Canon PIXMA MX850 Multifunction Printer
I have a B200 code problem in my pixma mp 510
error B200 refers to an overheat condition in the printhead. However it could also be a problem with the carriage and/or main board. The first thing to do is change the printhead. Its a expensive gamble if it proves to be the carriage or board. the decision is yours!!!
May 16, 2011 | Canon PIXMA MP510 All-In-One InkJet...
Canon Printer Pixma MP540 with error code B200 - what can I do? Thank you for your support. Arthur
Try to press down on the sponge to get it to work again. It may be a waste toner issue, which generally is repaired at an authorized service center for canon by contacting 1-800-OK CANON or logging on to canonusa.com.
Good luck on this.
Feb 12, 2011 | Canon PIXMA MP540 All-In-One InkJet...
Am not able to print anything and on the screen popup a window that shows ERROR B200 how can I solve the problem if I do not have the manual.Please advise on how to correct the problem.Thank...
Am not able to print anything and on the screen popup a window that shows ERROR B200 how can I solve the problem if I do not have the manual.Please advise on how to correct the problem.Thank You.
tony
Jan 27, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Ho una canon mp 540 e sul display mi appare error B200
Nov 18, 2010 | Canon PIXMA MP540 All-In-One InkJet...
E16
press stop reset button for few seconds and you can use your black cartridge for printing,but do remember to put use black only setting in ur printer cartridge settings.
Nov 09, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP540 All-In-One InkJet Printer Logo
413 people viewed this question
old marine
old marine
