Screen width unadjustable
This problem just came up today, where the horizontal edges of the screen are not shown on the monitor, ie i cant see the start button or the system tray. Adjusting the screen size with the buttons on the front of the monitor work for everything except the horizontal width. i even tried to just zoom out so i could at least see the edges of the screen, but the width stayed teh same, while the height changed. Thanks in advance for any help. I have an older Compaq TFT500 LCD monitor. One day I came to work and the horizontal edges of the display had grown slightly so that I can't quite see the very edges (left and right). This montitor has NO external width control.
  • 1,847 Answers
Chk the resolution is as mentioned by the makers in the user mannul.
Posted on Jun 17, 2008
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
I accidently hit recall on my monitor settings. I now have a smaller veiwing screen with black edges
You didn't say which OS you're using but it sounds like you've changed the aspect ratio of your video signal. Different screen resolutions have somewhat different aspect ratios. The aspect ratio indicates the ratio of the number of pixels of width to those of height. For example: my video driver offers a resolution of 1280 x 960 or 1280 x 720 which would give screen aspect ratios of 1280/960 = 1.33 :1 and 1280/720 = 1.77 : 1. The latter would produce a narrower image. You can compensate somewhat by increasing your horizontal sweep voltage with your monitor menu. A better solution would be to select a resolution that more closely matches your monitor's screen size.
Aug 10, 2011 | Dell D1028L 17" CRT Monitor
Screen horizondally pulled right side and screen rolled to left side
your monitors horizontal deflection side have some problem. you have to check the horizontal width cotrolling transistor mounded on the aluminum heatsik near the lot( line output transistor). also check the three mosfets which adjust the width for different resolutions. there are three such mosfets in the horizontal section.
fist of all replace the width controlling transistor in the heat sink. photo of mosfet and transistor is added for reference. not the exact number.
Jan 27, 2011 | AcerView 99C 19" CRT Monitor
My screen appears horizontally expanded
If your monitor is crt type, on its menu control, goto menu setting look for something that will adjust horizontal width. Or set the adjustment on Display setting in windows.
Apr 10, 2009 | Computers & Internet
Suddenly my horizontal size on my Dell montoris reduced about 1/3
On the monitor there should be some buttons that allow you to manually configure the width and hieght that the screen comes up with.
Does you screen come up squashed but you can still see everything or only 1/3 of the screen is shown and the rest is black.
Mar 20, 2009 | Dell E153FP 15" LCD Monitor
Lg flatron 775ft screen size problem
Hi Edit123,
U can chane output width and height from buttons given on LCD panel manually
Sep 19, 2008 | LG Flatron L1750S 17" LCD Monitor
Width increases a bit on lowering and incresing resolution
Hence my earlier suggestion of lowering the resolution, it was actually a test.
Now we are getting somewhere. Yoke is definitely out, opposing diode pair is also out. The remote chance of the horizontal sync/oscillator is also out. That leaves us only with a possible resistor that has gone up in value (or is open) (least likely) and/or a capacitor (most likely) that has leaked, bulged or whose capacitance has gone down.
Perhaps a service manual would be of more help.
Good luck.
Jul 20, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Monitor Height Shrinked and unadjustable.
that is my problem right now,,,just get your monitor and threw it use its a junk...
Dec 05, 2006 | Likom Futura LD5 15.1" CRT Monitor
Most likely width control circuit has developed a problem. Most common causes are a failed diode in the yoke return circuit or open capacitor near the flyback.
Sep 23, 2006 | Envision EFT720 17" Flat-Screen CRT...
Computers & Internet Logo
841 people viewed this question
David Payne
David Payne
