Question about HP Photosmart C7250 All-In-One Thermal Printer
The light by the card slots flashes continually and I can't close the machine and my wireless home network cannot communicate with the printer. I cannot turn it off using the power button and it does not react to pressing any of the other buttons. On the display I get a picture of the power button with B851FE84. How can I resolve this problem?
  • jclaudebinet Nov 09, 2010
    I did all u recommended and there are no obstructions in the slots. I reconnected the power cable and the problem persists. Could this be caused by an empty ink cartridge? And, what does the message appearing on the printer display mean?
    Thanks Gingko, it worked and in fact one of the catridges was empty.
  • HP Master
  • 19,396 Answers
Hi.
Disconnect the printer power cord.
With power cord OFF use a flashlight to check inside the memory card slot. See if any of the oins is bent or making contact, and check if there is any foreign object.
Connect back power and please let me know how it goes.
Regards.
Ginko.
Posted on Nov 09, 2010
  • Ginko
    Ginko Nov 09, 2010
    The point is that B851FE84 is not an error code. It is a memory location in Hex returned by several HP models when an error is encountered.
    HP did never investigate the problem, and no real fix or bulletin has issued.
    Try following factory reset :
    Turn off printer by holding button.
    Disconnect power cord.
    Hold down both the # and 6 keys at the same time.
    Connect power cord back while still holding the two keys.
    Wait ten second after plugging back, then release the keys.
    Turn printer on using the on button.
  • Ginko
    Ginko Nov 09, 2010
    Hi.
    Good to know.
    Have a good day.
    Ginko.
Cannot get the wireless connection to work on the printer. The USB cable is connected to the back of the PCU. I've installed and uninstalled twice and nothing. It did work when I first got it and...
Here are some guidelines to identify and fix your wireless communication issue:
  • What is the status of the Wi-Fi light on the printer? Green light means that it's connected to a wireless network while Orange light means it's not connected to a network.
  • Try to print the printer's wireless network settings to determine if it's connected to your own wireless network. On the printer operator panel, touch the Setup button > Network Setup > Print Setup Page. Your printer will then print the its wireless network information page. Ensure that the printer is connected to your network by checking the Network Card Status, Wireless SSID, Quality or Trouble Code.
  • If printer is not connected to your network, you may need to reset your printer's wireless network settings. On the printer operator panel, press Setup button > Network Setup > Reset Network Settings. The Wi-Fi light on the printer will momentarily turn off then back on to solid orange. You can then run the Wireless Setup Utility application on your computer to reconfigure the printer to connect to your wireless network. On your computer, launch the Lexmark Printer Home application > go to Settings tab > Wireless Setup Utility. Please follow the instructions on your computer screen.
If you still need assistance, please contact Lexmark Technical Support Center for additional assistance.
Aug 21, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
I have a D-link DGS-1005G. I have two computers connected and a printer. The D-Link is also connected via LAN. I can obtain internet connection to each computer with wireless and the printer will not...
Hi, you have to set up your printer as a device that can be communicated in your LAN by the two PCs.
To set up your printer properly in the LAN, you need to assign a fixed IP to this printer such that whenever it is switch on again, both PC still communicate to this printer without changing the new IP assigned to this printer.
You need to set up this fixed IP properly in your DLink router. For guidance please check this in your user manual of the Dlink. Please let me know any problem you may have again in future.
Aug 10, 2011 | D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps...
My printer wireless indicator is flashing red and I cannot print
The flashing status of the WiFi light on the printer indicates that it's either trying to connect to a wireless network or it has gotten disconnected from your wireless network.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, check the WiFi light status. Try to print again.
You may also refer to this article: Wireless & Network Communication Issues with 2008 Lexmark Inkjet Products
Jul 05, 2011 | Lexmark Z2420 Printer
My Lexmark Z1420 wireless printer used to work perfectly; however, since we moved, I can't get it to work. We have wireless internet. I have reinstalled the driver. I have checked the cables. I...
Your printer may need to be reset. Disconnect your printer from your computer. Unload the sheets of paper from the feeder. Open the printer cover and remove the cartridges. While the cover is open, check for any paper jams or obstructions in the paper path and the cartridge carrier's path. If all is clear, close the printer cover. Unplug and re-plug the printer into the power source to reset it.
When the printer turns on, reinsert one cartridge first. Close the cover. Check for any errors. If no error, reinsert the other cartridge. Replace whichever cartridge is causing the error to appear. You can also try to reinsert a different known working cartridge to determine if the other is faulty.
For your wireless connection problem, you may need to reset the printer's wireless network settings first. Please refer to How to Reset the Z1400 and Z1500 Series Network Settings.
To reconnect the printer to your wireless network, re-launch Lexmark Wireless Setup Utility on your computer.
Jun 21, 2011 | Lexmark Z1420 InkJet Photo Printer
Wifi light flashing orange. communucation failed
The flashing light indicates that the printer is trying to connect to a network or is not connected to a network. This article Wireless & Network Communication Issues with 2008 Lexmark Inkjet Products will help you identify and resolve the issue.
May 31, 2011 | Lexmark Z2420 Printer
Light on printer keeps flashing orange. Router is working, if not I could not have wireless, right??? My printer is next to computer and router. Help
If your printer was wirelessly working before, try to unplug/replug your printer to the power outlet. Doing this usually fixes minor communication issues.
If that doesn't help, please reset the wireless network adapter for your printer. On the printer operator panel, press Setup button -> Network Setup -> Reset Network Adapter to Factory Defaults. The WiFi light will momentarily turn off, then turns on steady orange. You can now reconfigure your printer for wireless connection.
May 02, 2011 | Lexmark Prevail Pro705 Wireless All-In-One...
What does it indicates when the wifi light is flashing red in the lexmax z2420
The flashing light indicates that the printer is either trying to connect to a wireless network, a "connection failure" or a communication is not available. This article should give you ways on how to fix wireless connection problems - How to identify a Wireless Communication Problem and Resolution Tips. Hope this helps. Thanks.
Jan 21, 2011 | Lexmark Z2420 Printer
Connected all the points one minute its working, next time i turn it on, the light does'nt turn on. there was always a loose connection but now how ever hard i try the light is not going on.
HP has designed an easy-to-use Network Diagnostic Utility tool to help you identify and fix common problems when installing or using HP printers on your home network. Let the Wizard guide you through the following troubleshooting steps to make sure your printer connects to the network:
  • Identify network and Internet connection problems.
  • Identify communication problems between the printer and the network.
  • Check for required HP software to connect your printer over the network.
  • Troubleshoot firewalls blocking communication.
NOTE: The HP Network Diagnostic Utility is a Windows tool only. c01647276.gifTip : For general information about wireless networking, visit HP's Wireless Printing Center (in English). How do I get the Network Diagnostic Utility? Follow these steps to download and install the HP Network Diagnostic Utility on your computer.
  1. Right-click the following link, and then click Open in New Window . Link to tool (right-click) File size c02237693.gif HP Network Diagnostic Utility 2.72M
  2. Make sure you meet the system requirements, click the Download only button, and then click Save to save the tool to your computer.
  3. Browse to the location where you saved the Network Diagnostic Utility , and then double-click the HPHNDU.exe file to run it. If you get a firewall security alert, click Unblock , Accept , Continue , Yes , Allow , or Permit .
Nov 04, 2010 | HP JBL Platinum Computer Speakers
I set up my own wireless network and now my printer will not communicate with my laptop.WIFI light flashes red. Have tried everything to reconnect. Lexmark Z2420.
I suggest you reset the Lexmark Z2420 wireless network adapter. To reset, do the following: With the printer on, press and release the power button. The printer will enter power save mode. Now, press and hold the paper feed button. While holding down the paper feed button, press and release the power button. Continue holding the paper feed button for 30 seconds. Release the paper feed button. This will reset the internal network adapter (INA). When the printer has been reset, a solid orange Wi-Fi indicator light should appear. If Wi-Fi light goes back to flashing red, you have not successfully reset the printer. Start the procedure again. Once you have a solid orange Wi-Fi light, reconfigure the printer for wireless connection. Thanks.
Jul 29, 2010 | Lexmark Z2420 Printer
Cannot get truemobile 2300 to communicate with linksys usb network adapter Wireless light does not show in truemobile 2300 and link light does not light up on network adapter
To isolate the problem try installing the adapter to a different computer and if it works there it could be that your card slot is defective. As for the router try to reset it
Mar 06, 2010 | Dell TrueMobile 2300 Wireless Broadband...
HP Photosmart C7250 All-In-One Thermal Printer Logo
158 people viewed this question
Seeker5211
Seeker5211
