Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
My TV turns it self off after a few hour s of viewing
  • Sony Master
  • 19,396 Answers
Hi.
The most common problem that causes shut down after few hours is overheating. Overheating however does not necessarily occurr because a faun is broken or because a thermistor is defective. A devective IC may fail and overheat on its own. The fault won't be even called overheating in some case.
The TV must be taken apart and tested by a technician.
Common faults to be tested are:
Fans and tehrmistors.
Convergence ICs.
Ballast.
PSU.
There are also a couple of test point on main controller board to be tested.
Regards.
Ginko.
Posted on Nov 09, 2010
Tv will turn on for a few seconeds then turns its self off
Tries tv unplug,replug it back like an hour later.The tv is resetting itself back to the factory setting now.The tv now should work,not than the tv have problems with it power supply board.The power supply board it not giving the tv,the wright voltages to the tv anymore.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 14, 2010 | Sanyo DP32649 31.5 in. TV
My tv says enter password. I never knew it had a
I don't know how it got fixed. I left it on for and hour and then tried switching the imput again and it worked. A few hours later it shut its self off. I turned it back on and so far so good.
Nov 18, 2009 | RCA 32F531T 32" TV
Turn off after a few hours
If the TV turn itself off then perform the following steps:
(i) Check if the Sleep timer is activated.
(ii) Check if the Parental Guide prohibits viewing during that time and/or limits amount of viewing time per day.
(iii) Check the batteries on your remote, low battery power may cause random signals from the remote.
(iv) Disconnect all the cables from the TV then reconnect them after a few hours.
(v) Ensure the power cord from the TV is directly connected to a functional wall outlet.
(vi) You may also try resetting the TV to the original factory settings by pressing the Reset button on the remote control supplied with the TV when in Menu.
The following is the information indicated by the blinking patter of the standby/timer lamp on the TV:
2 times : Power does not come on.
Load on power line shorted.
3 times : The TV has entered standby mode.
4 times : Has entered standby state after
horizontal raster.
Vertical deflection pulse is
stopped.
Power line is shorted, or
power supply is stopped.
5 times: No raster is generated.
CRT Cathode current detection
reference pulse output is small.
6 times: No picture
9 times : No sound
Furthermore, the TV is equipped with a self-diagnosis function that you can use to determine whether the issue is related to any hardware malfunctioning. Perform the step given below to run self diagnosis:
Quickly press the remote command button in the following order from the standby state.
Display -------> Channel 5 ---------> Volume -(minus) --------> Power ON.
If the Self Diagnosis display numeral "1" for any parameters then a fault has been detected and service will be required.
wish u good luck!!!!!!!!!!
Sep 17, 2009 | Sony KP-65WS500 65" Rear Projection...
KDF-46E2000 turns off then back on by its self
* Most common would be a couple of capacitors in the power supply that are not letting the proper voltage to the lamp.
* The lamp itself is not working properly.
Jan 25, 2009 | Sony KDF46E2000 46" Projection HDTV
Sony tv not turning on
I would need the model number to look service codes
Feb 24, 2008 | Televison & Video
RCA F31317 31" TV Turning self off and on then completely off
the horzantle power supply is bad probably missing the B+ voltage this is a repair for a tech high voltage
Dec 21, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Phillips 64" PTV Issues
sounds like vertical problems see if you have bad solder connections then get back to me
Nov 02, 2007 | Philips 50P8341 50" Rear Projection...
TV turns off right away relay clicks
1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB.
Aug 19, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
285 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
