Question about Intermec EasyCoder® PF4i Label Printer
Head lifted - Intermec EasyCoder® PF4i Label Printer
Solution to head lift error problem on my Fargo printer
You don't mention which printer model you have, but we mostly see that error on old DTC5xx printers. It is usually caused when a rubber o-ring within the printer has failed (broken), and the head-lift motor no longer has the necessary connection to the head-lift mechanism.
Jul 20, 2017 | Fargo Office Equipment & Supplies
Fargo dtc 550 head voltage error
Fargo DTC550 Head Lift Error - YouTube
? 4:46
https://www.youtube.com/watch?v=1MCO3wHmLgE
Jan 8, 2015 - Uploaded by Alfonso Terrazas L
Fargo DTC550. Head Lift Error. Este error se origina porque el O-Ring que hace girar el engrane que ...
Mar 22, 2017 | Fargo Office Equipment & Supplies
The power head has a device to hold the power head together what does it look like?
Shark NAVIGATOR LIFT-AWAY PRO NV355 Owner's Manual
www.manualslib.com/manual/.../Shark-Navigator-Lift-Away-Pro-Nv355...NAVIGATOR LIFT-AWAY PRO NV355 Vacuum Cleaner pdf manual download. ...Shark ® Getting Started Navigator ™ Mode 1: Upright Vac Lift-Away ® Mode 2: ...Important Safety Instructions - ‎Table Of Contents - ‎Ordering Parts - ‎Maintenance
Sep 22, 2015 | Shark Navigator Lift-Away Professional...
How to change the pin head
I assume your asking how to change the "Print head" power off the machine, remove the ribbion and plastic mask (lifts up) you will see 2 gold phillips head screws. unscrew them both and lift up the print head. push in new print head and reverse the directions you removed.
Jul 24, 2014 | OKI MICROLINE 5521 Matrix Printer
Old Kitchen Aid classic (25+), new KA-TH beater bar and suddenly the bowl won't stay mounted. Is it the beater bar, the mounting or something else?
You may need to adjust the head height if the new flat paddle is a bit bigger than the original. When you have the head lifted up with beater out of the bowl you will see a single slotted screw where the head hinges on the pedestal. Anti clockwise to lift the head up, clockwise to drop the head lower. Paddle should just clear the bowl with head down & motor running.
Oct 25, 2013 | KitchenAid K45SS Classic Stand Mixer
The printer shows head lift error ...so ..how can I solve this problem ?
I had the same problem with my fargo dtc 550.
I changed the "O" Ring rubber attached to the printhead and that solved the problem. No more head lift errors.
Jul 02, 2009 | Fargo DTC550 Thermal Card Printer
Error/ Head Lift Error
If you replaced the o-ring on the headlift assembly and that did not solve the problem, most likely you may have a sensor out that controls the position of the head lift.
Dec 12, 2008 | Fargo DTC550 Thermal Card Printer
Replacing print head
Lift the top cover when the printer head stops in the centre push the printer head to the right about 5mm. you should then see the tab you need to push to the back of the printer to release the printer head once you push this allow the head return to the centre and then you will be able to lift the printer head out
Oct 10, 2008 | Canon i80 InkJet Printer
Intermec EasyCoder® PF4i Label Printer Logo
114 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
donjackson
Level 1 Expert
Nick
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
