Question about Dryers
Kenmore Oasis dryer model # 110.77086600 A little history... I was away for three weeks in September. When I came back, I noticed the blower sounded different, less strong maybe. The dryer still worked fine, so I didn't think any more of it. Well, it did quit working (excessive dry times) a few weeks later. I took everything apart and did not find anything significant electrically or blockage wise. A few days ago I took it apart again to make sure I didn't miss anything and found a bit of lint in the screen area, but nothing I thought would make a difference. Cleaning this area out did help a bit, though. I tinkered a little more with the dryer a bit more and did find a few points of interest. 1. The flame is being cut off by the cutoff sensors by the flame, I think because of lack of airflow. If I set the sensors to the side, the dryer functions fine. 2. In diagnostic mode, the blower blows much harder than it does in any of the cycles. With the vent hose off, the sound of the air exiting the machine is dramatically different and the volume of air is about twice as much in diagnostic mode as in a regular cycle. 3. I was trying to make the dryer have fault codes on purpose, to test the control modules. I unplugged the com cable from the two control modules and started the dryer. After a couple of seconds the f40 code (lack of communication between the modules) came up and the dryer stopped. Good. I plugged that back and unplugged the blower motor from the blower module expecting an f44 code. When I started the dryer, the drum turned, there was no blower (expected), but there was no fault code either. Does that mean anything? Thanks again for your help! Trent
SOURCE: my dryer is not doing anything
Thank you for the useful tip, I also had the same problem and the thermal fuse was the problem...
Posted on Jan 21, 2007
jsrock516
  • 5911 Answers
SOURCE: Kenmore electric dryer won't start. #63841
Normally when a dryer starts to exhibit longer dry times, then suddenly stop working, it is an indication that the Thermal Cut-Out has blown. The TCO acts as a fuse for the heating element circuits. When an overheat condition occurs, normally the hi-limit thermostat will open to shut off the heating element. This is how the dryer regualtes its heat. However, if the hi-limit thermostat malfunctions, the TCO will blow, It is not resettable, and has to be replaced. This also means that the hi-limit thermostat could be suspect and it should also be replaced at the same time. Normally, when you go to replace one or the other they are sold as a set. This still does not rule out the possibility of a bad heating element, either.
However, you said the dryer additionally does not start. With a blown TCO or heating element the dryer will still run, but will not heat. I'll get back to this in a minute...
Now...if your dryer has been having problems drying, the first thing you need to check is the ventilation ducting to ensure that it is not kinked or clogged. Poor air flow is the number one cause of dryer failures. Not to mention it can cause fires due to lint backing up inside the dryer. This could be the "electrical" smell you've experienced. If trapped lint is ending up on the heating element it will smolder and burn. I recommend the ducting be cleaned thoroughly about once per season. That's 4 times per year. If you've never cleaned the ducting, or your dryer is pushed all the way up against the wall causing the ducting to become kinked, you will have air flow problems. One way in determing air flow is to remove the vent hose from the back of the dryer and start the unit (of course, you need a working dryer in order to do this). The air should be forceful and slowly warm up to about 140 degrees. If the air flow is weak, you may have a clog inside the air baffle of the dryer (this is where the lint screen slides into). If the air flow is good, reattach the dryer hose and check at the output of the dryer vent as it exits your home. If the air flow is weak or non-existent then you know you have a clog in the vent line somewhere. Periodic cleaning will go a long way towards preventing future clogs. Dryer vent rule of thumb: The SHORTER and STRAIGHTER the vent line, the BETTER. Everywhere you have a bend or kink is an area where you will create potential collection points for lint.
Now, in determing which component is bad in your dryer. If your dryer has the lint screen on top of the unit, you will need to remove the back panel to get to the heating circuits. If your dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by pushing in on the release tabs with a putty knife. They are located along the front seam about two inches in from each side.
The heating circuit is set up and troubleshot as follows:
Heating Element (located inside the heater box) - Resistance reading should be 9-13 ohms.
Thermal Cut-Out (located on the heater box) - Resistance reading of 0 ohms.
Hi limit Thermostat (located on the heater box closest to the heating element leads) - Resistance reading of 0 ohms.
Operating Thermostat (located on the air baffle) - (May have 4 wires attached to it). Will read 0 ohms across one set of leads, 7 ohms across the other.
*Thermal Fuse (located on the air baffle) - Resistance reading of 0 ohms.
*If the Thermal Fuse blows, this will shut down the entire dryer. This is your likely suspect.
Here's a few things that will cause a dryer not to start at all:
1. Broken Drum Belt - If dryer is equipped with a broken belt relay, this will shut the dryer down.
2. Broken Door Switch - If the door switch is broken, this will shut down the entire dryer as no power is applied to the start switch with the door switch open.
3. Bad Start Switch - If the start switch does not toggle close or stay closed when released, the dryer will not start.
4. Bad Timer - If the timer does not function the dryer will not start.
5. Bad Drive Motor - No Motor, drum does not rotate, heating circuits may or may not function. DOUBLE CHECK the CONNECTOR PLUG on the Drive Motor. I have found situations where this plug came loose for whatever reason and caused the dryer to either shut off completely or work intermittently.
6. Bad A/C Receptacle and/or Connector Plug - If you aren't getting the proper voltage to the dryer, it will not run.
I just threw in those other items to give you some other things to consider. Troubleshooting is always an exact science as symptoms don't always indicate what you think the problem could be. The reason I keyed in on the heating circuitry was the intial symptoms you started with. Longer dry times are usually associated with poor air flow which usually causes something to eventually blow. I hope you find this information helpful. Please post back with any comments that I may assist you further. I hope this isn't confusing to you. Please ask for clarification if it is.
Posted on Nov 02, 2007
SOURCE: Kenmore Elite Oasis Dryer with Airflow problem
same problem removed back cover cleaned lint found pulley had unscrewed and belt was off.installed pulley rev threded and put belt back on.
Posted on Apr 07, 2008
  • 686 Answers
SOURCE: Dryer turns, heats up but won't dry
check the outside of your house to see how strong the blowing is if it's weak then it's in the vent tube
Posted on Feb 18, 2009
  • 1738 Answers
SOURCE: Kenmore 600 dryer tumbling & heating, but not drying
Several reasonings. Step One make certain that you have 220 volts coming to your outlet. It takes 110 for the motor, and it takes 110 for the heating elements. If you have a volt meter that would be the best way to do that. Take the red and stick it in to the long part, and the black lead to the ground. Fuse houses was bad about this. Step Two it could be the elements are kicking off too soon. That is usually a sign of almost blown element. Step Three the heat sensor for the element prematurely kicking off the element.
Posted on Aug 10, 2009
Kenmore elite oasis dryer model 110.67032601 blower still works but heat stopped. took it apart and cleaned everything.now
searspartsdirect.com will identify part numbers when you contact them and identify model 110.67032601.
Apr 12, 2018 | Kenmore Dryers
Kenmore oasis dryer
Them oasis dryers and maytag bravos dryers all have a design blower with a small belt that tends to come off. Check this out
56bfeca7-24ae-4c69-8f40-12e24b03f02b.jpg ec813e4d-c675-4f0a-afde-b9585e5124aa.jpg
Oct 13, 2014 | Kenmore Dryers
The Kenmore Elite Oasis Steam Dryer - almost new - worked well last week. This week no power to dryer; 220volts is present to dryer. Any ideas?
You might want to take a look at the vent pipe for lint. If the exhaust thernistor detects high temps it shuts down the dryer. Bravos service manual (same as oasis)
Apr 29, 2011 | Kenmore 67082 Electric Dryer
Electric dryer, vent is clear, no air coming out vent line.
You most likely have a broken blower fan wheel. The hub sometimes will crack on the blower wheel and it will either not turn or turn very slowly on the motor shaft. I used model 110.6808600 as a reference since you did not include your model number:
See this link: (Item 10) $19.12 part!
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-1106808600/0582/0151200/00037555/00002?blt=06&prst=&shdMod=
Thanks for choosing FixYa,
Kelly
Apr 26, 2011 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore elite oasis dryer model #110.6708
about $10.00 for the thermal fuse and 1 Hr Labor (my rate is $30.00 per hour) and a service call,rate depending on where you live
Mar 19, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
Kenmore Gas Dryer Model # 97281800 - will not turn on. The dryer will not turn on, does this machine have a Fuse?
kenmore 97281800 drum turns good ,all vents are clear,only blows
very little.take the cover off blower compartment blows a lot.only warms the cloths. runs very well just does not dry. WHY does the blower not blow very much when its all together? is that the reason the heat cycles mostly off? three hours to dry a well wrung out load
KEN
Dec 23, 2009 | Kenmore Dryers
Just inherited a kenmore elite oasis dryer model 110 77092600 Where can I get a user manual? Could be online. I called Sears and they want $18 to order one!!! Kenmore charges also.
searspartsdirect.com - and enter your model #.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 22, 2009 | Kenmore Elite Oasis ST 7806 Dryer
HOW TO REPLACE A THERMAL CUTOFF ON ELECTRIC DRYER
you will need too take off your back panel of your dryer and the heater is on your right the thermal cutoff is on the left of the heater housing at the top and then there is a little white thermal cutoff on your blower housing in the bottom left of the dryer now if this is not how your dryer looks let me know cause there is several different style of kenmore dryers but this is the most common one
Dec 29, 2008 | Kenmore 67082 Electric Dryer
Dryers Logo
147 people viewed this question
Top Dryers Experts
