Question about Zoom Audio Players & Recorders
All connections correct. Microphones connected and working. From Zoom MRs no sound either on input or output.
  • 2,069 Answers
The exact model for your Zoom Mrs unit is not indicated. so i will refer you to some websites where relevant troubleshooting and possible repair action is indicated. go here and here.
regards
Posted on Dec 01, 2010
  • Muzahura Frank Dec 01, 2010
    probably this manual too may be helpfull.. especially troubleshooting part.
Is a microphone an output device?
no, output devices are things like speakers or a monitor. They output sound or images, microphones are input devices because they put sound into the system not out of it.
Oct 01, 2013 | Computers & Internet
Mixer not working with Skype
Skype allows only one audio input at the time. You can set up the input device in the skype menu.
Try connecting all microphones to the Mackie and then connect the output from it to the line in or microphone input on the PC, then choose the input you connected it to in skype.
Jan 29, 2013 | Mackie Onyx 820i FireWire Recording Mixer
Audio-Technica freeway 200 Series VHF Wireless System - I had problems connecting the wireless system with a quarter inch to a xlr. The sound system made a very loud disturbance sound. What cable do I use...
XLR connectors are a two-wire plus ground system. Using a 1/4 inch to XLR adapter may not connect the wires correctly to your sound system input.
The A-T Freeway 200 Series has a 1/4" output jack. This would indicate a line level. A cable to connect the tip of the 1/4" jack to pin 2 of the XLR and the sleeve of the 1/4" jack to pins 1 and 3 of the XLR should work. The XLR should be plugged into a device that accepts line level.
Ideally, you should plug the 1/4" into a 1/4" or RCA jack that is designed for line levels.
Dec 14, 2010 | Audio Technica ATM33A Fixed Charge...
Sound disappears when channel is changed
try connect a rca cables to ensure sound , the tv has scart port or audio output rca? the digital input on receiver is non priority level, so every time you change chanell the receiver jumps to next Line input present. (receiver output security)
Jan 17, 2010 | Onkyo TX-DS474 Receiver
Where do I connect the microphone to a piano (roland) ? I've tried to the output mono and it came no sound from the piano..
You need an input. I don't know which model of piano you have so I can't tell you whether you have the correct jack or not. If you have an auxilliary input jack for instance the signal from the microphone will not be loud enough. Let me know if I can help you more and give me some more details and I will try to give you some more advice.
Nov 28, 2009 | Sony FV120 Microphone
The HDMI "input" ports damage output ports of connecting devices
i know this sounds stupid, but have you "toggled" or "played" with the HDMI cables? are they the same manufacturer? HDMI channel connections are very fickle. If just one connection is not exactly correct, they go to a limp, no go status. Since they run at such a minimal voltage, i can't see them "blowing" the outputs on the devices.however....if your cable has a serial type output for video only, I would connect the hdmi convertor to it and see if it works.
Jan 10, 2009 | Yamaha HTR-6140 Receiver
Microphones not working
check the mic input volume
Oct 25, 2008 | Audio Players & Recorders
Help fixing a sound problem with our receiver
You should be able to find all the instructions for these connections in your products owners manuals. The procedure should be straight forward. all the connections to the receiver should be input and output connections. The Receiver is basically just a switch box and amplifier with extras.You must make sure you know which input and output you are using for each of the components. You must have all the remote controls set-up to work with each other. The receiver is the master switch. From it you will control all input sources to the various output sources. Here is a possible set-up . Television output sound and video to the first input/ output section of the receiver. from here you can use the first audio/video output to your dvd/vcr input. This will allow you to record the television programs video and audio to your recording media.The audio/video output of the dvd/vcr will be connected to the second input /output of the receiver.With the second input you can view all the dvd/vcr materials on the television while listening to the sound through your receiver.The master output of the receiver's audio/video output is connected to the television input circuit. This will allow viewing and sound from all the units connected to the receiver. The receiver sound system will receive sound from all the input units as long as the connection are right and the input/out selections from the remotes controls are correct. That is the reason the owners manuals are so important for this purpose. They give these instructions and diagrams to show you the correct procedures for setting them up.They also give you information about customer support either with website help or a call in line for technical assistance.I hope this helps you with your problem.
Feb 09, 2008 | Audio Players & Recorders
Using a tube pre amp with my CA Azur 640A?
There are many answers to your questions but Ill have a go with the basics...
Audio connections should be matched.... its called Frequency impedance,.... to get a signal along wires or cables (or Fibre) the Impedance of the cables and wires must be matched to the device they are connected to transfer the signal along the cables without distortion...
Manufacturers provide many sockets on the input side of amplifiers and preamplifiers to allow the consumer to connect various devices of different impedance.
They label these inputs like CD, or Tuner, or PHONO etc etc,
That means if you have a CD player it must be plugged into the CD input socket then the impedance will be correct and the sound will transfer along the CD cables correctly, without distortion..same with the Phono input etc...
You will find on the sound output to the speakers terminals are also labelled 4-6ohm, or 8-10ohm, these are the impedance expected for the coil ratings of the speakers them selves and its important to get the correct speakers to the correct out put terminals...
In your case all you have to do is follow these simple rules and all will be well....you say you have a squeeze box well there probably isnt a port labelled squeeze box so you need to experiment and try out each input port for the squeeze box to see what input gives you the correct sound output...Watch the Phono inputs as these are very sensative to input sound levels and must be treated very carefully as they have a double stage of sound amplification and as such you need to have the volume right down when connecting up the Phono inputs then increase the volume carefully after the cable connections are completed.
If you follow these rules then all will be well,,,,there is no difference if the Pre amp or Power amp is valve or transistor or FET or has IC outputs to the speaker the same impedance rules apply..just treat it as a box with input and output terminals and all the impedance will be taken care of for you...if you read the lables...
You need to connect you signal source to the Preamp inputs the out put from the Preamp connects to the power amp input then the power amp output goes to the speakers. this is a basic configuration for sound systems, there are other variations but are outside this discussion.
Cheers From YUBEUT
Nov 12, 2007 | Cambridge Audio Azur 640A Amplifier
74 people viewed this question
Top Zoom Audio Players & Recorders Experts
Marvin
Marvin
Paul Bade
slaidleyw
Level 1 Expert
Are you a Zoom Audio Player and Recorder Expert? Answer questions, earn points and help others
