Question about Kenwood Food Processors
Kenwood Multipro fp730 - won't work, the bowl and lid are locked into place but it still won't run. I have changed the fuse and that hasn't made any difference. It is only 18 months old and hardly ever used.
  • Anonymous Mar 12, 2014
    I can't get the lid part out of the bowl part of my kenwood FPM250. It's lock in place properly but I can't unlock it. How can I do ?
New magimix won't start
It is most likely the way the bowl and lid are set.
Facing the machine:
the bowl locks in, with the handle to your right directly above the switches. The lid has a double tab...see underside of the top of the lid. Place the lid on tightly with both tabs locked into bowls handle. It really clicks in.
Feb 01, 2013 | Magimix 4100 Cuisine Systeme 1268 Cups...
Tip
The cusinart pro classic food processor is not working ?
Try this procedure:-- It usually goes something like this, with minor variations depending on model number:1.Remove the work bowl completely from the base
2.Plug the food processor in and turn it on
3.Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4.Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the work bowl
5.Place the lid on the work bowl with the tab slightly left of the center of the work bowl handle – slide the lid counterclockwise until it won’t slide any more
6.Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7.Slide the lock to the right into the locked position
The food processor should now work.
This will help.Good luck.
on Mar 08, 2010 | Food Processors
How do i use centrifugal juicer?
The Instruction Manual for the Kenwood FP730 Multipro Food Processor can be found online here:
http://www.kenwoodworld.com/Global/Instruction%20books%20(User%20manuals)/Food_Processors/57832%20Iss%203%20B5%20FP730%20English%20only.pdf
On page 7 you will find illustrated instructions for the assembly and operation of the centrifugal juicer.
Dec 03, 2011 | Kenwood Multi Pro FP730 Food Processor
I Cuisanart mini prep and removed the bowl, lid,
Make sure the tab on the lid is making contact with the "tower" in the back and that the work bowl is locked properly into place so that the plastic tabs show on each side toward the bottom of the work bowl.
Aug 12, 2009 | Cuisinart DLC-2 Mini Prep Plus Food...
I have a cusinart pro classic, went to use it yesterday, filled it and turned in on, got nothing. i tried a different plug and still nothing. it is not even making a sound.
1. Remove the work bowl completely from the base
2. Plug the food processor in and turn it on
3. Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4. Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the workbowl
5. Place the lid on the workbowl with the tab slightly left of the center of the workbowl handle – slide the lid counterclockwise until it won’t slide any more
6. Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7. Slide the lock to the right into the locked position
-Tha Mp3 Doctor
Oct 19, 2008 | Cuisinart DLC-10S Pro Classic Food...
Food processor
-Tha Mp3 Doctor
Apr 20, 2008 | Cuisinart DLC-10S Pro Classic Food...
My food processer does not work
I had the exact same problem. The red light came on when I hit the "On" button, but nothing happened. Then I noticed that when the lid is locked into place, a small pin in the handle goes into a small hole in the base. I took a wooden chopstick and poked it in this hole in the base, and the unit started running. I put the bowl and lid back on the unit and locked them into place, and this time the unit ran just fine. Yeah! I will remember this the next time my unit won't run even though I know that I've properly locked down the bowl and lid. Good luck!
Oct 11, 2007 | KitchenAid KFP750 Food Processor
Food Processors Logo
929 people viewed this question
Top Kenwood Food Processors Experts
Ross Keen
Mitch Vass
Mitch Vass
Are you a Kenwood Food Processor Expert? Answer questions, earn points and help others
