Question about Palm Treo 500 Centro
Bluetooth how to bluetooth on a palm centro
Email Restarts phone.
Sprint said make a new user because of 3rd party software but won't help otherwise.
Bluetooth won't work with my Pioneer DVD in dash Car receiver either.
Works with my Jabra headset though.
What gives? Any software I can download to fix?
Thanks
Posted on Nov 05, 2008
4 Suggested Answers
SOURCE: locked out of my palm centro
How do I recover my old passwoed?
Posted on Nov 21, 2008
SOURCE: Palm Centro locked
If you forget the password, the only way to get back in is to perform a "hard reset." Performing a hard reset causes you to loose all data on your phone unfortunately (numbers, texts, and all). Hopefully you've sync-ed up your data on your computer recently.
To perform a hard reset, do the following:
1 - Remove the battery cover.
2 - Take out the battery.
3 - Put the battery back in. An orange Palm logo will appear on your screen.
4 - While the logo is showing, press & hold the Power/End button until a black status bar appears on the screen, fills completely, and then goes away. Then you can stop pressing the button.
5 - Next on your screen will be a prompt to erase all data. Press up to say Yes.
6 - Next select your language and you have an empty phone to start a new. If you've previously sync-ed up your data, you can sync up now and add it all back.
Posted on May 31, 2009
SOURCE: Palm Centro - continous Syncing problem, now phone is dead
This happened to my palm centro and i fixed it myself. :) Maybe it will work for you. What i did was take out the battery and so the phone is completely off.. then take a tooth brush with rubbing alchohol on it and scrubbed the bottom part of it that the hotsync cord goes into.. I thought this may just mess up my phone more but i plugged it back into the power cord, turned it on and it worked just fine!! Seriously, try this out. It brought me so much relief!! And chances are you either got some **** stuck up inside there, or you got the botton part wet. Hope i helped!!
Posted on Sep 05, 2009
How do i tranfer my contacts from my palm centro & another palm centro?
First, make sure you backup all of your data, including data in any 3rd party apps.
Sync your first Palm Centro with the Palm Desktop software to save the data.
Verify the sync settings in the Palm Desktop software to make sure when you begin syncing with the new Palm Centro, the settings for each application (contacts, calendar, memos, etc.) are one-way sync to the device, or you might end up overwriting the data in your Palm Desktop software with what's on the new Palm Centro.
When you sync your new Palm Centro with the desktop software the first time it will ask you to name the new device. If you give it the same name as the old Palm Centro, all of the data will sync to your new Palm Centro.
Search your computer for a folder with the name "Palm" in it to try and locate the name of your old Palm Centro, so you can name the new Palm Centro the same. When you locate that folder on your computer, it would be a good idea to simply make a copy of that folder as a total backup.
Dec 22, 2009 | AT&T Palm Centro Cell Phone - White
I cannot get it to connect. My Palm Centro recognizes it, but says that is unable to connect even though it has done so in the past.
Try disconnecting the bluetooth device then turn the bluetooth off then hold the power button untill the bluetooth shows a solid red light then try connecting the bluetooth between your palm and the bluetooth device hope this helps
Oct 24, 2009 | LG HBM 730 Bluetooth Headset Wireless...
Hello Two problems with Palm Centro phone 1) 'No Activated Card Found' message but card is installed. 2) Phone resets on attempt to activate Bluetooth.
We might need to hard reset the phone. Follow all the steps mentioned in the website below:
http://kb.palm.com/wps/portal/kb/common/article/42094_en.html
Aug 17, 2009 | Palm Treo 500 Centro
I can't get my jawbone to pair with my palm centro any idea's
With the jawbone turned off, press at the same time the turn on button and the noise reduction button. The jawbone should blink white and red for three minutes, in that time you shoul be able to find it as a bluetooth device in the free hnd configuration of the palm centro. than yu complete the conection by inserting the code. The next time you turn on the jawbone it will connect with te palm.
Aug 09, 2009 | Palm Treo 500 Centro
Internal speaker on palm centro stopped working
jjn374 you are a genius! I had the same problem, my centro had all my music, and you're solution really helped me out. I made this account just so i could thank you!!!
Apr 05, 2009 | Palm Cell Phones
How can put ringstones on palm centro
Download the free app..."minitones"
Jan 03, 2009 | Palm Treo 500 Centro
Bluetooth connection problems
I cannot say I have the answer to this, but I am using a Jabra JX10 and it is working well. I previously had a Nokia 6256i, which I loved, but wouldn't work with the bluetooth at all. If you have not tried a Jabra, I would recommend it. Also, if you haven;t tried for a replacement phone, consider the possibility it might be the phone itself.
Oct 18, 2008 | Palm Treo 500 Centro
Palm Treo 500 Centro Logo
106 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
