Question about Samsung ML 1610 Laser Printer
When switched it on it comes on well, but it can not warm up so that it can be ready to print.we have tried to test the main motor its fine.
  • 385 Answers
Hey!Load the smart panel and see if it gives a error indication!It sound like it might be the fuser unit!!Good Luck!
Posted on Nov 09, 2010
    Genius:
  • 1,325 Answers
Konica minolta 240f error code 18 stands for what
https://printcopy.info/?l=en&mod=erc&brand=Konica-Minolta&model=bizhub%20240F&code=18
Konica Minolta bizhub 240F Error Codes
Quoting from the web link shown above:
Konica-Minolta bizhub 240F Error Codes
Exploded Views and Parts List Free!
Code
18
Description
Fuser Error
(The number indicates the detailed error code) 0 The fuser did not become to the main motor driving temperature in 50 seconds after printing started. 1 The fuser did not become to the paper pick-up temperature in 50 seconds after printing started. 2 The fuser did not become to the main motor driving temperature in 30 seconds after warming up started. 3 The fuser did not become to the warm-up finishing temperature in 30 seconds after the motor started driving. 4 A temperature of 250°C or higher is detected in a mode other than sleep mode. 5 The fuser does not warm after fuser error is solved and the power is turned OFF/ON. 6 A low temperature of 10°C is detected in 10 seconds after printing started. 7 A temperature of 190°C is detected in ready mode after printing finished.
Remedy
1. Turn on the power again, and verify the fuser warms up. If it does not, see step 4. 2. Check the contact between Fusing thermistor and Connect A PCB(P89). 3. Check the contact between Connect A PCB (P80C) and the main board. 4. Replace the Fuser. 5. After replacing the Fuser, verify the fuser warms up when the power is on. 6. Replace the main control PCB.
Apr 07, 2018 | Konica Minolta Office Equipment & Supplies
I need help to clear error 18 on konical minolta 240f.
Code
18
Description
Fuser Error
Remedy
Nov 19, 2017 | Minolta Office Equipment & Supplies
Hi dear sir I have Ricoh 700 machine it was working fine but yesterday it's got some problem when I switch on its showing ready when i make the copy its scan the paper but not print stay on same place but...
You should try resetting the machine if you can. Taking out power cord will not reset machine. The micro chip has to be reset on the machine. If test / counter print works but copy doesn't work, then reset machine.
Nov 26, 2014 | Office Equipment & Supplies
My printer HP laserjet P2015, have a problem that no error light blink ready status light on (GREEN) but no test print out and nor other printing by USB cable from computer. Please advice about this i
May be cable loose or heavy dust available in printer that`s why your printer not proper response it. Or may be printer main board damage position so i suggest you contact it printer technician or checking it, which area damage.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01764440&tmp_task=solveCategory&cc=us&dlc=en&lang=en&lc=en&product=3811075
Thanks,
HP Printer Support
May 15, 2014 | HP LaserJet P2015 Printer
I have an HP 4515 that is printing blank pages. I have tried to replace the toner and the power supply board. Neither resolved the issue. When the paper gets deliver out the paper is warm. This occurs when...
I believe I understand your issue:-
The printer is able to come to ready- your still able to navigate the menus. the printer goes through all the motions of printing except producing an image-
Having the machine print a test page ( internal Print ) tests whether the formatter is still able to generate a digital image ready for the print engine, but does not diagnose the print engine-
1) power down and remove power cord
2)remove the toner cartridge, use a pair of pliers and gently rotate the drum ( within the toner cartridge, a drive gear/mesh can be found on the end of the toner unit)- are you able to turn this drum or has it seized?
if it doesnt replace the new toner with another NEW toner and try again
3) return the power and power up the machine having first disconnected all network connections.
allow the machine to come to ready.
4) ask the printer for a config page ( internal print) and estimate when the paper is immediately below the drum surface ( toner cart) and using the power switch turn the printer off- causing a jam in the centre of the printer - this is ok we do this to see if an image has been generated on the drum surface- remove the toner cartridge and slide the drum protector plate to the side, look carefully at the drum suface ( you should see a latent image of a config page, at this point look at the paper still jammed inside the printer and see if there are any signs of toner ( there should be part of an image allready on the surface ) now if there is an image on the drum but no image on the paper then I would replace the transfer roller and or transfer HVT power unit, if however there is no image on the drum then you have a very serious problem which will require a new laser unit ( but this should really come up with a diagnostic error code)or Primary HVT unit.
Feb 06, 2014 | HP P4515n LaserJet Printer
When I attempt to print the data and ready lights are on, but soon after it sounds as though it will print, the "Alarm" light appears, and printing stops.
Go into Test Print Mode
The printer incorporates various test print modes.
Select the test mode you want to use following the steps below;
(1) Turn off the power switch of the printer and check that the front cover is closed.
(2) Turn on the power switch while holding down the control panel button. Press the button
until the Drum LED comes on.
The Drum LED illuminates to indicate that the printer enters into the test print mode.
(3) If you want to execute the test print, release and then press the button again when the
Drum LED comes on.
or
Push "alarm" button : The printer is restored to the factory setting and permanent fonts and macros are cleared.
The printer returns to the ready status after
printing.
If it does not reset, replace the main PCB.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 23, 2011 | Brother HL 1440 Laser Printer
Red Alarm light (and all others) flashes, does not print. Closed properly. Seems to be a small amount of toner left in cartridge.
Drum LED comes on.
or
printing.
Thanks, Joe
Feb 22, 2011 | Brother HL 1040 Laser Printer
When Copying or printing the paper does not feed
open the front cover pull out the cartridge and you see paper feed roller it is rubber. Clean paper feed roller with cloth and water or alcohol.
Jan 24, 2011 | Samsung SCX 4521F All-In-One Laser Printer
My Phaser 7700 Printer does not come to a ?Ready? state
This might be a bad main Image Processor (650-4307-00) board. We can isolate it by printing an internal test print.
You can power up the unit in diags (hold "back" & "info" buttons while powering up) Go to "Built in Test Prints" and try to print the "Grid 1 Dot Pattern"
If you print, then it's proven...
If not, then you will get an error that will allow further troubleshooting.
-Whit
May 10, 2009 | Xerox Phaser 7750DN Laser Printer
Cold coffee, machine does not go through warm up cycle
I think its the main element that has a fuse thats need to be reset.
There is 2 kinds of elements on this machine one for the steam and one for the coffe.
On the main element there is 2 automatic fuses that you can reset by just clicking on them.
Jun 28, 2008 | Saeco Incanto Classic Espresso Machine
Samsung ML 1610 Laser Printer Logo
59 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
