Question about Compaq Computers & Internet
I have a Compaq laptop here at the office, that we have had several local people look at, and no one has been able to fix. When you turn it on, within a few minutes it crashes. It is compaq series PP2140. It is the EvoN1000v. Can you give me any ideas on what to do?
  • 3 more comments
  • rhines Jun 17, 2008
    The latest on the compaq: Now this morning, it is giving the following message:
    1720-Smart Hard drive detects imminent failure, (Failing Attr:01)
    Do I need to replace the hard drive in this computer?
    As I mentioned earlier, Now it is giving the message 1720-Smart Hard Drive detects imminent failure, (Failing Attr:01).........
    DOES THIS MEAN I NEED A NEW HARD DRIVE? WHAT WOULD IT COST TO REPLACE THE HARD DRIVE IN THIS LAPTOP?
    PLEASE LET ME KNOW WHAT YOU THINK............
    Comment by rhines, posted on Jun 17, 2008
    I DON'T HAVE ANY COMPUTER EXPERIENCE AND I DON'T KNOW HOW TO SCAN THE LAPTOP, WHEN I CAN'T EVEN GET IT TO COME ON NOW. ALL I GET IS THE IMMINENT FAILURE MESSAGE.
  • rhines Jun 24, 2008
    Ekse, Thanks for your help. I don't think the video is necessary. I REALLY appreciate your time and knowledge with this issue, and your willingness to share it with me. Again, I sincerely appreciate your help.
    Genius:
  • 1,036 Answers
Hi.
Have a little read Here About how hard drives fail, and the causes.
This may be due to downloaded Malware, slowly eating the disk.
Try and get as much important files off the hard drive as it lets you, and treat these files as infected.
Once you have done this, reformat the drive, and load up with your windows recovery disk, and get some antivirus software on there.
If the hard drive is physically damaged, it should indicate this after formatting - Then it's destined for the bin.
Hope this helps you.
Posted on Jun 17, 2008
    Genius:
  • 3,422 Answers
HI,
I am sorry to say this but you'll have to replace the hard drive.This is the only solution to get it fixed.
If you need anymore help let me know.
Please don't forget to rate or accept the solution..
Goodluck..
    Genius:
  • 2,028 Answers
Replace the hard drive. Best Buy sells them and the price will vary.
  • Compaq Master
  • 13,433 Answers
Your hard drive seems to be smart bad, yes you need to replace the hard drive.
  • 2 more comments
  • Ekse Jun 17, 2008
    you can basicly replace the hard drive yourself, the only cost is a screwdriver and the harddrive it self.
  • Ekse Jun 17, 2008
    I just looked on ebay fast.
    heres a 20GB ibm hdd 2.5" which should fit your laptop
    Click here
    look around ebay for a cheap deal, or you can also get it from most computer shops out there. Repair shops.
    I assume your laptop has a IDE type hdd, it may also be SATA but as this is a older laptop its most likely IDE you can check it by removeing the harddrive cover from the bottom of the laptop and inspecting the harddrive.
  • Ekse Jun 17, 2008
    I can guide you throughout the replacement process if needed.
  • Ekse Jun 17, 2008
    If you are intrested I can create you a video of replaceing a laptop harddrive ofcourse opening the case and geting to the harddrive will be difrent in your compaq laptop.
    Sergeant:
    Champion:
  • 310 Answers
Due to virus it will happen pls scan the laptop....
    Master:
  • 638 Answers
Cmos battery or motherboard or powersupply or its ram or the tracks on the board are broken somewhere to create the problem .try to repair by inter changig one by one with good parts.if think its lenghty procedure call the technician he will solve it in minites.
Posted on Jun 16, 2008
  • hemant somaiya
    hemant somaiya Jun 16, 2008
    rate this solution if it helps you in anyway solving or knowing your problem how to fix it.
  • hemant somaiya
    tyr to rub thick golden lines on your ram with normal pencil rubber to clear the dust if any.it works propely many a times. but do not rub it harsly or it may damage your ram.reply me i am waiting for u.
    Master:
  • 555 Answers
Bad RAM.
  • 1 more comment
  • Matt Jurach
    Matt Jurach Jun 16, 2008
    Use Memtest86+ to run diagnostic tests on your memory. If it comes up with positive faults, you'll need to replace the bad RAM.
  • Matt Jurach
    This is very typical of faulty RAM. The system boots OK, since the RAM isn't fully utilized yet. Then, as more and more data gets written to RAM, it finally reaches the bad capacitors, and the system will freeze or restart (depending on how Windows is configured).
  • Matt Jurach
    Matt Jurach Jun 17, 2008
    First, don't listen to hemantraj. Rubbing an eraser on your RAM contacts is is not advised and it not helpful.
    Second, now that you have that S.M.A.R.T. error message, it is clear that the hard disk is failing and causing your computer to crash.
    Yes, it will have to be replaced.
Need boot disc for Compaq LTE 5250
Your laptop is asking for the the operating system's files.
As your laptop is not able to locate in on the harddisk so it is asking for the Disc.
You just need to start the laptop using the any OS Disc. You can try to install windows XP.
This disc is easily available in any local computer stores.
Incase if you have any trouble come back to Fixya.
Thank you
Aug 09, 2012 | Compaq LTE 5250 Notebook
Blank Screen??
Do you see anything on the screen when it powers on?
May 09, 2012 | Quantum Technology HP/Compaq HP G61-511WM...
My Compaq Presario CQ50-110US switches off and has burned up several power supply cords
If your computer is still within Warranty then contact the manufacture, if not then bring it to a local computer shop to get it looked into.
Mar 04, 2011 | HP Compaq Presario CQ50-110US Laptop
Laptop short circut
A short circuit could cause several different problems with your computer, most of which will require a new motherboard, processor, or both. Is it not powering on at all? If not, then your motherboard is most likely fried. I would suggest taking it to a local computer shop, or you could contact my business and arrange to send it in to be diagnosed and checked over. See MADHATTER COMPUTERS
Mar 22, 2010 | HP Compaq Presario CQ50-140US NoteBook
My computer keeps shutting off and it the battery
I recommend taking it to a place like Office Depot, or your local expert, Office Depot is doing free checkups for back to school. Once diagnosed you should take it to your local shop as it will likely be a cheaper and better fix. But from the "moving the cable" portion of your post, I think the power socket on the laptop has come dislodged at one or more connection. A local shop will dust out the PC and resolder the connection to the main board for a nominal fee compared to purchasing a new laptop.
Hope this helps,
Jim
Aug 05, 2009 | Computers & Internet
I lost all my rubber feet, wich makes my computer get very hot, cause its so close to the tabel
you can find little rubber pad things like that at a local hardware store. they usually have stick on the bottom so you can stick right on. or get a notebook fan pad, something like this. staples or office depot maybe target or wal mart too.
http://www.staples.com/office/supplies/p1_Targus-Notebook-Chill-Mat-trade_102485_Business_Supplies_10051_SEARCH
May 08, 2009 | Compaq Presario V4000 Notebook
Compal EL81 will not turn on
Compaq and HP have several models with this problem as we;; as not seeing the wireless adapter. Go to Compaq.com and see if your model is listed. Get on a live chat there. They are offering one time fixes for these machines even if out of warranty.
Jan 04, 2009 | Compal EL81 Notebook
2 NICs connecting to 2 different networks
you need to speak to your network administrator, for printers you get network enabled printers ( your network admin will assign an IP address and sharenames for your printers,
your network admin can create shared volumes on the network and can sort out internet routing that complies with the corporate domain.
sorry no easy way to do this
Oct 04, 2008 | Compaq Presario 5000 PC Desktop
Problem with my COMPAQ Presario 900Z Notebook
I already answered this question. Your operating system cd is the cd you need to follow my instructions.
If you MUST get the information out NOW, you can bring the laptop to any computer repair center or buy a laptop drive adapter at your local Office Depot or Staples, and then plug it into your pc via USB.
Oct 11, 2007 | Compaq Presario 900US Notebook
Computers & Internet Logo
108 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
