Question about McCall Refrigerators
Keys We have misplaced the keys to our McCall Refrigerator and McCall Freezer. Anyway we could order a replacment set form anyone. Numbers on locks are KHC1311
    Genius:
  • 1,036 Answers
Hi there!
Yes you can order a set from most locksmiths that cut keys to code.
You may be able to order a set by phone for this.
Alternatively, the manufacturer will keep replacements, but may cost slightly more.
I hope this helps you resolve this problem. If it does, Please spare a moment to rate as Fixya! Thanks.
Posted on Jun 16, 2008
Freezer not cold and forming ice in side?
Replace the defrost thermostat located on the coils in the freezer. Here is the part to order.
Dec 03, 2012 | Amana ARS2464B Side by Side Refrigerator
I'm looking for keys for a Franklin Industres FBC 360D. Can you point me where I can buy them? Thanks, Nick
Hi Nick
Try this link the guys should be able to supply the spares, but you may have to buy locks and keys unless you have the key numbers, the numbers are sometimes on the face of the lock in tiny figures, but I can't promise they will be there
http://www.compactappliance.com/FBC360D-Franklin-Chief-Outdoor-Beverage-Cooler-Refrigerator/FBC360D%2Cdefault%2Cpd.html?mtcpromotion=CJ
Hope this helps
Gordon
Apr 15, 2011 | Franklin Industries FBC360D Beverage...
What does LLL code on a Mccall 4-4070 refrigerator mean?
We have a commercial freezer and where the temp should be showing it reads LLL can anyone tell me what that means. it is a MaCall 4-4070.
thanks Lisa
Oct 20, 2010 | McCall 2-2045 Stainless Steel Commercial...
I have a Samsung refrigerator/freezer How do I adjust the freezer temperature?
1Place the appliance thermometer in a glass of water.
2Set the glass of water with the thermometer in the refrigerator on the middle shelf.
3Check the temperature on the appliance thermometer after 24 hours.
The temperature should register between 37 and 40 degrees Fahrenheit (2 and 4 degrees Celsius) in order to store food safely.
4Look for the temperature control dial inside the refrigerator if you have to adjust the temperature, and make it warmer or cooler.
If you can’t easily see the control dial, check the owner’s manual for a diagram that shows the location
When looking at the refrigerator temperature dial, you may see numbers rather than degrees. The majority of refrigerators use a set of numbers, with the lower numbers representing cooler temperatures and the higher numbers representing warmer temperatures.
5Move the temperature dial in the necessary direction to adjust the temperature up or down. Be sure to move the dial only one number in either direction because it probably will not take much to change the temperature in the refrigerator.
6Adjust the temperature balance control if your refrigerator has such a dial or sliding switch. This allows you to direct more or less cold air to the refrigerator section from the freezer section.
7Wait at least 24 hours, and then check the refrigerator temperature again.
8Observe the amount of frost in the freezer section of the refrigerator if you are unable to properly set the temperature.
90Defrost the freezer if the amount of frost is more than .25 inches (.64 cm) thick.
10Repeat the steps as necessary until the temperature is within the safe range.
11Use a permanent marker to draw a line on the dial after you locate the best setting on the refrigerator temperature dial. This will give you a reference point in case your dial moves and needs to be adjusted in the future.
Hope this helpout...
Aug 09, 2010 | Samsung Refrigerators
Maytag MFI2266AEU Water and ice dispenser locked, control panel
Door Panel Locked
Press Door Alarm and Freezer "-" at the same time, then release Door Alarm but continue pressing Freezer "-". You will see PE _ _ _ _.
Press Freezer "-" until PE # # # # shows on the panel.
Using Freezer "+" to move cursor, Refrigerator "+" and "-" to change numbers, bring all numbers to "0". Press Freezer "-" until PE and numbers blink. Unplug refrigerator for 45 seconds, never beyond 1 minute or you'll have to start over.
Look inside refrigerator door and locate the serial sticker. To the right of the serial number is the CODE ####. Plug in your refrigerator.
Press Door Alarm and Freezer "-" at the same time, then release Door Alarm but continue to press Freezer "-". Using the same method as above, enter the four digit CODE number you found on the serial sticker. Press Freezer "-" until PE and numbers blink. You have just reset your panel. Unplug for 45 seconds. Plug in refrigerator and you should now have full use of your door panel.
This unit has a built in safety timer mechanism. If it dispenses water for two minutes, it assumes it is flooding your house and shuts the panel down. If you are filling a pitcher of water, just stop dispensing halfway through to reset the safety timer.
Feb 01, 2010 | Maytag MFI2266AE Side by Side Bottom...
Need drawer bins for a Subzero 201R refridgerator 30 years old
There may be a serial number break that would give a different part number. Make sure you give the serial number to the people you order parts from and see if they get diferent part numbers.
Jun 27, 2009 | Sub-Zero Bottom Freezer Refrigerator
The freezer temperature is too high. is it controlled somehow? the fresh food compartment is a bit warm too - though the setting is on coldest.
I've made a mistake before with thinking that I was setting the adjustment correctly on a refrigerator before, sometimes those dials are hard to read if there is a graphic scale, or symbols etc. Instead of numbers with the highest number being the coldest setting. Anyway make sure the temp setting is set correctly, these are found in the refrigerator side.(yes even for the freezer, so it does'nt freeze up) I adjust mine all of the time, things only need to be so cold right.(helps my elect bill) Make sure those special compartments have clear air passages to them. best regards.
Jun 08, 2009 | Haier HRF10 Top Freezer Refrigerator
Freezer fan noise
Remove the freezer panel to access the fan motor. Look for any obstruction around the fan or blade. Ice, misplaced wire etc.
Check the fan blade. Sometimes they slip down the shaft too far.
If you find none of these issues, replace the fan motor.
May 25, 2009 | GE GSH25JFR Side by Side Refrigerator
Ice forming on the inside of the freezer
freezer fan light maybe staying on or freezer door is not properly close
Mar 31, 2009 | Kenmore 55692 / 55694 Side by Side...
Mccall 4-4045
You would need to change the condensing unit (outside bit) to a larger duty, you would probably need to change the evaporator (inside coil) to match the condensing unit. You would need to install drain heater, door heaters and probably change part if not all of the control circuit. In short I would suggest not doing this unless you want to make a fridge guy a lot richer. I know fridges that can get to sub zero temps without help but I would suggest that you would be better off to buy a purpose made freezer as what would be required would probably cost as much and not look as nice. Hope this is of some help.
Sep 11, 2007 | McCall 4-4045 Commercial Refrigerator
Refrigerators Logo
383 people viewed this question
Top McCall Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
Are you a McCall Refrigerator Expert? Answer questions, earn points and help others
