Question about Zanussi Dryers
I have a zanussi ZTE 170 drier and want to use the drain hose on the rear of the machine instead of the catchment tank. can i have the hose draining above the drier? does the drier pump the water out or is it gravity feed?
Rotu
  • 175 Answers
SOURCE: Pump in tank wouldn't turn on
Sounds like you've already figured ti out. The pumps on these fail regularly. I would bet youve got a bad one. If you want to know for sure, check for 110 volts across the two wires at the pump when it is running and supposed to be draining. If voltage is there, but no pump run, order a pump and you'll be back in buisness. Good luck!
Posted on Jul 18, 2007
  • 4 Answers
SOURCE: dishasher does not drain
If it gravity drains, but the pump does not push out the water.......replace the drain pump. I just repaired an 8-year-old  Frigidaire dishwasher with this very problem, and although it sounded like the pump was operating, it was not....it was just vibrating. I replaced the drain pump and it now works perfectly. I am a service tech with 38 years experience.
Posted on Oct 28, 2007
SOURCE: Not collecting water in the tank
I assuming it is a condenser dryer ,have you checked the rubber gasket ,to see if it is damaged or has dirt on it that prevents it from making a water tight seal.
Posted on Dec 02, 2007
SOURCE: How to clean out drain hose
Believe it or not...I think it is fixed. I used a coat hanger to try to take out as much "gunk" as I could from the drain plug hose. I added warm water and then vinegar to the hose with a medicine dropper to help loosen the "gunk" I also forced air with the medicine dropper and I could hear it in the tub from the pump. Then I knew it was free of "gunk." I ran 3 hot cycles 2 with 1/2 gallon each of vinegar and one plain water cycle. Between each cycle I emptied the drain plug hose and drain pump filter. After the three cycles the water came out clean and not muddy. I also took a spray bottle of hot water and sprayed the "gunk" from around the seal to release it and out of the washer. I alternated with the spray bottle of water and vinegar applied with a small paint brush. I also noticed this "gunk on the stainless steel tub as well. I used the paint brush and painted vinegar on that and sprayed down with the hot water. I then did a load of towels and this morning my washer does not smell and is clean as can be...no more "gunk." what is that stuff anyway? Too much soap or softener? Anyone else have this problem? I was told by the service tech a few years ago that I didn't need to open that door because that is where they service the machine from.....wrong....I was to empty that drain hose from time to time. That was the first time I opened that door and the machine is 4 years old....
Posted on Mar 06, 2008
  • 1462 Answers
SOURCE: my zanussi TCS 675 EW
posibly a problem with the pump or a lint blockage in the pump chamber
Posted on Jun 19, 2008
My zwf 16581 w zanussi shows E32 error code. I have replaced the pressure switch but nothing has changed. Please help
If you are replacing an analogic pressure switch and nothing has changed I suggest you the following:
  • Drain the water from the tub.
  • Are pressure switch hose and air trap system free? (You can disconnect the hose and blow in it to check if the system is free).
  • If YES, than check the draining system (filter, drain pump, drain hose). Is the machine draining correctly?
Dado
Feb 23, 2016 | Zanussi Washing Machines
Washing machine fills up but empties at same time
If there are no obvious signs that the water is leaking out of the wash tub onto the floor, the cause is usually due to improper installation of the drain hose. The drain hose must be elevated prior to going into the household drain otherwise a siphoning effect will take place. A drainage standpipe or wash basin should be a minimum of 85 cm high to eliminate the possibility of siphoning.
The height of the drain will determine the maximum amount of water the washer can hold before siphoning begins.
Due to this effect, some manufacturers now place the connection for the drain hose towards to top of the washer cabinet instead of at the bottom. This then makes the actual drain height irrelevant. However, siphoning can still take place if the drain hose is sealed into the stand pipe.
Dado
Oct 15, 2014 | Zanussi Washing Machines
My drier tc.481w water not going into tank
remove container/tank and clear drain line that runs into tank, Tim
May 29, 2011 | Zanussi TD4212W Electric Dryer
How do i cahange a zanussi fl 1282 drain hose
tilt the machine back as far as possible to access underneath, then locate the drain pump an unclip the drain hose. Remember to have a basin or towels as water will come out.
Mar 02, 2011 | Zanussi Washing Machines
Machine flashing F02
- Clean out the drain pump catchment.
- Pull the suction boot off the drain pump, clean out any debris.
- Blow through the drain hose starting from the connection at the pump.
- If all else checks out, replace the pump
Nov 29, 2010 | Whirlpool Washing Machines
Stops with code F02
- Pull the suction boot off the drain pump, clean out any gookus.
- If all else checks out, replace the pump.
Nov 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F2 message appearing on washer, what does that mean
Something clogging the pump or drain line. Clean out the drain pump catchment.
This is how to clean the drain pump catchment: Remove the bottom front panel to see a white plastic catch basin with a removable-by-hand, large facing forward lid (peanut butter container sized) Remove it and clean out.
Feb 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Zanussi tc470 condenser drier Red light is staying on even after the water container is emptied. switch appears to be faulty
excess water seems to be lodged in the drier and was drained out.There is a drain at the rear of the machine. I am concidering connecting a pipe here and draining permently to the outside.
Dec 28, 2009 | Dryers
Grey sludge on my washing
Hi, I had the same problem.
The waste is blocked, check the drain pipe from the machine and also where it drains out to. (thick sludge)
I ended up unclipping the pipe from the drain motor (Bottom rear) and passing a garden hose throught it to flush it out.
Jan 07, 2009 | Zanussi FJ1254W Front Load Washer
Dryers Logo
144 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
