Question about Bose Audio Players & Recorders
The wire to the plug has a bad connection. (must wiggle to sometimes get sound.
  • Bose Master
  • 5,259 Answers
See my tip on dealing with dodgy plugs/cables on headphones. To find it just click Grubhead.
Posted on Nov 09, 2010
How do I Turn off the passenger airbag light
This is a common problem with nearly all makes of cars and is usually down to bad connections under the seat caused by sliding the seat back and forth. Sometimes just wiggling the wires and connector sorts it, sometimes you have to disconnect and re-connect the wires and sometimes a new connector is required. Generally, though, the light will only be reset with the aid of an OBD reader.
Nov 25, 2015 | 2008 Dodge Caliber
Buell blast doesn't always start after running
Yes, it sounds like there is a lose wire or connection. If you can get to these wires and connections, check them for bad connections, loose connections, etc on the switches. Sometimes the contacts on the switches where the wires attach become corroded, or the terminals on the wires become corroded or loosen up, making poor contact.
May 15, 2014 | 2007 Buell Blast
I have a 1998 peter built 3126 series my tachometer stopped working i bought a new one and it still is not working properlly ive changed two sensors on the transmission and it only works when u rev it up
sounds like a loose connection behind the dash. Sounds like power is not flowing through the circuit evenly. Usually a bad ground wire, or bad connection on the power wire. I'd look at all connections and wiggle all the wires and the connections on the tranny as well.
Nov 11, 2013 | Cars & Trucks
Truck cuts off while driving. I replaced the fuel pump a few months ago. if i wiggle the wire harness it will restart
I have seen this and took me a long time to figure it out. The problem I have found was inside the plug on the wiring harness to the fuel pump. You can't see it unless you take the plug apart and it may be corroded inside. I don't know if this is your problem but check to see if you have power there and wiggle the wiring to see if it cuts out. Hope this helps.
Jun 12, 2011 | 2001 Chevrolet Silverado 1500
There seems to be something wrong with the lead input socket on my guitar...it only seems to work (i.e. get a sound through to the amp) when the jack is wiggled around in the socket on the guitar and even...
Yeah, sounds like a bad connection. If you are handy, you can take the jack out yourself and determine if it is a loose wire or solder connection. If everything looks fine then you should squeeze the connections togather inside the jack itself. Sometimes it just gets pushed apart and does not hit around the male end secure enough.
Nov 30, 2010 | Fender Squier Standard Telecaster Electric...
SOMETIMES MY RADIO WORKS THEN SOMETIMES IT DONT NO SOUND NO NOTHING THEN SOMETIMES I GET IN IT IT WILL WORK
you have a loose radio connection; remove your radio from the dash then turn it on and, wiggle the wires in the back of the radio until it goes on or, off then fix the loose connection
Jul 15, 2010 | 1998 Chevrolet Cavalier
Escort indicators work intermitantly
there is a bad connection in your wireing take off the stearing consol and the switch is under there as its an old car now you may need a new switch try swilling it with switch cleaner and look at the wireing it wont take much of a brake in this to stop it working
Oct 20, 2009 | 1989 Ford Escort
1998 caravan shows sevice engine soon light is always on
mcdevito75 here, Sounds like either a bad relay or a bad connection at the relay plug, wiggle the connector wires at the relay se if it helps, if so have your shop rig another plug, if not buy a new relay.
Jun 16, 2009 | 1998 Dodge Caravan
Losing sound in my Shure ear buds, they are one year old.
the wire breaks after a while in ear buds ,and head phones due to the constant flexing,and moving.they probably need to be remade.by cutting out the bad part of the wire(usually close to the fitting)You can usually wiggle the wire and find where the breaks are that way.it can be a real pain re soldering ear buds.also check the plug end by wiggling the wire there.
Mar 16, 2009 | Shure SCL3 Headphones
358 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
