Question about Toshiba Televison & Video
I have a Toshiba 42WH18B and I am told that the teletext board has gone (suffering from intermitent picture and lines, picture switching between black and white and colour). Can anyone tell me what the part number is for the teletext board and where I can get one? Thanks
    Brigadier General:
  • 8,909 Answers
The teletext board in that set is an add on and as such if it is taken out the set will work happily without it and as teletext no longer exists in the UK, not a problem. When the set is switched on without the panel, the microprocessor will see there is no board because it won't get the hand shake and perform as though it were a 42WH08B
Hope that helps.
Posted on Nov 09, 2010
  • suejlynch Nov 09, 2010
    Will I be able to remove the teletext board myself or do I need an engineer to do it?
  • specialistel Nov 09, 2010
    I think it is plugged in but I can't remember.
    If you take a look inside, the text board in near the front panel and about 1 1/2" high and 2" long.
    Watch for dry joints under any heat sinks, that may be the real reason for the intermittancy.
My tv only show black and white lines, it shows no picture but the lines
The main digital processor board should be troubleshooted. The work is a skilled one, that a user cannot locate the exact fault point with these boards. Contact any experienced service technician. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Jan 29, 2013 | Toshiba 62HM95 62" DLP HDTV
7inch vertical color lines right side of screen all th time
Hi.
This website has the service manual ($7.79) with instructions to diagnose the boards. Unfortunately I am afraid that the problem is not a board but the panel itself.
Thin vertical lines in the middle of the picture mean that the panel is gone. Here an example of lines from bad panel in Toshiba LCD:Line Picture. (discussion: Avsforum). Sometimes the lines can be dark or in bright color.
The panel costs $339 (LCD PANEL ASSY).
Because of the price of the panel, the TV is not worth repairing unless under warranty.
Even if the TV is out of warranty call Toshiba and report the problem. As you can see in AVSforum page above the problem is affecting many users.
If Toshiba doesn't offer special conditions on repair (or discount on new), the TV is not worth repairing. Replacement of the digital board will hardly be a solution.
Only if you have wide bands, scrambled or flickering, then the problem is digital board (main board) or panel.If you have the thin pixel lines, then the panel is gone.
Dec 10, 2011 | Toshiba 40RF350U 40 in. LCD TV
Can you confirm if my motherboard has gone. I have two ports for the monitor. One is an external Graphics Card and one an internal graphics card. The monitor screen has lines across it when i plug into the...
You may have suffered a power surge which has damaged the motherboard and other components. I have suffered 2 myself and this sounds similar. Try reinstalling ALL your drivers and see if this solves it. If not I think *********** board has been ESD damaged.
Feb 26, 2011 | Packard Bell Computers & Internet
We recently switched to digital cable and now the TV has a solid line thorough the center of the screen. This started intermitently and after a time the picture would come on but now is constant. Is this...
If the set is a standard CRT type set and the line is a horizontal one, this is a common problem that has nothing to do with the switch. There is a problem with the vertical circuit that can be a simple as poor connections at the vertical IC (LA7837 or somthing similar) or a defective IC.
Dan
Mar 14, 2010 | Toshiba Televison & Video
ON MY DIGITAL LG TV A BLACK SQUARE COVERS MOST OF THE PICTURE SWITCHING OFF THEN ON SOMETIMES CLEARS IT
Check CC/TELETEXT setting, most likely your teletext is activated,switch it off and black square will go away.
Nov 22, 2009 | Televison & Video
Toshiba REGZA 37AV500A LCD TV when using HDMI input picture and sound intermitantly blacks out for about 2 seconds
Does this happen with all the HDMI inputs. If only the one then jack is bad. Replace the main board. If on all HDMI inputs see if replacing the cable helps.
Nov 08, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Toshiba 36A50 sound, light line horizonally on black screen
It is my guess that you have some intermitent solder connections in the Vertical output circuit.
Hope this helps,
Skyassoc
Jun 23, 2009 | Toshiba 36A40 36" TV
Sond no picture
try this
sounds like the teletext module's
http://forum.eserviceinfo.com/viewtopic.php?p=4626
Dec 07, 2007 | Toshiba 42H81 42" Rear Projection...
Televison & Video Logo
340 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
