Hi,i have a Tevion portable 7" dvd player model No 6322. Everytime i load a Dvd it spins for a while then says 'no disc' Any ideas,ive cleaned the lens several times
    President:
  • 624 Answers
If cleaning the lens does not work, you may need it serviced. It could be the laser pick-up is bad, or an IC on the DSP board could be bad. may even be the spindle motor, even though it spins, it may not be spinning at the right speed to get a focus lock and read the disc.
Most of these type of DVD players end up being disposable due to the cost of the parts and labor for the repair. If you can get a free estimate at a repair center it might help you make that decision a little easier. It is not very good news for most people who buy them, but since the manufactering cost has gotten so low, most just get replaced. Most of them can not be fixed for thess than $100
Posted on Jun 16, 2008
MY TEVION WAS THE SAME. PUT IN DVD AND HERD IT RUNNING AS LOADIND THEN NO DISC. AFTER READING SOME RESPONCES I THOUGHT IT MAY BE THE DRIVE SO I PUT IN A DVD LET IT RUN AND STOOD IT ON ITS SIDE. AFTER A MINUET OR SO IT CAME ON.I MUST HAVE TAKEN SOME WEIGHT OFF THE DRIVE. HOPE THIS HELPS. BILL,
Posted on Sep 29, 2009
My DRC6309 RCA portable DVD player will not play disc. It says "loading" and then says "no disc". I have tried different outlets and different discs. Any suggestions? Is there a...
Hello
Either your DVD players Laser Pickup Unit is dirty or defective or its 'sled' motor has damaged. Sled motor is one, which spins the disc inside. if it does not spins, the main system IC won't get any signal that the disc is "IN", and will show the messege "No Disc". The same will happen if the laser pickup unit is defective or dirty. Insert a Head Cleaning Disc into the system, and play it for atleast 3 times. If there is any dirt or dust, this will solve your DVD's problem. If not, it should be serviced by any skilled technician. It is not a user reparable item, as you have to take out its loading mechanism completly out of it for repair. OK.
Jun 02, 2011 | RCA DRC6309 9 in. Portable DVD Player with...
My 1710 mintek keeps saying loading but doesn't load. What do I do? Thank You.
Hi.
Clean the lens with a dvd cleaning kit. It should solve the problem. If you load the disc and you don't hear the disc whirling, it means that the motor is not spinning thus, the player will not identify any disc. It is time to have the dvd lens repaired or replaced.
Hope this helps. Thank you for using Fixya!
Feb 12, 2011 | Mintek DVD-1710 Portable DVD Player
EVERYTIME I PUT DVD,MP3,CD "NO
Hi Susan,
Your problem is in the lens assembly. First try to clean the optical lens by soft cottond buds. Dust build up and any tiny foreign object will block the lens from reading. If nothing happens, you need help from friends that can perform this steps http://www.fixya.com/support/r7833671-change_defective_motor_portable_dvd.
Hope it may help you.
Have a nice day!
Thanks for using fixya.
Feb 09, 2011 | Philips 7" Susan G Komen Portable DVD...
Says loading disk and then says wrong disk everytime. tried several different dvds. always the same answer!
The DVD portable player and the DVD disc came from the same countries?Ur DVD portable player and DVD disc u are using might have the wrong region DVD disc format frequencies.Like PAL frequencies only play Euroupean,Asia,Middle East,Austriala and Africa products.NTSC frequencise play only USA,Canada and Mexico DVD Disc products.
Dec 13, 2010 | Coby 7" Widescreen TFT Portable DVD Player...
Everytime i put in a DVD it says "Loading" on the
There is problem with Optical block need to replaced.This Model is new and still come in under Warranty.SO check your Warranty card and calim your near Sony service centre.
Nov 15, 2010 | Sony DVP-FX930 Portable DVD Player
Portable dvd player
the laser may be broken,and can not read...
Apr 15, 2009 | Mintek MDP-1720 Portable DVD Player
I have a CyberHome DVD 300. It will not load disc.Indicates that no disc inserted. I have cleaned the disc to no avail.
you will need to remove the cover and clean the laser eye with rubbing alcohol and cotton swab (q-tip)
Mar 04, 2009 | Cyberhome CH-DVD 300 DVD Player
Won't pickup the dvd everytime
there are a few possibilties
1 make sure the disc is clean
2 your lens may need cleaning
3 some dvd players don't read burn copies of disc's some just read +R discs some just read -R disc
Jan 29, 2009 | Memorex MVDP1077 Portable DVD Player
I have a Panasonic portable DVD Player---0714. Recently the player does not recognize the DVD when loaded, and gives a message of "no disc" when a disc is loaded and the player is spinning. I...
Try cleaning the lens with a cotton bud and alcohol like ethanol, clean the worm wheel that tracks the laser assembly, failing that the laser may be worn....Phil
Dec 12, 2008 | Televison & Video
Disc gets stuck on "loading"
laser lens may need cleaned or realind! claen and try again
Televison & Video Logo
212 people viewed this question
Top Televison & Video Experts
Electro Med Services...
