Question about Canon PC-D340 Black and White Copier
When using the top loader to make copies, the copies come out with a line down the whole sheet?
    Sniper:
  • 86 Answers
I fixing is verry simple.Open the top cover of the copier(where you are putting the paper you want to copy).There should be two glasses(One big and one smaller wich is under the top loader).You need to clean the little glass from any dirt.Even a small peace of dirt can make a whole line on the paper,beacuse the scanner is not moving,but the paper is.So clean the little glass(wich is next to the big one and the line will be gona.replay if you need any futher help.Please vote if that was helpfull!!
Posted on Nov 09, 2010
How do you copy and paste one excel spreadsheet to another making sure the headers are lined up correctly.
right-click the sheet you want to copy, select "copy to", then either select the position within the current document, select annother document (needs to be open in the same excel instance) or select "new document". check the box "copy" to copy, leave unchecked to move.
Jan 01, 2016 | Microsoft Excel Computers & Internet
How do you make lines appear on an excel sheet?
I'm not sure what Version you're using, so I'll assume after Excel 2010.
At the top of the page, under the Home tab and directly under the Font window, there is an icon which looks like a window frame (dotted all around except on the bottom edge).
In your spreadsheet you have to select the area you want to work on. You can select a single cell to add lines to or the whole spreadsheet. Click on the icon I described above and a menu box will pop down. There many choices which allow you to select lines on all sides of your work. I prefer the one at the bottom which says 'More Borders'. With that window you select the edges you want lines on, the thickness/type of the line, or put an outline.
I think that's enough for now and I hope that gets you started.
Aug 12, 2014 | Microsoft Excel 2010
When i ask my NP 6050 copier to copy some sheets 5 copies, the sorter start to sort the first shet then in the next sheet it doesn't sort it he put it in the six shelf and the copier doesn't go down for...
Most likely, one of the finisher bins is broken and it is not lined up right. One of the bins ends are broken that ride on the spindale that moves the bins up or down. It is not a easy job to repair, the whole finisher needs to be taking apart and it is not a pretty site.... I've done it alot of times.. Good Luck
Oct 23, 2010 | Canon NP 6050 Copier
Black line down left side of sheet, if i'm copying a page that is and i can't get rid of it no matter what i try i've changed the drum and the toner and still get a line down the whole sheet
If the received fax's are ok and there is no line; and you only get the line when you make a copy....I assume the people you send to are also getting the black line down the page,?? then the problem is in the optics...favorite is some kind of dirt, glue, or corrector fluid on the glass that the original passes over when you make the copy.
Aug 20, 2010 | Office Equipment & Supplies
Black line appears on copies fed through automatic top loader
Clean the scan glass, there is lilely a spot or streak on the glass, use a good glass cleaner and soft cloth or paper towel.
Hope this is of some help.
Ed
Apr 21, 2009 | Konica Minolta DiALTA Di200 Copier
L7680 all in one W/big & wide dark vertical line
Open the document feeder and clean the scanner glass.
Feb 16, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Canon PC850
1.replace OPC drum
2.clean your Canon...
Jan 20, 2009 | Office Equipment & Supplies
How do I stop a black line appearing on the copy of an original document
Try this- Make sure the whole glass area of the copier is covered with white paper,
ie. lay the document face down, and any glass area you can still see- cover with sheets of blank white paper
Good luck
Nov 26, 2008 | HP Office Equipment & Supplies
Toner banding down the sheets
Need more info.... Is it pitch line accross the page the whole page or banding on the front or back side of the copies or is it black streaks down the page?
Sep 09, 2008 | Canon imageRUNNER 8500 Copier
Problem printing business cards
in your program adjust the pic your printing to fit in yours sumtimes u have to adjust your print in preview box your card u made down or up whole thing so it fits in nice for u sumtimes they just dont line up right i had same issue just move your project up with it ok to make it print in box cards u need ok
Mar 13, 2008 | HP PSC 1210 All-In-One InkJet Printer
Canon PC-D340 Black and White Copier Logo
74 people viewed this question
old marine
old marine
