FixYa.com
Tags:
Epson Stylus Photo R1800 InkJet Printer
Problem using sublimation inks
posted by nikwak on Jun 16, 2008
Am using sublimation inks with the Epson Photo R1800 printer and the red light comes on above the Cyan and Matt Black cartridges although they are fitted up correctly and the ink is fitted. The error message says that they are empty and that Epson doesn't recognise the cartridges, even although they are the same as the others that it recognises. Any ideas what might be the problem?
Nick
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 13, 2008
Not Rated (0)
Eagle_tech
Rank:Wiz Wiz
Rating: 82%, 216 votes
For those having "flashing lights" , "end of service . . " or Ink Pads full"
go here for a little item that will save money and fix that
http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=+++Waste+Ink+Tank+for+Epson+
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 12, 2008
Not Rated (0)
brokethenfix
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Since you are using sublmation ink, the cartridges are probably aftermarket and may not meet Epson standards. Aftermarket chipped cartridges are notorious for failing to 'communicate' with Epson printers, even when the cartridge is brand new. Before taking the printer to a service center, you might try purchasing new cartridges of your ink from your reseller. If that fixes the problem then your fight is with the ink reseller, not Epson. If it doesn't fix the problem and your printer is still under warranty, take it to an authorized service center, and remember, using non-Epson ink does NOT void the waranty.
Can you Help with these Printers problems?
EPSON 1800 PROBLEMS WITH NEW...
Downloaded new driver 6.0 for... Answer This...
paper wont feed
trash can symbol comes on and... Answer This...
Mac OS 10.5 Leopard
Since upgrading to... Answer This...
How are you doing it?
I'm not sure I understand where... Answer This...
Failure of an Epson Stylus R...
From Lowerhouse to CompuG Re... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
