Question about HP Photosmart C6180 All-In-One InkJet Printer
Printer just clicks on and off - HP Photosmart C6180 All-In-One InkJet Printer
  • 100 Answers
An ink system error started occurring on my printer and eventually it would constantly power on and off. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures the printer was having. A similar fix may apply to other printers.
Posted on Mar 28, 2011
How to install dcp-165c
To install a new printer, follow these steps:
1. Click the Start button, point to Settings, and then click Printers.
2. Double-click Add Printer, and then click Next.
3. Click Local Printer or Network Printer as appropriate, and then click Next.
If you click Network Printer, you are prompted for the network path for the printer. If you do not know the correct path, click Browse and select your cd/dvd drive(Put Printer cd in your Cd/DVD drive). Click either Yes or No in the "Do you print from MS-DOS-based programs?" area, and then click Next.
4. Click the appropriate manufacturer and model for your printer, and then click Next.
5.If you chose to install a local printer, click the correct port and then click Next.
6. Type a name for the printer (or accept the default name), and then click either Yes or No in the "Do you want your Windows-based programs to use this printer as the default printer?" area. Click Next.
7. To print a test page, click Yes. Click Finish.
Jun 21, 2011 | Brother DCP 165C Compact Color Inkjet...
Tip
How to connect the Printer to a network ?
Connecting the USB Printer to network
1) Right click on My computer
2) Click on Properties
3) Click on Computer Name
4) Click on Change (where it says "To rename this computer or Join a domain, Click Change")
5) Give Name to your Work Group
"Type the some Name in the BOX"
6) Click OK and Restart the Computer
** NOW THIS COMPUTER IS A PART OF WORK GROUP **
(settings on Main Computer where the Printer is installed)
7) Now we can share whatever you wana share
8) Open control Panel
9) Open Printer and Faxes right
10) Right click on the Printer Icon and click on Properties
11) Click on Sharing
12) Click on share this printer and *Name the Printer if you want share
13) Click on Apply now this Printer is in Network
Network the Second Computer
13) Go to each computer
1) Click on Start - control panel -
2) Click on Printers and Faxes
3) Click on Add a Printer
4) It will show Welcome to Add Printer Wizard
5) Click on Next
6) Select "A network printer, or a printer attached to another computer
7) Select browse for a Printer and HIT NEXT
8) It will show you the WORK GROUP and when you hit on it it will show you the Printer
9) Click on Next and OK
Its Done the Printer is Shared and you can take a print out.
Note : The Main Computer should On in order to take Print-out
Hope this will help you connecting your USB printer to the Home Network
or IF YOU HAVE THE NETWORK PRINTER check the following steps
Adding a new network printer
1) Click on Start
2) Click on Printer and Faxes
3) From the left side of the window - click on Add a Printer
4) It will Pop up a new Screen (Add Printer Wizard Window
5) Click on Next
6) Select Local Printer
and Uncheck Automatically Detect and install my plug and play printer
7) Click on Next
8) Click the DROP-DOWN menu next to Use the following port
and if the Printer Queue is listed,select it and click NEXT
***IF it is not listed in the Menu,
Choose Create a new port
from the Type of the Port list - select Standard TCP/IP Port. Click Next
In the Add Standard TCP/IP Printer Port Wizard window, click Next.
In the Printer Name or IP Address field,
- Type the queue name of your printer and the Port Name field will be automatically filled in
Click Next
Click Finish
IF Required Install the Printer Drivers using the Disk
9) If you are asked whether you want to keep an existing driver, select Replace existing driver, then click Next.
10) In the Printer name field, type the printer's queue name, model name, location and double-sided or single-sided. If this is the printer you will be using most often, select Yes to use this printer as your default printer; otherwise, select No. Click Next.
11) If you are asked whether you wish to share the printer, select Do not share this printer. Click Next.
12) When you are asked whether to print a test page, select No
13) Click Next.
14) Click Finish.
Note : You may have to wait a few seconds for the Add Printer Wizard window to disappear and it may appear frozen.
If you receive a message that a Microsoft digital signature was not found, click Yes to continue the installation.
TEST THE PRINT
To check if the printer is working correctly, go to Start > Printers and Faxes. Right-click on the newly created printer, select Properties and then click on the button for Print Test Page.
on Jan 22, 2010 | Office Equipment & Supplies
Tip
Setting up a Shared Network Printer
Any printer that is connected to a computer and is connected on a LAN can be configured so all other computers on the same network can print to this printer. This means the computer with the printer attached to it MUST be booted up at all times when other computers want to access the printer.
You need to install the printer driver on the computer and configure it as a Shared printer.
The other computers on the network need to add this printer to their computer.
Follow these steps to set-up a shared network printer :-
1. Connect the printer to the computer and install the printer driver.
2. Open Printers and Faxes - right click on this printer and click Sharing - click Sharing tab and click Share this printer, then if you wish you can change the Share name, then click OK
3. Right click on the printer – click Properties - click Print Test Page to confirm printer installation.
Follow these steps to configure the computers on your network :-
1. Open Printers and Faxes – click Add a printer – Next – select A network printer, or a printer attached to another computer - Next.
2. Select Browser for a printer – Next
3. Click on and expand the Microsoft Windows Network down to the computer with the printer – Next
4. Select Yes for - Use this printer as the default printer – Next – Finish
5. Right click on the printer – click Properties - click Print Test Page to confirm printer installation.
on Dec 19, 2009 | Office Equipment & Supplies
When I press print, it shows up as my default print is my fax. How do I change the default printer to be just the printer instead of the fax?
In windows Vista or 7:
  • Open Printers by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Hardware and Sound, and then clicking Printers.
  • Right-click the printer you want to use, and then click Set as Default Printer. A check mark is displayed on the printer icon to mark it as your default printer.
  • In windows XP:
    • Open Printers and Faxes; click Start, click Control Panel, click Printers and Other Hardware, and then click Printers and Faxes.
    • Right-click the printer you want to use as the default printer, and then click Set as Default Printer. A check mark appears next to the printer icon in Printers and Faxes.
    Hope this helps!
    Mar 17, 2011 | Serif Computers & Internet
    Unable to install HP640C Printer driver
    Delete it from the Add Printer Wizard
    1. Click Start .
    2. Click Control Panel .
    3. Click Printers and Other Hardware .
    4. Click Printers and Faxes .
    5. Under Pick a task heading, click View installed printers or fax printers or under the heading or pick a control panel icon , click Printers and Faxes .
    6. Right-click the printer icon.
    7. Click Delete from the drop down menu.
    Windows XP
    1. Click Start , Control Panel .
    2. Double-click Add or Remove Programs .
    3. Highlight the printer to be removed and click Change /Remove .
    If the driver comes with an uninstall feature, follow the steps below:
    1. Click Start and Programs .
    2. In the Programs list, highlight the name of the printer to uninstall.
    3. Click Uninstall .
    4. Click Next .
    5. Click Uninstall .
    6. Click Restart .
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
    Thanks, Joe
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Dec 30, 2010 | HP DeskJet 640c InkJet Printer
    Its identifying my printer as being offline, how do I correct it
    Click on startà control panelàprinter and faxes.
    Click on top left Add a printer option. This launches the Add Printer Wizard. Click next.
    Select Local printer attached to this computer and uncheck automatic detect and install my plug an play printer option then click Next.
    Now, Use the drop down arrow to select USB001 then click next.
    Select the Manufacturer as HP from drop down list and select DeskJet 990c from printer drop down list. Click Next.
    Verify the printer name and set the printer as default then click next.
    Do not select print a test page option.
    Click on Finish
    Click on start then run type notepad.
    Write any stuff and then try to print.
    ADD A PRINTER IN VISTA
    Click Start and click Control Panel.
    Click Hardware and Sound then Printers.
    Click Add a printer. This launches the Add Printer Wizard.
    Click Add a local printer.
    Now, Use the drop down arrow to select USB port 001 then click on Next.
    Select replace current drivers
    Click on Finish.
    Click on start then search type notepad.
    Jul 10, 2010 | HP Officejet 4315v All-In-One InkJet...
    Want to install printer
    If you are running Windows XP or Windows Vista, you may simply plug in the printer to the computer, and the computer will install the generic driver.
    By default, Windows XP and Vista already has the generic driver installed.
    However, if the printer is not a Plug-n-Play device, you will need to load the CD that came with the printer, and follow the installation wizard.
    Thank you and good luck!
    Jun 13, 2010 | Brother MFC 240C All-In-One InkJet Printer
    While trying to print from a microsoft works spreadsheet...it always says "out of memory" and prints a distorted page.
    Hi
    here are some ways to override the problem
    When you try to print
    it says
    Microsoft Works Out of Memory
    This problem may occur if there is a problem with the printer driver that is installed on your computer.
    • Method 1: Install a different printer driver
      Contact the manufacturer of your printer to inquire about how to obtain and install the most recent version of the printer driver for your printer.
    • Method 2: Configure the printer as the default printer
      Configure the printer driver that you have installed as the default printer. To do this, follow these steps:
      1. Click Start, and then click Printer and Faxes.
      2. Right-click the printer that you want to set as the default printer, and then click Set as Default Printer.
      3. Click File, and then click Close.
      4. Start Works, and then print the spreadsheet or the database file.
    • Method 3: Install an emulation printer driver
      If the problem persists after you install the most recent version of the printer driver for your printer, install an emulation printer driver. An emulation printer driver is a driver that imitates the functionality of a different printer driver. For example, you may be able to resolve this issue if you install the driver for the Hewlett-Packard DeskJet 550C printer or for the Hewlett-Packard LaserJet II printer. To do this, follow these steps if the printer is connected directly to the computer:
      1. Click Start, and then click Printers and Faxes.
      2. Double-click Add Printer.
      3. Click Next, and then click Local printer attached to this computer.
      4. In the Use the following port box, select the port that you want to use.
      If the printer is connected directly to the computer, the port is typically LPT1 (Recommended Printer Port).
      5. Under Manufacturer, click the manufacturer of the printer driver that you want to use as the emulation driver. For example, if you are installing Hewlett Packard 550c, click HP DeskJet 550c.
      6. Under Printers, click the model of the printer that you want to use as the emulation driver, and then click Next. Select HP. In Drivers, select HP DeskJet 550c.
      7. In the Printer name box, type a name for the printer, click Yes to set the printer as the default printer, and then click Next.
      8. Click the appropriate option for sharing the printer, and then click Next.
      9. Click No, and then click Next.
      10. Click Finish.
      Note If you are using a USB printer, go to step 12.
      11. Start Works, and then try to print the spreadsheet or the database file.
      12. Open Control Panel.
      13. Open Printers and Faxes.
      14. Right-click HP 550c, and then click Properties.
      15. Click Ports.
      16. Click USB001 Virtual Printer port for USB.
      17. Click Apply, and then click OK.
      18. Start Works, and then try to print the spreadsheet or the database file.
    Hope this will solve your problem
    Jan 02, 2010 | HP Photosmart C5180 All-In-One InkJet...
    Microsoft Word problem
    This error message may occur when there is a wrong Printer selected when u try to Print but if it still says the same thing just uninstall and reinstall Works and Check............
    Good Luck
    Mar 01, 2009 | HP OfficeJet 6210 All-In-One InkJet...
    How can I set up wireless printer
    To share the printer, I open the Printers and Faxes folder on the computer that was connected to my printer.
    To open the Printers and Faxes folder
    • Click Start and then click Control Panel.
    • Click Printers and Other Hardware, and then click Printers and Faxes.
    • In the Printers and Faxes folder. Click the printer's icon and, in the tasks pane, click Share This Printer.
    • Open the printer's Properties dialog box, and click on the Sharing tab.
    • Click Share Name, and then clicked OK.
    That's it
    Now you have a network printer, you are ready to connect to it and print from other computers on the network.
    To connect to the printer
    •O pen Control Panel, and click Printers and Other Hardware.
    •C lick Add a Printer.
    • Instead of adding a local printer, though, click Printer Connection and then browse the network for the printer.
    Feb 29, 2008 | Computers & Internet
    HP Photosmart C6180 All-In-One InkJet Printer Logo
    16 people viewed this question
    Clive
    Clive
