Question about Garden
I have a model m02195,when turned on it has a massive power draw and the main transformer gets hot instantly,i have replaced the main transformer ,but it still does the same thing.
  • 3 more comments
  • jeffroadfeld Nov 09, 2010
    this is a welder it is a marquette model m02195,the other model number is 117-034-400. the welder is about 5 yrs old.when you turn the unit on there is a massive power draw,in talking to a welding supplier they said it was the main transformer,i replaced it and the problem is the same. the transformer buzzes and gets instantly warm.
  • jeffroadfeld Nov 15, 2010
    i have tested the wiring and cant find a bad wire or burned spot on the circuit boards, the wire feed motor is ok any other ideas that i can look for . i had the fan housing out to replace the fan motor all the wiring is correct i double checked with the wiring diagram,is there somthing else that i am missing?
  • jeffroadfeld Nov 17, 2010
    tested all the wiring does not appear to be a dead short,there is relay inside that seems to be closed all, the time,i am not sure how it works,this is on my marquette welder model m02195 that seems to have a massive power draw when turned on.any help would be great
  • jeffroadfeld Nov 18, 2010
    i disconnected circuits one at a time, same problem, looked at crydom d2490-10 relay located on fan housing, it is a voltage control relay from 3vac to 240vac. this relay appears to be always allowing a full 230 volts input into the main transformer,i think it should be activated by the heat control swtich. is this my problem possibly?im stuck on what to do next.
  • jeffroadfeld Nov 22, 2010
    i replaced the voltage control relay,i do not have the massive draw when turned on now, butbvi do not have any power output when the trigger is pushed. the wire just sparks a little andthe transformer gets hot . what now?marquette welder m02195
  • 43,501 Answers
The problem is not with the transformer but rather the draw on the transformer...it is too high....there is a short in the wiring or the motor for the wire feed....
To find the exact problem you will have to take an OHM meter and trace down to problem with no power present.....
The readings will probably not be zero because the short is probably not a dead short but rather a break down in the insulation somewhere or an internal short in the motor.
Finding the problem could be a needle in the haystack deal...but at least with the OHM meter you should be able to isolate the problem to an area...then change parts from there...
heatman101
Posted on Nov 10, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Nov 17, 2010
    Is there anyway you can just disconnect part of the load at a time so that you can start to isolate the problem... it probably is not a dead short and is more likely bad insulation or something the just bleeds current...or just pulls more then it should...
  • 10,865 Answers
Hello Jeff. Thanks for choosing Fixya! The model number you listed does not match up with any chain saws. It appears to be a welder. Please reenter your problem being sure to state the brand name and the model number of your tool, and the category of tool that it is. We truly do want to assist you, so please do get back with the necessary information. Regards, Joe
Posted on Nov 09, 2010
My telefunken flatscreen tv goes to a black screen just seconds after switching on. The screen shows for about 2 to 3 seconds and then turns black instantly. How can I fix this
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 14, 2016 | Televison & Video
Have replaced transformer, worked for a couple of days and goes back to relay kicking off
If you have had to replace the transformer, then you probably have a relay that is pulling to much power and/or the thermostat wire may have to be replaced. Most transformer on controls are 40 watt transformers and at 26 volt it should pull less than 1.6 amps. P=IxE Take a clamp on amp meter to the red wire coming from the transformer on the 24 volt side and measure the current. If greater than 1.6 amps the transformer will start overheating because it is producing more power than it is rated. If this is the condition, then before the control fuse blows if it has one check the amp draw on the various relay coils to see if they are the cause of the excess current draw. Each control coil typically draws 6 watts and for 26 volt control power means the amp draw should be about .2 amps. If you find one more than .2 amp you have found your problem. Coil to check is your main contactor for the condensing unit, reversing valve coil if you have a heat pump, sequencers for emergency heat strips, and fan relay in the air handler for a few. Your schematic should list all possible relay coils. Keep checking until you find the coil.
You could also have a control wire that has its insulation worn down to the conductor, so you may have to check the control circuit for open grounds.
If after finding the coil or open ground, the next thing you need to check is the thermostat wire. Old thermostat wire sometimes have the insulation become brittle and cracked or chewn on by pets or rodents. If you have an coil that is drawing excess amps, the entire thermostat wire can turn into a long heater and can cause the thermostat wire to degrade until the wire short out. I have seen several thermostat wires that have been overheated due to bad coils and the excess heat have causes the thermostat wire outer cover to shrink just like shrink tite and is a dead giveaway that thermostat wire needs replaced.
I know that this is a lot to check, but I have had to troubleshoot the control wiring on a lot of units and now you have the condensed knowledge of my experience on this matter.
Hope this helps
Feb 11, 2015 | Heating & Cooling
Light transformer problems
DANGER WILL ROBINSON!
Transformers get hot when the load side sees a short (0 ohms) or very little resistance. V = I R or I = V / R. The voltage is a constant. As the resistance approaches 0, the current draw soars heating up both windings in the transformer.
Your transformer has an over temp sensor that shuts down the supply side before the transformer bursts into flames.
Find the short or replace the device. YESTERDAY!
Aug 27, 2014 | Intermatic Hardware & Accessories
Transformer overheating
The motor probably need maintenance:LUBE+replacing brushes,bearing.see my personal TIPS for defective transformer+motor
However the main problem is LUBE see the video and proceeding according witht the DECK BELT+ROLLERS BEARING TOO.
Feb 04, 2013 | Proform 835 Qt Front Roller Model 299480
I need a transformer
Hello
It is not clear from your post, that which transformer part number you wants to know. Anyway I'm hereby send you the part numbers of it two main transformers.
[1] Horizontal Ouput Transformer, or Line Output Transformer or Flyback transformer [HOT or LOT or FBT]; Part number is (257807)
[2] Switeched Mode Power Supply transofrmer [ SMPS transformer]: Part number is (257807)
OK.
Dec 16, 2010 | RCA F36650 36" TV
I have an intermatic C8865 timer. i want to wire it into an EFM model AF150-1 coal stoker furnace, because the fire goes down to far inbetween actual times heat is called for. also have main switch for...
Intermatic C8865 timer is a 5-hour cycle timer that repeats same cycle each 5 hour period.
This timer has 120Volt clock motor and is 120V timer.
Timer has NO and NC terminals.
NO terminal turns ON when timer turns ON
NC terminals is ON all the time, except when timer turns ON. At this point NC terminal turns OFF.
You have 3 things: 120V timer, 120V honeywell transformer, 120V stoker motor/fan
The transformer needs to be ON at all times.
The stoker motor is going to turn ON when the cycle timer turns ON.
You have 120V cable with black wire, white wire (and bare ground, which connects to green ground screw and to other bare grounds and won't be discussed further)
Black wire is hot
White wire is neutral
Black wire connects to 'Switch common terminal' on timer.
Same wire also connects to black wire on Honeywell transformer.
White wire connects to 'Clock terminal' on timer
Same wire connects to white wire on Honeywell transformer and to white wire on Stoker motor.
So all the white wires are connected together.
Last wire is black wire to stoker motor.
This wire connects to NO terminals on timer.
Here is drawing.
Add a comment any time
Dec 13, 2010 | Intermatic C8865 Timer, 1HR CYCLE TIME, 30...
Internal fuse on cambridge a1 mk3 has blown and when replaced,blew instantly??
When the fuse blows suspect an overload in either the power supply or Main Amp section.
Check for burnt/damage parts first!
Power Supply faults that will blow the fuse are: Transformer, Rectifier, Voltage Regulator, Large Electrolytic Capictors, Diodes & any other semiconductor connected with it.
Main Power Amp faults are: any semiconductor device on the heatsink.
Jan 04, 2010 | Audio Players & Recorders
Short Circut, blows fuses instantly.
OK usually the fuse goes because the Amp's IC's are drawing too much current thus the fuse blows... either this OR the Power Supply has gone Kaput. It is possible to replace the output IC's.. as it is to fix the PSU.. But it really is a shop job..
Jul 28, 2008 | Durabrand 5.1 Surround Sound Computer...
Have a nearly 30-year old Akai stereo receiver AA-R30. Power light just stopped turning on. Opened up case and found main fuse between AC power cord and power transformer blown. When I replace the fuse,...
Look for shorted output transistors or possibly shorted rectifier diodes. An immediate fuse blowing up usually means that the power supply is the problem. Keep us posted.
Dan
Apr 08, 2008 | Audio Players & Recorders
Low sound on high gain no low gain new tubs
Your power transformer should not be getting hot. The signal is not passing to or through the output transformer.Check the speaker connections on the speaker side of the output transformer. Go to geofex.com and check the tube amp debug page.
Apr 02, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
