It used to print instantly, and fast. now it takes minutes to start printing, then it prints partially and draggingly little by little until such time it completes the print out. It really eats up my time, especially when I am printing pages and pages of report. I uninstalled and reinstalled the driver but the problem still lingers.
    President:
  • 1,216 Answers
.Make sure settings match these
If this does not work uninstall and then re-install printer.
further if this also does not help, do a firmware update.
Regards.
Posted on Nov 09, 2010
The printer takes a long time to print.
Buy a faster printer.
And, no, I'm not being a smart-aleck
HP rates this printer at up to 32 pages per minute -- in fast draft mode black ink only... But even their ratings show it takes over a minute per page when doing quality printing in color.
And those speed ratings are all "after first page" -- ALL printers take longer for the first page due to the time it takes for the computer to set up the page and process the information.
As the specs suggest, you can get faster printing in black-only instead of color and by choosing fast draft mode instead of quality or normal mode.
There is very little that could be wrong with the printer that would make it print slower than usual -- generally any problem would make it not print at all or cause it to print incorrectly. Generally speaking whatever speed you see is simply the speed of the printer itself based on the settings you have selected, the software you are using, and the speed of your computer.
You can refer to the information on the HP website. It is just possible that replacing the printer driver MIGHT help but other than that there simply isn't much you can do about the speed of this (or any) printer unless you want to choose a lower quality print setting.
HP Photosmart C5250 All in One Printer Product Information
Mar 08, 2014 | HEWLETT-PACKARD photosmart C5250...
HP Officejet 5610 All-In-One InkJet Printer - printing any kind of document, from many formats (docs, pdf, photos) takes more than 15 minutes for one page to print. Tried restarting computer, printer,...
When you click to print something, you will get what's called the Print Dialogue box. Before clicking "OK", click the Properties button.26849353-6c28-4abb-ab9c-b5e445a1b08b.jpgThis will take you to a screen with some tabs. Click on the Paper/Quality tab. Somewhere in that window you will see some options for "Print Quality".
By default, it is probably set to "Normal". That's the middle setting. To save ink, you can set it to Fast Normal (better for ink saving) or Fast Draft (best for ink saving). This means the printer will use less ink to print the page. The final copy will look a little lighter but certainly still readable.
This option "fast draft" will print very fast and also save your ink.
Oct 16, 2013 | HP Officejet 5610 All-In-One InkJet...
I have a 2410 HP printer and it prints very very very slow. Can you help me? Email address pretty111comcast.net
I have the exact same model of printer, I find that it prints faster if you go into printing preferences and change the print quality to fast draft or fast normal. You can also set the printer directly by pressingcopy twice then press3 for copy quality, then select 3 for fast.
Doing both should produce faster printing for your documents. (NOTE : This will not suggested if you are printiing items that need to have crisp clean printing as the faster it prints the less detailed the printing is.)
Jul 22, 2012 | HP PSC 2410 All-In-One InkJet Printer
I finally cleared a paper jam, and now my printer is trying to reprint all the documents I sent to print while there was a jam. I do not want these to print since it will waste a ton of paper and ink. How...
There should be a little print queue icon down by the clock.  Double-click on this to open the print queue program.  From there you can remove jobs from the queue.  NOTE:  It can take a minute or two for jobs to remove themselves.  It's not instant.
Please rate me if you found this helpful.  Thanks.
Mar 07, 2010 | Dell P1500 Laser Printer
Unable to print to canon IR7200
More than likely their is a problem with the file or that it is too large to process and has gotten stuck in the que on the copier. Go into printer set up and find restart server or clear server - it's ussually at the back end of all the settings. You want to clear the server and restart it. Then try printing a few pages of the file to see if their is an issue with it. If that prints then print half of the file, if it's has a lot of graphics pick a smaller chunk. You can also restart the server through the copiers internal web page - to get to that type the copiers ip address into internet explorer and it should bring it up.
Dec 26, 2009 | Canon Office Equipment & Supplies
Streaks on copy
Try these steps first:
1. Check ink level.
2. Nozzle Check Pattern
  1. Load A4- or letter-size plain paper in the Auto Sheet Feeder (ASF) or cassette.
  2. Press the <Feed Switch> button to select the appropriate paper source.
  3. Press <Menu> repeatedly until [MAINTENANCE] appears.
  4. Press <OK>.
    The machine prints a nozzle check pattern.
  5. Confirm the pattern is not broken, missing, or a specific color is not printed.
3. Print Head Cleaning / Head Refreshing If the printed Nozzle Check Pattern is broken, missing, or a specific color is not printed, clean the print head.
  1. Press the <Menu> button on the printers operation panel repeatedly until [MAINTENANCE] appears in the LCD.
  2. Press the left [<] or right [>] arrow buttons to select the cleaning setting you want. Select [HEAD CLEANING] or [HEAD REFRESHING] for deep print head cleaning.
    Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary.
  3. Press the <OK> button.
  4. Print a Nozzle Check Pattern and perform at least two Head Refreshings if the pattern is not correct.
You can also try using a higher quality print settings as follows:
Change the Print Quality Settings (Windows) The Quality setting controls how finely ink droplets are placed on the printed page. Depending on the type of paper being used a higher Print Quality setting does not always insure a better print. Print speed will decrease as the Print Quality setting is increased. Follow the instructions below to change the print quality settings in the Canon printer driver for the Windows operating system through a printing application.
  1. Click 'Properties' in the Print dialog box.
    Note: Depending on the Application software, 'Properties' may be displayed as 'Preferences'.
  2. Set the desired print quality in the 'Print Quality' section.
  3. Select 'High', 'Standard', or 'Draft / Fast'.
To set more detailed print quality settings, follow this procedure:
  1. Select 'Custom' and click 'Set'.
  2. In the Set Print Quality dialog drag the slide bar from 'Fast' to 'Fine' to select the print quality.
    Note: There are five options in 'Quality'. However, selectable options are limited depending on the media type.
  3. Select 'Auto', 'Dither', or 'Diffusion' from the 'Halftoning' section.
If the above steps do not solve your problem, it may be a time to purchase a new printhead.
Oct 09, 2009 | Canon PIXMA MP750 All-In-One InkJet...
SLOW, SLOW PRINTING
try saving the things you want to print as a pdf file, then print them from there
Jun 01, 2009 | HP DeskJet 3550 InkJet Printer
Phaser 850N prints commands, not proper file
Could be defective memory module. Try taking the RAM back out. You can get replacement RAM from Crucial. You can make your N into a DP by switching the NVRAM chip (or the complete main board).
Jan 05, 2009 | Xerox Tektronix Phaser 850N Laser Printer
MFC-3240C
The printer may not be scratching your printout but you may have a clogged printhead. A clogged printhead will constantly miss a spot creating an effect of a scratch printout. Please run an all inks printhead cleaning routine (2 or 3 times) and create a test page. Best Regards
Aug 20, 2007 | Brother MFC-3240C All-In-One InkJet...
55 people viewed this question
k24674
jasbo
jasbo
