Question about Sony Playstation 3 (PS3) Console
Ps3 The problem with my PS3, is that every time I try to get out the disk that is in side the PS3 shuts off. And also when i press the power bottom in stay green for couple of second, and than it shuts off.
  • 182 Answers
Hi, you could try holding down the eject button for over 15 seconds, it resets the drive, that should get the game out, but i'm not sure about the powering off, hopefully it will fix this as well. If not it sounds like a job for sony if its still under a year old, then it should be covered under warranty. If not they can arrange to fix it. Your local number is found on the ps3 website. hope this helps
Posted on Jun 17, 2008
Black screen ps3 play
Where are you seeing the black screen?
If it is during game startup, then the game file could be corrupted:
Move selection to the game title that is causing the black screen and pres the triangle button for options, select "delete".
Then do a database rebuild (This also erases any messages, but will not lose game data or account info) -
Eject any disk that may be in your PS3, and power off.
Press and hold the power button on the console, until it cycles on and then shuts itself off.
Press and hold again until the console beeps once, and then rapidly beeps again two times.
A maintenence menu screen should appear, from that, select "rebuild database".
When it is finished, it should automaticly restart.
Then go to Playstation Store and re-download.
Reinstall and run to get it to update the game again and it should work fine.
If you mean that you only get a black screen when you turn on your PS3, then it could be set to the wrong video output. To get it to automaticly detect your video, use the procedure to get to the maintanence menu and it will display text asking for video setting:
Text should appear saying whether it detects HDMI video or not, if you see the text, then select "yes", otherwise simply wait a moment and it will switch to composite automaticly.
Sep 13, 2013 | Sony Dc Universe Online
Ps3 keeps shutting off
Time to bring it to a repair shop.
Jul 12, 2012 | Sony Playstation 3 (PS3) Console
I did everything except this time now it says "
Try a Restore
PS3 Recovery Menu
  1. Place the PS3 in standby mode
  2. Press and hold the power button for a couple of seconds, you should hear a beep
  3. Keep a hold of the power button for a couple more seconds, the PS3 should shut back down to standby mode
  4. Once this happens, press and hold the power button again for a couple of seconds, waiting for 1 single beep.
  5. Ignore this beep and keep it pressed until you hear 2 consecutive beeps, release the button.
Try restoring the file system (Option 3), then repeat with rebuilding the database (Option 4).
Feb 10, 2011 | Sony Playstation 3 (PS3) Console
On my PS3 when I try to update it, its keeps on saying error code 8002F994 and that the data is corrupted. Im tying to updated it to 3.5
Your HARD DRIVE (aka: Hard Disk), located on the left side of the unit, may have crashed. You will need to replace the HD.
When you replace your hard drive, you will need to have the latest firmware on a
usb stick. Download the firmware from the playstation official website onto a usb
stick. Once prompted by your system you will need to insert the usb stick into the
PS3. Good luck..
You will need 2.5" Sata Hard Drive.
Before you replace the hard drive, try:
Try accessing the recovery menu 'safe mode'.
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until you here 3 beeps. Let go.
It should ask you to connect your controller via usb and press the PS button in
the middle of your controller. There will be a menu with 6 options. Update using option 6.
PS3. Good luck..
Jan 28, 2011 | Sony Playstation 3 (PS3) Console
My PS3 has been broken for a very long period of time. About 6-9 months now, I've lost track. Every time I turn it on my PS3, it starts with the wavy animation and the colored background, and then the...
Ok, please try the following steps :
Step 1. Turn your PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep a total of 3 times and turn off again. Release the power button.
Step 3. Press and hold the power button. It will beep when you first press it, then 5 seconds later it will beep again and then it will beep twice quickly. Let go of the power button when you hear these 2 quick beeps.
Step 4. The PS3 will start up asking you to connect a controller via USB and press the PS button. Do this then continue to the next step
Step 5. The PS3 will load with a menu with 6 options, choose number 5 "Restore PS3 System" and follow the on screen prompts.
Using this method should sort your PS3 out for you.
Hope this helps
Oct 16, 2010 | Sony Playstation 3 (PS3) Console
Ps3 cannot start. the correct hard disk was not found
Hi if you replaced your hdd or if the old went foul try this plug your controller in with the usb lead insert a game disk, put it on standby (red Light) press and hold the power pad you will hear beep,beep, then it will shut down, Do it again beep, beep then beep beep take your finger off then follow your instincts on what it says. Also you may have to replace your hard drive ,not very expensive good luck
Mar 27, 2010 | Sony Playstation 3 (PS3) Console
HELP!! in march 09 my ps3 shut off and the light started blibking.. well like in xbox the ring of death, the same thing happened to the ps3.. the cause of it is the thermal paste inbetween the...
While it was a little hard to follow your explanation I think I can help you. It would be very difficult if not impossible to do this without actually looking at your unit. If you would like to send it in for repair though email me at Jordan@jordanselectronics.com
Jan 10, 2010 | Video Game Consoles & Games
Hi, my ps3 shutting down when I turne on the power
try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 27, 2009 | Sony PS3 40GB Best Sellers Bundle Console
My PS3 wont turn on it just flashes a yellow light then red light that beeps cant get disc out
I found a way to eject the disk:
  1. Power off the PS3 on the main switch on the back of the console
  2. Press and hold the Eject button
  3. Turn on the main power switch
  4. The PS3 LED will go green and the fan will spin at max speed
  5. Wait a few seconds and press the eject button a couple of times, the disk should now eject
  6. watch the PS3 die after 30s or so…
This procedure did not fix my PS3 but at least I got my disk back before sending it to Sony for repair.
Jun 10, 2009 | Sony Playstation 3 (PS3) Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
29 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
