Question about Universal Kreepy Krauly In-Ground Pool Cleaner
Hose sucks air on a bend. - Universal Kreepy Krauly In-Ground Pool Cleaner
  • 640 Answers
You can buy and replace leaky sections of hose for these pool cleaners. Go back to the place where you bought the cleaner or look online for an authorized dealer of Kreepy Krauly cleaners. You can buy the section of hose and install it for very little money and it should completely correct your problem. Also, make sure that you are not storing your cleaner with the hose coiled. That will cause these cracks. Here is a copy of the users manual for these cleaners. If you go to the end, there is a part list with model numbers. You can find the section you need and replace it.
http://www.backyardcitypools.com/images/pentair/kreepy_krauly_manual1.pdf
Posted on Mar 23, 2011
Vacume does not suck from the brush but it sucks from the hose
take your brush out and take a coat hanger bend it straight then push it through the dust channel until it comes out where hose is. you probably just have an obstruction between those two places
Feb 13, 2013 | Kenmore 31913 Progressive Direct Drive...
There is a motor-looking device under the radiator that is sucking air, but, I can't find anything it should hook to. What is this thing and what should the 5/8 to 3/4 inch hose hook to?
Hello, I have a 2001 also and had to replace that "motor looking device". It is the Air Pump, which is part of the smog control system. The hose that you speak of should be about 8 to 9 inches long and have a 90 degree bend in it, and then a Y hooked to it with two more hoses and then one way valves that hook up to two tubes that are on the front of each exhaust manifold. It will come as a whole assembly that includes from the 90 degree, Y, hoses, one way valves, and two more bends, It is available from the dealer only, It is not an item that I found could be gotten from Autozone or others. You might be able to go to a junk yard and salvage one. Hope this helps.
Jun 21, 2012 | 2001 Chevrolet Blazer
When I step on the head so that vaccum enguages it stops sucking. You no longer hear air being sucked through the handle as well, the head does not **** down to the floor. When you lock the handle in the...
near the bottom of the vacume where the hose bends down to the floor sweeper, check to make sure there is no blockage. this is the most common problem with vacume suction. you can use a wire coat hanger to help loosen the dirt and debris from the line and it is sometimes easier to clean properly if you remove the bottom plate ( like you would if you were changing the belt ). also while you are getting dirty and having fun, this is a good time to clean the air filter, ( tap it out good or/and use a brush or air compressor to clear and clean ).
c...
Dec 31, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
I take hose to my pool suction. I then have my psi on pool pump going at 12 psi. the cleaner works. then it loses power/psi. I wait to see if it will still work . Then it stops working and does not...
It sounds like your loosing prime. I would chesk all the hoses for leaks. When you start the pump keep the hoses under water and see if the system works. If it does then pull the hoses one by on up out of the water bending them as you go to see if you can hear them sucking air. Good luck.
Aug 16, 2010 | Zodiac Pacer Pool Cleaner
My vaccum is not sucking up barely anything and the cup is empty
In spite of it's advertising, it may actually be a clogged air passage. Remove the debris cup and reach into the air passage with a hooked wire to pick out any material. Do the same from the under side of the machine. The usual point of clog is where the upright and base components bend--there is a flexible hose there that tends to catch things large or sharp. Make sure the air exit filter is not plugged. Good luck!
Aug 11, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Brush spins, I have washed the filter, but do not have much suction.
I want you to do 2 things, First run a small broom handle threw the hose. next you need to clean the small hose under the sweeper. its a flex hose that bends when the vacuum bends back and forth, i use hemostates and a coat hanger. this clogs up and slows sucking power.
Sep 02, 2009 | Sharper Image Dyson Slim DC18 All Floors...
Does the hose come off the dyson? I accidently sucked up a rag now it is stuck in the hose
hi. i can help you. the best way to remove the rag is to straighten out a wire coat hanger and put a small bend at the end to act as a little hook. shove it into the hose, snag the rag and pull it out.
Jun 23, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC14 won't **** from hose but works fine otherwise
There is probably a clog in the U-bend on the back of the unit at the bottom. Removed with a twist of a plastic screw by a coin or screw driver. If not in the U-bend check in the hose/wand.
Nov 28, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Universal Kreepy Krauly  In-Ground Pool Cleaner Logo
125 people viewed this question
Top Universal Pool & Spa Experts
Bill Jordan
Are you an Universal Pool and Spa Expert? Answer questions, earn points and help others
