Question about Samsung HCN653W 65" Rear Projection Television
My tv is working normal but the picture has some waves, amean they are't to bad.. after while you dont see them because you get used to them, how can i fix it? thank you.. samsung model hcn653w
  • 1 more comment
  • gabriel leon Nov 10, 2010
    you mean take a picture and send it to you?
  • gabriel leon Nov 12, 2010
    i took several pictures but you can't see anything, it loos like a tv with poor antena signal
  • gabriel leon Nov 15, 2010
    yes it does, and you can tell more when the tv has no pic, like when the pic is dark
  • 4,889 Answers
Can you please upload an image to imageshack.us and get me the link so that I can see for myself what it looks like?
Posted on Nov 09, 2010
  • 1 more comment
  • eagle338
    eagle338 Nov 10, 2010
    Yes thats what I meant.
  • eagle338
    eagle338 Nov 12, 2010
    Does it happen on all input types like component, HDMI? ALso does it happen with different sources like DVD, tv receiver etc.,?
  • eagle338
    eagle338 Nov 15, 2010
    If it happens even when you don't have an image, it sounds more like electronic interference. Any electric wires crossing the video input cables(like HDMI) or anything that emits microwaves like an oven. For some reason, it does not look like a tv problem to me. So lets see
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
DISPLAY BUTTOM FLASHED 5 TIMES . THEN THE TV TURNDS OFF IN 30 SECONDS. THEY DISPAY BUTTOM KEEPS BLINKS 5 TIMES WITGH NO PICTURE. AT FIRST I COULD HEAR THE TV NOW NOTHING. THE MODEL#KP-57WS520 SERIAL#...
Hi
Thanks for using FixYa. You need to check the horizontal and vertical output wave form at the high side of the deflection which should be a normal horizontal/vertical pulse respectively. Now check the HV output transistor on all three elements and also check the regulator transistor which might have short. Replace the parts/diodes which are gone bad and can be easily replaced. You can order these from the following link --
Projection TV spares parts
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 09, 2009 | Televison & Video
3d rainbow pictures..with colorful waves..and no convergence menu to fix it.
You will need to replace the FL231, DL231 and CL230 you can get the parts with free instructions with pictures at the following link. The parts are all listed under the RCA parts category total cost is about 11.00 http://servicemanuals.vstore.ca/
May 14, 2009 | RCA HD61W66 61" Projection HDTV
VIDEO TAPE WHEN PLAYED WAVE AT THE TOP OF THE TV SCREEN
This is a common problem usually seen when playing copy protected tapes. The part of the picture affected is normally off the top of the screen. Sometimes the problem is also due to the VCR itself and differences in tapes. It's also possible for the TV itself to be causing this, although you would probably also notice this flag-waving (that's what it's called) on regular TV viewing if that were true.
Sometimes increasing the height of the picture can push the affected area off the top again. But this can also cause you to lose part of the picture you want. Also, the height adjustment may be difficult to find as it's not something normally used. On some TV's it's a small pot somewhere on the board, but most newer sets have electronic adjustments through a service menu that you need to know how to access.
I'd suggest trying another VCR first and play one of the tapes you know shows the trouble. That might be all it takes. Then consider trying to increase the picture height if it's just a small bit at the top of the screen.
Mar 12, 2009 | Zenith B25A11Z 25" TV
My Toshiba 57H81 has a 'jittery' picture.
I have the same prob need to change the resistors as a first resolution. there should be 5 of them, if you dont soon and i mean soon you could cause the skt to go bad and have to start over in your repair
Mar 08, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba 50hp66 picture waves
Please describe the 'waves' and what you are watching when it happens, is it on everything? e.g. normal TV and when watching a DVD? Are the Waves a grey close pattern going diagonally across the screen for some other sort of pattern?
John
Jun 13, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Glitchy power
Clearly your TV is shutting down due to a problem. Based on your description, it's hard to tell if you have a vertical or convergence failure. What do you mean by "waving" line ?
Feb 01, 2008 | Samsung HCM422W 42" Rear Projection...
Panasonic
Throw out the vcr. It could be that the heads inside of it have gone bad. If this doesnt work let me know.
Dec 11, 2007 | Televison & Video
Jvc television
picture on tv started waving in & out
normally this problem is due to main filter capacitor failure in tv which is located in power supply.it becomes dry after few years
you can also check for normal voltage at input to your home.
hope this will help
good luck.
Oct 12, 2007 | Televison & Video
RCA 25GT536 picture has a horisonal wave or wiggle that scrolls from the bottom of the picture up to the top and then repeats. TV worked great before a power surge. Sound is still good.
Any kind of wave form usually is cause by a bad filter, the question is if it's in the powersupply or horizontal section. I would first start with PS. Look for bad capacitors.
Sep 23, 2007 | Televison & Video
Samsung HCN653W 65" Rear Projection Television Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
