Question about Kenmore HE2 Plus Front Load Washer
Hi, our kenmore HE topload washer was making a loud noise then it stopped and not working now. What was the cause? Any solution? Is it worth fixing it? Your suggestion is greatly appreciated. Thanks
  • Kenmore Master
  • 1,902 Answers
Hello
Loud noise in a top load washer is usually caused by the bearings going bad however, it really depends on the model# what part# needs replacement. Worth fixing-depends on the age of your washer...you know if its more then 10yrs old and repair will cost you more then 50% of its original cost then you can think what you want to do. Please get back to me if you have any other questions.
Kevin
Posted on Nov 09, 2010
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
My Kenmore Elite HE3 Mod 11044832 202 started making LOUD knocking noises during final spin cycle, then started to smell like something burning. Whit placis shreds in the washer.
the plastic is the drum has dropped so its eating a way the plastic on the back of the drum so no not worth fixing the mould is an easy fix just soke a cloth with neat bleach and leave over night make sure you do a rines after woulds as you don't want bleach on your cloths ok
Oct 21, 2012 | Kenmore 44832 Front Load Washer
I have a kenmore front load washer model 970-c42072. I'm experiencing a loud noise in the drum on the spin cycle even when it is empty no matter what setting (slow normal fast) What would be the...
If you turn the inner wash drum by hand, what kind of noise do you hear? If it is a thumping kind of noise, it would mean that the spider support arms are broken. If the noise is a loud rumbling sound, similar to a jet engine when it is spinning, it would mean that you have a bearing seal failure and the bearings need to be replaced. Either problem is a big job to fix since the entire washer needs to be taken apart. Get a few estimates before deciding whether it is worth fixing. Sorry.
Sep 01, 2010 | Kenmore 44072 Front Load Washer
Makes a loud banging noise as if the load is underbalanced even through the load is balanced.
HI There
Try this even tho you said it's balanced. Sometimes it looks like but a slight unbalanced can cause this problem.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Let me know how this goes and thank you for writing to fix ya.
Best Regards Richard
Jan 07, 2010 | Kenmore Washing Machines
Kenmore Ultra Wash water supply started making loud noise while water is entering washer. If you turn on sink faucet at the same time the noise will stop.
It sounds like the solenoid valves which let in the water are not fully opening and causing chatter -- probably corroded . Turning the washer-water supply faucets down (to the left) will probably stop it, but the solenoid valves need to be checked.
The reason opening the sink faucet stops the noise is that it reduces the water pressure to the washer -- this is the same effect as turning the washer faucets down.
May 05, 2009 | Kenmore Dishwashers
My washer does not spin and makes loud noise
Hi!!! You have a bad motor coupler replace and you should be fine..
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series agitator problem
time to look for a new washer, this is a gearcase problem, or cluth. Not easy to fix , unless know how.
Nov 08, 2008 | Washing Machines
Maytag PAV2300AWW
hi there,
the humming is the motor trying to turn, which means it works. since you did not mention any error messages, it could just be a belt that slipped off the pulley. have you taken it apart yet?
it definitely worth fixing.
Sep 22, 2008 | Maytag PAV2300 Top Load Washer
Whirlpool washing machine won't spin after rinse cycle
there is a coupling between the motor and transmission that has cracked. with the crack in the coupling the transmission cant spin as fast as the motor causeing the loud noise. replace coupling to solve problem
Nov 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Loud noise when spinning
the only part that makes a loud noise is your bearings m8 other than that could be a bra wire stuck inbetween your drum and casing m8
Aug 11, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore HE2 Plus Front Load Washer Logo
56 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
