Question about GE (PSS26MSRSS) Side by Side Refrigerator
On warm DAy My Refrigertor Dont Work I lost Food 2 Times But it stay running
  • 525 Answers
You don't say how old your unit is, so I will give you some things to look for.
1.Condensor coils must be kept clean. Inspect and clean if needed.
2.Door seals MUST be sealing tight so warm air does not enter the unit. Heat moves toward cold, so any void in the door seals will cause food loss.
3. Controls should be set fairly equal to each other, too much of 1 control over the creates unstable temp.
4. Limit door open times, get in, get out! Think ahead about what you want out of the unit.
5. Observe the compressor run time, if it's running continually, then you need to investigate the above issues. If no apparent cause is found, then you may have a weak compressor
Please rate this advice on helpful my answer was in resolving this issue.
Thank you.
Dave E. (Illeagle).
Posted on Jun 16, 2008
It is a all refrigertor the fan works the compressor works but dont get cold all the time. it warm then cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 11, 2011 | Refrigerators
Food defrosted pulled away from wall improved then defrosted again. Un plugged for day in case frozen somewhere, plugged back in and worked for a day. Now defrosted again. At times fridge has frozen food...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Feb 23, 2011 | Frigidaire Gallery Series GLRT83TEK 30"...
Refrigertor is running but the freezer is not that cold, and even the fresh food side the foods are not getting cold on the top 2 shelves what could possibly cause this problem..
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Jan 05, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer freezes and refrigertor will not stay cold
Hi
Check the back wall or floor of the freezer section for frost. Check the freezer or evaporator fan to see if it is running. Check the condenser coils under the unit for blockage from dust. Check the condenser fan to see if it is running.
If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost terminator, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. These things usually require dismantling the freezer and other areas of the refrigerator to be checked.
You could defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with the doors open to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jan 03, 2011 | Kenmore 53642 / 53644 Side by Side...
2 year old LG refrigertor doesnt cool inside is warm and the bottom freezer doesnt work either. outlet is ok. the light inside the refrigerator works.
Your run capacitor is bad which is the plug attached to your compressor or you have a leak in the system. If your compressor is not running after you put a capacitor on then your compressor is fried. Good luck. Rate me if I helped you!
Aug 27, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
I have a Kitchen Aid Md# KBLA20ERSS The
Lack of airflow up to the refrigerator. could be a defrost problem, a fan motor not running, a damper staying closed, a food obstruction, or something else altogether.
May 09, 2010 | KitchenAid (KBLA22ER) Bottom Freezer...
Freezer is coldbut the fresh food side is warm
there is probably something wrong with the defrost if you dont take the bak off and defrost all of the ice off they will freeze back up in no time
Apr 24, 2009 | Frigidaire 22.6 cu. ft. Side-By-Side...
We have an RS21 fridge freezer. Always freezing up. Last week, under the newly announced extended warranty (seen on Watchdog) it was 'fixed' again with some new parts. Fine for a week BUT Today it has...
Time to check the defrost timer, these can go bad on defrost and warm up the freezer / or on run mode, and cause the freezer coils to frost up..it usually will cycle 2 or 3 times a day. If you can find the timer (bottom, near floor) it can be rotated to cycle. (there are about 5 wires connected to it (it's about the size of pack of cigarettes.)
Apr 21, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
