Question about ASUS V8420/Deluxe (128 MB) Graphic Card
Is there a driver for V8420 Delux Graphic Card for windows 7 ?
  • ASUS Master
  • 19,396 Answers
No. Drivers for this card were released up to XP.
This card is built on an NVidia GeForce 8 series chip. You can try the latest driver pack for GEForce 8, I don't know if it will work.
Here link.
Regards.
Posted on Nov 09, 2010
9950 driver download for Windows 7 please.
Download the program (freeware) to find driver at http://driveridentifier.com/.Instal that program and let it to scan your pc and finally find the appropriate driver.
Dec 12, 2013 | ATI RADEON 9550 Graphic Card
I installed windows 7 but my vga(via p4m266a) doesn't support how can i fix it
Hello if it is this mainboard:
http://www.asrock.com/mb/VIA/M266A/?cat=Download
It`s to old to run windows 7 with the onboard graphic.
And the driver does not supports windows 7.
You can add a new graphic card in the agp 4X
socket on the mainboard.
Just make sure the graphic card driver supports windows 7.
Good luck
Dec 05, 2012 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
EAX300SE-X/TD/128M Windows 7 driver!?
A very common problem, sadly there is no solution expect the maker of the card to issue a driver for the older card to operate on the newer 7/10 system. Bottom line they want you to buy the new card
May 27, 2012 | ASUS Eax300se-Xtd 128m RADEON X300se Pci...
Nvidia 7400 card dowsnt work with windows 7
Here is the link from where you can download NVIDIA 7400 driver for windows 7.
http://www.nvidia.com/object/geforce_notebook_winvista_win7_179.48_beta.html
Open the above link and Click on "Supported products", you will find your card listed there.
Download the file and installed it.Your graphic will work fine with Windows 7.
Your Notebook doesn't support windows 7 according to Sony.But if Windows 7 work fine with your Notebook then it's good.The graphic card which comes with your laptop is support by Windows 7 and the driver for that chipset is available and there should not be any problem with your graphic card.
Happy New year..
Dec 31, 2009 | Sony VAIO VGN-SZ430N/B Notebook
Where can I get a new fan?
Find to the nearest computer hardware shop Zalman VF700-AlCu vga VF700-AlCu cooler, buy it and mount it.
Oct 13, 2009 | ASUS V8420/TD Graphic Card
Mafia
Hi!
Well, I think this depends on the nature of the Game you playing. I suggest that you open any window or little application like notepad before you start the game, then try what you want to!
I hope it works!
Oct 31, 2008 | ASUS V8420/Deluxe (128 MB) Graphic Card
Defect ASUS V8420 ?
I don't understand, please explain more:
0) What kind of a monitor is it ?
1) If the monitor is NOT plugged into a working video card,
it should blank out or display some sort of a
"NO SYNC" or "NO SIGNAL" or "UNPLUGGED" warning.
The power light may also flash or show a different color.
2) If the monitor is plugged into a working video card,
it should wake up from the inactive power-saving mode
and display the desktop.
3) If the video card is malfunctioning, or if the windows
video settings are set outside of the monitor's sync limits,
the monitor may turn off or display a warning message,
such as:
No sync, Out of range ... etc.
4) The repair situation (3), reboot windows into
safe mode:
a) Press Hardware Reset
b) After the power-on self-test (POST) and memory check
press and hold the F8 Key
c) Select Safe mode
d) Login to windows at low resolution
e) Right-click on the desktop, chose:
Properties -> Settings -> Set the correct resolution, apply
Click advanced -> monitor -> set the correct refresh rate.
Reboot normally
Hope this helps
Martin
PS, some monitors have dual inputs: VGA or DVI
make sure the correct input is selected, depending
on your cable (VGA is a 15 pin "D" connector,
DVI is a larger connector with many more FLAT pins)
Also some video cards have multiple outputs, which are
activated only if a correct monitor is attached BEFORE
reset.
Apr 22, 2008 | ASUS V8420/TD Graphic Card
ASUS V8420/Deluxe (128 MB) Graphic Card Logo
264 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
