Question about Pioneer VSX-919AH-K A/V Receiver
I just received the LG PK950 and have a Pioneer VSX-919 receiver. I have my digital cable, PS3 and Xbox 360 hooked up to the Pioneer and then the Pioneer hooked up to the TV. Both the PS3 and Digital Cable Box work flawlessly but the Xbox 360 for some reason does not produce video, only audio. I had a Panasonic S1 before the LG and never had a problem. I did not change ANYTHING when it comes to how it is all hooked up. I just unplugged the single HDMI cord running from the receiver to the S1 and plugged it into the LG. The weird thing is, when I plug the Xbox 460 directly into the LG via HDMI it works fine. Someone please help, I'm about to lose my mind. And yes, I have tried switching around the HDMI cables and ports. Thanks.
To correct this problem you have to go to the display settings on your xbox and turn off display detect.
Posted on Dec 26, 2010
I want to connect my VSX-26TX receiver with my Asus A53S lap top.
You should be able to get a cable that will allow you to hook up the headphone output of your laptop to an rca input on your receiver.
Dec 24, 2012 | Pioneer VSX-26TX Receiver
Hi I just bought a pioneer vsx-42 cable box and was wondering how to hook my Xbox 360 up through there so I can play on the tv, I have an hdmi cord And will be playing on a Samsung smart tv
Hook your X Box into the Receiver HDMI input with your HDMI cable and another HDMI cable from the HDMI out on the receiver to the HDMI input on your TV.
Aug 02, 2012 | Audio Players & Recorders
I am trying to hook my playstation 3 up to the pioneer vsx 510 using a digital optic cable. I have everything set on the playstation but still cannot get any sound. I am not that familiar with the reciever...
Be sure youve selected the optical output option on your ps3 (in sound options on your XMB) ... now on the back on the amp under the optical input it says CD. Select CD input using the toggle know or your remote and then on the front of the amp press the button labeled"signal select"(in between DSP select
Jul 10, 2010 | Pioneer VSX-D510 Receiver
Can I use my Pioneer VSX-D412 receiver to hook up my surround system to my new Samsung HDTV?
Yes, both receiver and tv have optical/digital connectors, or alternatively, the S-video connector. The Pioneer will decode the compressed 5.1 signal coming from the tv unit.
Feb 15, 2010 | Pioneer VSX-D412 Receiver
Pioneer vsx-519 no sound from center and surround
Make sure that the sound field/programme you have selected is dolby digital not stereo.(On the amp)
You also need to check on the display that is says DIGITAL not ANOLOUGE, as only a digital input, Optical fibre cable, HDMI, COAX will be a digital signal.
If you are using red and white rca connectors, it is not going to work, as this is an Anolouge signal.
Sep 08, 2009 | Pioneer VSX-818V-K Receiver
Pioneer VSX-D608 Optical connection
The manual states that the default association of each digital input in as follows:
  • Optical 1: CD
  • Optical 2: MD
  • Optical 3: TV
  • Coax: DVD
Use the "Signal select" button to set the receiver to use a digital input, and the Dolby/DTS button (above "Signal select") to enable decoding.
As samz11 stated above, a remote is required to alter the digital input mapping.
Sep 19, 2008 | Pioneer VSX-D608 Receiver
Component to HDMI
why dont u connect the xbox directly to the tv via HDMI cable? the output will be fantastic.The component cables just cannot give a better resolution than HDMI.
As for connections,i am not in favour of component and HDMI together.
May 18, 2008 | Pioneer VSX-92TXH Receiver
Pioneer receiver VSX-D411
Yes techtod you are right you do have to tell the receiver what you want it to do usually on the front panel you can access set up menu and go into input set up This is an example Say you plugged the dvd into optical one or coax 1 you must go to the input that says dvd click down till you highlight dig input and then select optical 1 or coax 1 there can be as many as 8 digital inputs so just check wich one you plugged it into and then tell the amp then you should be back to watching your digital movies
Mar 21, 2008 | Pioneer VSX-D411 Receiver
No sound
you have the co-axial and optical inputs both set to a specific input? ie. For my xbox 360, I use optical. so I set my optical to DVD, and then I have to set the receiver to DVD to get the sound.
Nov 22, 2007 | Pioneer VSX-D510 Receiver
Connections
Follow these; 1-Get an Xbox 360 HD cable (see the picture1 below) 2-Connect the red and white plugs to one of your amplifier's empty inputs. 3-Connect the VGA plug to the LCD directly By following these instructions you'll be able to get surround sound from your amplifier as long as you keep it turned on. 2nd solution could be that; (if you have some other equipments connected to the amplifier such as dvd, cd, etc.) 1-Get the above-mentioned HD Cable and get a VGA to S-Video adapter (a small piece of equipment) 2-Do the same thing as mentioned in the 2nd above 3-This time, you're gonna select a VIDEO INPUT (video1, video2,etc.) on your amplifier's input selector. Affix the VGA plug of your HD cable to the S-Video adapter, and connect it to an empty S-Video input slot at the back side of the amp. 4-Get a simple RCA cable or a digital coax cable (up to you) to make a connection between the "monitor out" slot of the amp. and the "video in" slot of the LCD. It's important that which video input you've selected in your amp. to make this connection. For instance, if you choose "VIDEO 1", you will have to connect all plugs (Audio and Video) via VIDEO 1 slots. Good luck
Apr 17, 2007 | Pioneer VSX-D510 Receiver
Pioneer VSX-919AH-K A/V Receiver Logo
318 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
