Question about Intel D975XBX Motherboard
The cpu wouldnt fit, so when i forced it in a prong thing fell off and now it does fit, but it wont work, did i do somthing wrong and how can i fix this?
    Genius:
  • 1,672 Answers
Geez! Might one of those CAPACiTOR got cut off from its base! U need to bring ur MoBo to ur nearest Electronic techman!
Posted on Nov 09, 2010
I dropped my stereo at home and fell upside down now all my cd s got stuck i took it apart and all the placement cards fell out how do i fix
Not understanding or picturing what you mean by the term Placement Cards, i am at a bit of a loss here to be of much help. I have forgotten now what the insides of my tape deck looked like, too. Sorry.
My guess is that if you study the structures you will be able to grasp how they go together. Tinker with it and play around trying to get things to fit aback together. Things work together logically, but you do have to study the parts and pieces a bit to begin to see that logic. It may take you a while to get it right, but that only requires a bit of patience and not making yourself wrong emotionally. If you can call from memory how things looked before stuff fell apart, that will help. If you can remember how things fell apart that will help, too.
Have fun with the problem solving... just play. Best of luck.
PS
If you can post a picture and or video of what you have got, that may be of help to me so that i can make suggestions.... or others can.
May 20, 2014 | JVC MX-J900 CD Shelf System
"space compact icemaker" cover fell off. How to put it back?
To replace this part, locate the two holes at the front of the top base of the ice maker, going up into the freezer ceiling. Place the two half-round 'pegs' at the top of the missing cover (above the vent holes) into these holes, then press the cover back into place. The peg protruding from the back of the piece should go into the hole in the ice maker housing, and the prongs will catch on the ice maker when you snap it into place by brute force. I wasn't strong enough to push it back on with one hand, but a stronger person did it in seconds once I explained how it should fit.
May 30, 2010 | Samsung RF197ABRS Bottom Freezer French...
My Gateway GM5972 computer shut down and will not start up again, There is no video or audio. The fan still runs, and the DVD drive come on, but computer will not start up
Despite the fans running and the dvd powering up it could still be a power supply problem BUT it really sounds like the motherboard died.
I have built and repaired thousands of computers and your description fits the majority of the dead ones. Replacing the motherboard with a like board is the easiest solution. You can replace with a different motherboard but be prepared for problems. I wouldnt suggest it unless you are a experianced tech.
Apr 09, 2010 | Gateway GM5072 Desktop PC
No heat on 2005 honda accord - air works fine but its cold here now in NJ.
My did this recently. I went into the engine bay. Directly on the middle of the firewall you will see the heater core hose coming off the firewall going to a plastic boxy thing. That thing has a thin black "cable" going to it. It looks like the cable for a bicycle brake. This cable attaches to a metal prong. That prong regulates the hot coolant that goes through the heater core to heat up the air.
Go ahead and push down on the prong that the black "cable" attaches to. It should push down about 1" with minimal force. Dont go putting a million pounds of force on it.
Thats what I did with mine and it stated working. Post up if it worked!
Oct 12, 2009 | 2005 Honda Accord
Wii wouldnt take in games
u have knocked a chip out, it'll cost around 30 to 25 pound to get it fixed, dont worry its better to get it repared than get a new 1
Jul 23, 2009 | Nintendo Wii Console
Car wont go in third gear
the gear selectors have to be removed from the box to get the box out
it is possible that the selector area was not properly adjusted after installation of the box
you may be able to see the problem using a friend to shift the gears ( stationary -engine off) while you look at the selector movements --3rd gear will not select easily
the garage that did the job is a fault here as they haven't done the job properly or tested the car after the job to fix faults before you took it back
if you have to , take it to an accredited professional transmission service center for a diagnosis and quote
there will be nothing wrong with the box just the selector system
Apr 12, 2017 | 2006 Fiat 124
I droped my camera on the grond and it wont turn on.it fell the side of the lens
Theres a very good chance you are going to have it repaired by a Camera Repair person. I would really need to know the brand and model.
If it is a canon then it will most def. need a new lens assembly. they have metal pins which guide the lens and when they are droped the pins break out of place.
If it is a Nikon or Sony or Casio alot of times I have been able to push the lens straight and it will re-align itself and work perfect again. But that said I wouldnt be too forceful unless the camera is not worth fixing. In that case you really arnt risking anything other than the possibility of fixing it.
Jun 26, 2008 | Olympus Cameras
Got a gateway essential 450 mhz tried to upgrade the cpu to 1000 mhz
just cuse p3 doesnt meen it will work maby wrong fsb also ok
Jan 28, 2008 | Gateway Essential 500 PC Desktop
Nokia 6230 Wont Switch On
This is problem due to sofware
Sep 05, 2006 | Nokia 6230
Intel D975XBX Motherboard Logo
Top Intel Computers & Internet Experts
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
