Question about GE WM1050 Digital Camera
Lens error and there spill of oil inside. - GE WM1050 Digital Camera
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Jan 26, 2011
How to clean lens on rca projection tv model# p61960 ?
Unless something got spilled inside the TV, I suggest you think otherwise about cleaning inside the TV. You will only make things worse by doing so.
Aug 21, 2014 | Televison & Video
Spark plugs is soot black and there's a check engine msg after oil spilled on the engine when i forgot to cover cyclinder head oil cover
the black soot may be old plug wires that should be replaced chances are the spilled oil caused the engine to miss fire setting off the check engine check the inside of the plug boots and plugs for oil.
Feb 21, 2011 | 1996 Toyota Corolla
Mitsubishi WT-36809 turns on for 2 seconds and then turns off. The error code is 22. Any ideas?
Verify the model number. Some of these Mits. family have bad picture tubes, and oil spills out onto the signal board. Look inside front panel, RHS tube, look below it onto signal board. If you see an oil puddle, then tv is toast!
Jan 18, 2011 | Mitsubishi WT-46809 46" Rear Projection...
Error 99 canon 30d slr camera
err 99 is moisture or dew inside the camera.
May 11, 2009 | Canon EOS 30D Digital Camera with 18-55...
Oil Leak spilling oil on driver's side floor inside car
if it was an oil like substance it sounds like it might be freon from your a/c a line might have finally broke in the HVAC witch is in the dash and that sound like the problem hope this helps
Jan 17, 2009 | 1990 Toyota Corolla
I have a canon powershot SD850 IS digital ELPH camera. Every time i turn the camera on it beeps three times and says "Lens Error, Restart Camera" then it shuts off.
Lens errors are displayed when the camera cannot move the lens or something is slowing it down.
Accidental damage may have occured including the possibility of it being dropped or having something spilled inside of it.
Determine whether or not you have a service plan on that camera from the retailed you purchased it from.
If not, call Canon for repair estimates. If it just happened all of a sudden this it may still be under the warranty. If they determine its accidental (or mainly not the cameras fault) additional charges will apply.
Nov 06, 2008 | Cameras
Error 99 can't make a shot
the lens contacts are dirty - get a pencil with an eraser on the end, just a regular old pencil with a red rubber eraser. Detach the lens from the camera, hold it so that the lens’ gold contacts are pointing down and lightly erase their exposed surface, cleaning them of any hand oil that might have gotten on them. Do the same thing with the gold contacts inside the camera body. This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I've used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
Works well for me....let me know how you fair!
Oct 26, 2008 | Canon Digital Rebel / EOS-300D Digital...
Focus error
The lens is having a problem in the track. That can be similar and possibly the same as lens error. that could be caused by dirt or sand inside the camera. What happens is that the dirt or sand can get on the track which has oil or other lubricant and will cause problems with focus and other lens errors.
See my posts on these problems.
You may try to pull the lens as it starts and then push it as you turn it off.
This may also cause more damage, but can be worth a try.
Mar 15, 2008 | Nikon COOLPIX L3 Digital Camera
Blurring/grainy pictures, and lens error
hi
here are some tips that may be the reason why you are having those blurry, grainy and yellowish pics.
It is important to keep your lens away from excessive heat (i.e., hot car in summertime or a heat source in a home). This will help prevent the greases, used in most lens barrels, from breaking down into an oil that can run inside your lens and cause overexposure by slowing down the diaphragm.
Use rear element lens caps on your lenses when they are not on the body. Wide angle lenses, by design, have rear elements that extend out farther then the lens barrel and are susceptible to wear, which can ruin sharpness.
Always use a filter or lens shade (hood) to protect the front element.
Never, ever, oil your lens. A minute amount of oil on the diaphragm blades will cause them to operate slowly.
hope this helps
Jan 22, 2008 | Casio Exilim EX-Z750 Digital Camera
GE WM1050 Digital Camera Logo
Top GE Cameras Experts
Steven Wander
Steven Wander
Are you a GE Camera Expert? Answer questions, earn points and help others
