Indesit widl 126 stopped mid cycle, changed the brushes and it did one complete wash cycle. Now it stopped again mid cycle.
  • 8,197 Answers
Sounds like your transmition is bad on the washing machine. Replace the transmition. You will need to call a repair man out to fix
Posted on Dec 09, 2010
I have a silver Inesit WIDL 126 S washer dryer. Whenever the wash cycle completes, it then lets in some water from the inlet. Then stops. I tried draining it, it drains, then lets in water from the inlet,...
A device called a solenoid open and closes when activated by the control board (circuit controller). If debris collects inside of the chamber when it is open or closing, it can leak or simply shut down. This device will open upon command and allow water to enter or exit. It takes its orders from the command center and if it is damaged, plugged, or no longer capable of switiching on and off, it needs replacement.
Mar 12, 2014 | Indesit W 123 Front Load Washer
Washing machine not working
The lid switch/latch has failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 10, 2009 | Washing Machines
I do i stop the indesit widl 126 mid cycle?
Open the door - or press stop/cancel.
Jun 28, 2009 | Washing Machines
Indesit WIDL 106 wont start -ON/OFF-Door Led Flashes rapidly
It is a defectiv controller pcb. I think the eeprom on the controller pcb lost its program (happens often on Indesit machines).
The only solution I know is to change the controller pcb, - not a cheap solution.
I have the same problem with WIDL 106.
Dec 01, 2008 | Indesit W 123 Front Load Washer
Wiring for Indesit Widl 126
Tell me, is the machine compleatly dead or what is it doing?
Sep 10, 2008 | Indesit WA 115 Front Load Washer
Indesit widl 126-problem with the drum,moving back and forth to much and noisy.
It would seem that the bearings go on this model, which causes the inner drum to knock and bang against the outer during spin. If you continue to use the machine without replacing both sets of bearings, it will cause irreparable damage and the machine will need to be replaced.
Apr 27, 2008 | Indesit Washing Machines
Washing machine filling with water when switched off
Electric inlet valve doesn't close properly. You should get it replaced ASAP. It is a cheap part and quite easily replaceable. Turn off water to your machine until you fix this and keep it unplugged.
Apr 24, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Indesit widl 126 uk
Turn the control knob to a black dot leave the door open and press the on off button in and out quickly and look for a change in the lilght,, it should blink 3 times rapidly once it does ,, then the machine is reset and ready to use,,,
if you have any problems let me know im here for another hour..
Jan 25, 2008 | Indesit WA 115 Front Load Washer
Washing Machines Logo
113 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
