Question about Baumatic B180 Electric Single Oven
I have a multifunction oven ... when its on the fan assisted setting all the lights come on but no heat is given out. The other settings like the grill and bottom of the oven heat up and all the lights come on but the main convector part is not working. Can you help?
  • Baumatic Master
  • 3,463 Answers
Hi.
If the fan is working o/k, then you need to replace the oven element located at the rear of the oven compartment behind a removeable cover.
Posted on Nov 09, 2010
Smeg FU65-5 Oven temperature & timer & function knob lights not turning on and oven does not heat up but the fan comes on.
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Dec 02, 2012 | Smeg 24 in 60 cm Stainless Steel Electric...
Are the top and bottom heating elements both supposed to heat? Only the bottom one is heating except when specifically set on "broil".
Most ovens with top and bottom elements have a multifunction control switch which enables the user to select a certain setting to suit their cooking. The control switch would normally have small pictures of the elements, fan forced function etc, to show what each setting does. Sometimes you may only require the bottom element working and other times you may want/need both.
Feb 14, 2011 | Frigidaire Ovens
My buttom oven is not working but top is working
If it is a fan assisted oven, and the fan is working, then it is likely to be a faulty heating element.
This should be located behind a removeable cover at the rear of the oven compartment.
If the fan is not working as well, then could be a faulty thermostat, even without the element or fan not working, there should be an indicator light on to show that the power is on,
Also make sure the main oven is set for manual operation, and not set on auto, as this will prevent the main oven coming on if it is.
Feb 12, 2011 | Tecnik TKC8522 Electric Double Oven
Oven is AEG Competence, single oven, fan assisted, 4 yrs old. Oven doesn't heat. Light ok, automatic cooking settings not switched on, grill working
If the fan is working o/k, then you need to replace the oven element.
This is located at the rear of the oven compartment, behind a removeable cover.
This should solve the prob.
Please leave feed back.
Thankyou.
Jan 06, 2010 | AEG Ovens
Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Oct 09, 2009 | Smeg SE250XUK Stainless Steel Electric...
Fan but no heat
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on Facebook please
Mar 14, 2009 | Smeg SE280X Stainless Steel Electric...
Fan oven not heating
its the element not the stat
Mar 10, 2009 | Bosch Ovens
AEG D2160 Double Oven - electrical fault
you may find that one arm of the oven selector switched has fused to its contact.
Sep 07, 2008 | Ovens
Fan assist wont heat oven
the ring element may have blown. if it works ok with the top and bottom elements, (the convection oven) then it is likely the element surrounding the oven fan.
Jun 25, 2007 | Baumatic B187 Stainless Steel Electric...
Baumatic B180 Electric Single Oven Logo
440 people viewed this question
Top Baumatic Ovens Experts
ashburton
Starnley Johnwells
Starnley Johnwells
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
