Question about Proform Crosswalk 500 Treadmill
I have a PROFORM CX 500 at my home. It used to work fine but now there is a strange striking sound coming out of the front chamber when I run it at a spead 6 km/h or above. And with the sound you can feel breaking momentum of the belt as well. When we run the machine with no one onboard, there is no such sound. How do I overcome this problem?
    Master:
  • Proform Master
  • 165 Answers
You must LUBE the roller bearing front and back with WD-40 very well. .
2) Examine the drive belt motor, if are very tight, must be deflection 1/8" other wise the ball bearing of motor are very tight.Tight very well the bolt of motor.
3) Run again, if the problem persist, the Rollers are Faulty. Replace.
Treadmill Repair worn belt roller bearings
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Posted on Nov 26, 2017
5 Suggested Answers
  • 64 Answers
SOURCE: Proform Crosswalk Dual Motion Cross Trainer
I think you are talking about the front roller. It has a rubber sleeve that helps to grip the walking belt. Sometimes you can tighten this enough to keep it from slipping but you run the risk of overtightening and damaging both rollers. We recomend replacing that roller.
Posted on Nov 18, 2009
bwinton
  • 83 Answers
SOURCE: The belt is slipping and making a squealing sound
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
Posted on Apr 30, 2010
maxtreadmill
  • 832 Answers
SOURCE: my treadmill Proform caliber walk... belts keeps
The deck needs to be lubricated. The lubricant can be purchase @ gympart.com. LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in2_bing.gif and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes
Posted on May 16, 2010
  • 218 Answers
SOURCE: Clicking sound coming from front
bad bearing in the front roller
Posted on Aug 12, 2010
1981 Honda CX 500 A blows smoke out of the exhaust
Hi, Anonymous your instrument gauges and lights can alert you to most electrical and engine issues they can not warn you about failed engine gaskets or seals so your engine has to resort to old fashion alert methods of colored "SMOKE SIGNALS" here is a breakdown of their meaning:
1. COLORLESS OR SLIGHTLY BLUE SMOKE on start-up means your air/fuel mixture is at the right composition and everything is well burnt in your combustion chamber.
2. BLUE SMOKE on startup is usually caused by failed valve seals dripping oil into the combustion chamber when the engine is not running.
3. YELLOW OR BROWNISH SMOKE at start-up means your air/fuel mixture is too lean. Too lean means that there is low fuel but high air mixture in your combustion chamber.
4. WHITE SMOKE on startup may be caused by a blown head gasket allowing coolant to enter the combustion chamber and may start dripping out of the exhaust pipes or mufflers. Smoke while riding is usually caused by worn out or damaged valves, seals, guides, pistons, rings, or cylinder walls.
5. BLACK SMOKE on startup is usually caused by too much fuel in the combustion chamber this can be due to air/fuel mixture adjustment too rich, accelerator pump improperly adjusted, faulty choke or not in the off position, air filter dirty and clogged, faulty carburetor float needle and seat, pilot jet too large, fuel injectors leaking, smoke while riding is usually caused by the main jet being too large or a damaged carburetor.
It should be noted that aggressive or abnormal throttle operation will cause these conditions to manifest themselves exponentially.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the links below. Good luck and have a nice day.
White Smoke
white smoke out of one exhaust when revving
Honda CX500 Shop Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda CX500 CUSTOM Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Dec 12, 2012 | 1981 Honda CX 500 A
Proform 500 cx stops whilst running
1) lube the machine in according with the instruction manual maintenance
2) You have a deck belt worn, this producte enough friction to shut down the machine for to protect the electronic system.
3) inspect the drive belt 4) test the input voltage motor if there are the motor is faulty , repair. 5) Test the output voltage from board, for input voltage to the motor if there are NOT the board is faulty.
sincerely. God bless you
Apr 29, 2012 | Exercise & Fitness
Have a PROFORM CX 500 at my home. It used to work fine but now there is a strange striking sound coming out of the front chamber when I run it at a spead 6 km/h or above. And with the sound you can feel...
1)Examine, the board or Running deck, if the holes where the screwdriver are Looses, TIGHT very well, and see if there are doing correct .
Normally this happen when the person training is Jumping, Is NOT normally doing this. Since this machine ARE not Heavy duty like as the machine GYM.
Repair or Replace.
2) As a TIP LUBe the bearing Rollers front and back with WD-40
Blessing.
Oct 25, 2017 | Proform Crosswalk 500 Treadmill
When i try to run, it stops and then goes. Its like its trying to hard to go, you cant even run. its a proform crosswalk caliber.
hi it seems like the belt on the motor has either slipprd or needs to be tightened, i had the same problem. i just tightened the belt on the motor and its working fine!
Nov 20, 2010 | Proform Crosswalk 500 Treadmill
1980 Honda CX 500 won't start but makes clicking sounds
relay is bad or connection is--chec battery cable titeness or starter button--if u hav a kik starter buy a batt eliminator capacitor n hook in place of battery and bike will run like the old days
Apr 10, 2010 | 1982 Honda CX 500 B
I have a proform 650 treadmill. It is working ..but strange sound
The front bearings have failed and is causing the hammering noise will need to replace roller. Go to iconfitness.com go to customer service then replacement parts you will find your M# and pricing
Feb 25, 2010 | Nordic Track /proform Treadmill...
Speed indicator and belt problem
Under the motor hood by the front their is usually a speed sensor either not working or not adjust close to pulley where magnet is locate in , when it passes by the sensor it should read it.
Feb 24, 2010 | Proform Crosswalk 500 Treadmill
Strange clicking sound from my book home edition 1TB. Disk is not visible in any system Mac or Windows.
Is the clicking sound continous? Did the disk fell down or did something else hit the dis? The symptoms are bad for the data you have in the disk... If the sound isn't constantly, leave the disk on the computer for a long time, it's possible to work again....
Stelios.
Feb 22, 2010 | Western Digital My Book Home Edition 500...
Proform Crosswalk Dual Motion Cross Trainer Treadmill. motor works great. Rubber on right side under the moving belt has come off so belt slips when in use
Oct 24, 2009 | Proform Crosswalk 500 Treadmill
My 1979 CX 500 is running well but a strange noise seems to be coming from the transmission. Gear change etc is good and I checked all the levels and greased as required before using it after the winter...
The only thing I can think of is a shaft bearing gone bad. Probably the output shaft. Does the noise go away when sitting still? If so that would pretty much limit the problem to the output shaft bearing.
I hope this helps.
Please rate this answer. Thanks!
Mar 31, 2009 | 1979 Honda CX 500 A
Proform Crosswalk 500 Treadmill Logo
81 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
jay kaye
jay kaye
Marvin
Marvin
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
