Question about Kinamax IP-USBPH Skype IP Phone
I have a usb phone, and i need driver software v2.0,i the software on a mini disc, and i do not a mini drive on my computer ??
Software disc is too small, macbook pro will not accept the disc
Hi, if the Macbook can't read the Mini discs, you can copy the contents of the Mini Disc to any USB Flash Drive by inserting the Mini Disc in any Desktop Computer's CD/DVD Drive. After copying the Mini disc contents to USB Flash Drive you can install in the Macbook pro. var geo_Partner = '843689b9-ba30-459d-9c4b-876924715b22'; var geo_isCG = true;
Jun 11, 2011 | Targus Portable USB Notebook Mouse &...
How to transfer from the tape to computer to burn a dvd
To transfer your canon data in tape, you need to install driver of canon mini dv in your computer. Then paired your canon with computer trough usb to make data transferring. To burn a dvd disc you need to install software for dvd burner like Nero S in your computer to edit your AV and burn into DVD disc. Make sure your computer have DVD R/W to do so.
Regards. Jay
Dec 26, 2010 | Canon MV530i Mini DV Digital Camcorder
Need and and all USB Drivers for my Panasonic PV-GS180 Video Cam.. I want to use the USB to transfer my media from Camera to Computer. Thankyou.
You can use the disc that is provided with the cam install the software from the disc then connect the cam with the PC and wait a while until the driver get installed.
Aug 18, 2010 | Panasonic PV-GS180 Mini DV Digital...
How could i install samsung on my computer without using cd installer
If your computer does not have a CD drive then -
There are two methods.
1. Purchase or borrow an USB external CD/DVD drive connect it to the mini laptop's USB port and install the software from this drive.
2. Use a different computer and copy the contents of the CD to an USB memory stick and then plug it into the mini laptop's USB port and install the software from this USB memory stick.
OR
If you have lost the installation CD then I suggest you go to the Samsung WEB site and download the installer file for your model cell phone.
Mar 24, 2010 | Samsung SGH-i900 Omnia Unlocked Cellular...
I have a netbook computer which comes without a cd drive and I want to install my printer
There are two methods to install the printer driver.
Mar 22, 2010 | Lexmark X1270 All-In-One InkJet Printer
I have the cd that does not fit into my macbook for the dx-crmn-1
you could put the mini-cd into another computer and put all the files on another cd or a flash drive then transfer to the macbook.
Jan 18, 2010 | Dynex 5-in-1 USB 2.0 Mini Memory Card...
My stick is not turning on when i plug it into the computer
First, check all the usb ports with this drive, if they all don't work then most likely it is a driver issue. Load the drivers from the mini disc that came with the Cruzer....these drives like it when their U3 program is installed on the computer...they do not like to work independant of the program running in the background. These drives also do not lie to operate through a usb hub or portal. If you don't have the drivers disc, check the link below for the drivers.....scroll down the page and their will be links to the software.
http://www.mydigitallife.info/2007/05/24/reinstall-or-restore-u3-launchpad-software-into-usb-flash-smart-drive/
Nov 03, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Software
Qwest mobile IS Sprint! (at least for now)
Are you using the same phone you bought the cable for?
You really shouldnt need to use software. Once your phone is connected via USB you can open it like a removable drive. assuming the cable is the correct one for the phone.
May 29, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Software of motorola L6i
you should be able to just plug your phone into the computer and it will recognize the mini usb port and install itself . You can go into my computer and it will be a removable drive that you can drag and drop files into
Mar 19, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Connecting to computer
You should have got a sofware disc with the handycam when you bought it.if you load the disc it should accept the video on usb.if you dont have the disc try sonys website for software,.
May 15, 2007 | Sony Handycam DCR-HC36 Mini DV Digital...
Kinamax IP-USBPH Skype IP Phone Logo
114 people viewed this question
Top Kinamax Computers & Internet Experts
David Payne
David Payne
Are you a Kinamax Computer and Internet Expert? Answer questions, earn points and help others
