Question about Mr. Heater Mr Heater Portable Buddy Propane Heater
My heater doesn't seem to be getting any propane flow and I've replaced tanks with no change. What else can I check?
I am have the same problem and was told to clean the oriffaces with a fine wire (to remove rust/dust). Sounds easy but trying to take it appart to actualy do this may be a bit more complicated.
Posted on Nov 28, 2010
We replaced the regulator and the grill still does not have big flame always seem to be on low despite knob adjustment
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 30, 2014 | KitchenAid Superba KFRS271TSS Stainless...
Low water pressure
Hi Bob,
You can determine if the tank is the problem by connecting a garden hose to the drain that is provided on most water heaters. Before doing this, be sure to shut of the electrical supply to the heater - otherwise you can damage heating elements if an electric type or waste fuel by heating an empty tank if a gas / propane fired type.
If you get a slow flow out of this drain, it means that somewhere in the cold water supply side to / in the tank - there is a problem. Inside the tank, the cold water is delivered by a "dip tube" that distributes the cold water to the bottom in the tank. Dip tubes are used in both electric and gas / propane fueled heaters. Here's a cut away view of a typical tank:
If the tube is clogged, or there is build up, scale or debris in the supply (cold water) side of the heater, flow rates will suffer. Likewise, if there is a problem with the output of the tank, it will directly affect flow as well.
If you get a good flow rate from the drain, then the issue is going to be on the hot water output side of the heater. Again, the same build up, scale, debris issues on the hot water out put pipe will cause problems with flow. Typcial tanks do not have dip tubes for the hot water side of the tank - as taking hot water from the top of the tank is most desireable and is furthest away from the cold water that rushes in to make up the hot hot water going out.
There's nothing really in the tank itself that can cause issues with flow outside of the dip tube, and piping to and from the tank.
Jun 29, 2012 | Water Heaters
My grill has full propane bottle but doesn't seem to be getting propane! Any help would be appreciated.
Check there is gas at the burners and that the orfices are not block or the burners are bot blocked .
Turn on burners let pressure out of line turn off tank remove gas line then reconnect to tank and turn on tank slowly see if this works
Mar 12, 2012 | Weber Baby Q Grill
I got a new tank on and heater will not ignite. I drained the previous propane tank.
Check to see if the nipple is seated to the tank the o-rings will get hard and prevent a good seal and will not let you tighten up the regulated line to the tank. At work we spray WD40 on these o-rings and this lets us tighten things all the way, also check the tank itself make sure that propane will flow out of the spring loaded ball assembly,(try it on say a gas grill)
Dec 13, 2010 | Heating & Cooling
Connecting Reddy HD30 to RV Propane Tank
pipe feed could be too small poor flow of gas or flamesafety is cutting in
May 26, 2010 | Reddy HD30 Heater
Noritz tank less propane water heater, no out going pressure
There's a filter on the cold water side of the unit. You'll notice a black, plastic, cylindrical component directly below the unit on the cold water line pointing to the left. If you shut of your water and unscrew that cap, there will be a filter attached to the other end.
If the filter is clean, I'd recommend calling tech support for help. You might have an error code.
Jan 08, 2010 | Noritz Liquid Propane Tankless Water...
Patio Heater SRPH02 will not light in cold weather
you may need someone to come in and adjust your pressure regulator that is inline to heater this is what controls the output of propane and should only be adjusted by a pro
Apr 15, 2009 | Coleman 5040-751 BackHome Open Flame Patio...
Propane heater wont work
I'm not sure about that model, but I think you have to hold that button down for a minute or more to "prime" it.
I have a different model coleman propane heater that sits on the 20# tank. Mine is probably getting rusty, last time I used it I had to hold that button down for a long time.
I'm looking for a new heater now myself, as mine won't stay lit outdoors in much wind.
Dec 22, 2008 | Heating & Cooling
Heating & Cooling Logo
215 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Mack Baxter
vance jones
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
