Question about CDA Microwave Ovens
When microwaving with my cad cm4ss microwave. after a minute or two it switches off and shows E01 It does not happen every time. Any idea what the fault may be
    Brigadier General:
  • 8,909 Answers
Error 01 is usually magnetron failure. I suspect the connections to the magnetron may be poor.
Watch out as lethal voltages are at that point!
Posted on Nov 09, 2010
Sanyo, super showerwave, microwave has quit working. Clock counts down, lights all come on, but no microwaves nor does the plate spin...any ideas?
Hi William,
The secondary interlock switch is bad. You need an ohm meter to verify that the switch is not 'closing' electrically. Opening the door when the microwave is running is the primary cause of this switch's failure. The secondary cause of this failure is from constantly running the unit for extended periods of time, usually more than ten minutes or more. Be careful..
Oct 22, 2013 | Microwave Ovens
I have the West Bend #84386 and every time I push the power button, E01 shows up in the display window.
It is showing Some sort of Error like Fuse Blown or element Damaged or Voltage Problems etc
please Rate my answer and Support me
Nov 21, 2010 | Microwave Ovens
I have a Maytag OTR Microwave oven that doesn't work. After I close the door and set the time and start, I see the time countdown, but I don't see the microwave starting. I can get the microwave to start,...
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
See our file on door switches here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Sep 30, 2010 | Maytag Appliances Over-the-Range Microwave...
My Sanyo EM-D975 starts and then stops after 3 seconds with E01 on the display, i pressume this means error 1, can anyone help
I would first suggest that you check the door switches and switch holders. See this file.
If it is equipped with an inverter, that may be the trouble.
You can locate Sanyo owner's manuals, part distributors and authorized servicers here.
Good luck.
Jan 30, 2010 | Sanyo Microwave Microwave Oven
Cda cm4ss microwave. The microwave side of the unit has stopped working. Its making all the right noises,the plate is rotating, the light is on, and the fan is running, but the food is not getting heated
sounds like the mag has quit . this is sometimes caused by the hi voltage rectifier and cap . or the mag it self . it will require a service tec to dor this type of repair . its not safe for you to get in it . as there is hi voltag in the control panel .. **** . repari can run form about 45.oo to 200.00 . if older you may want to replace. and if minor fix it .. ****
Jan 10, 2010 | Microwave Ovens
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
Sansui Microwave: Nothing Happens when you hit start
there is a safty door switch,if that switch is not making proper contact this thing happens.open the microwave look for safty switch and replace it or if you know how to open it then clean it and it should work
Aug 07, 2009 | Microwave Ovens
Microwave still continues after cooking time is ended
It is the fan. Im guessing it only happens on combination cook and not when you are only using the microwave setting. It happens because the oven is hot and it helps to cool it quicker. It is normal. The microwaves are not working and neither is the oven-just the fan.
Mar 31, 2009 | Oster 0.7 Cu. Ft. Compact Microwave
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
163 people viewed this question
Top CDA Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
acmservice
Are you a CDA Microwave Oven Expert? Answer questions, earn points and help others
