Question about Dometic Rooftop RV Air Conditioner
DUO THERM Model 57915.622 runs and cools fine, but why does it drip water inside on the floor?
Are there any drains I should check? I have two units on my RV. Only one of them is dripping water.
    Novelist:
    Champion:
  • 230 Answers
I am not en expert at RV A/C units. I have worked on a couple before. There should be a reservoir somewhere under the evaporator coil(looks kind of like a radiator in a car but much smaller). It should have a hose or something to drain it away from the a/c unit. These very often become plugged on any kind of A/C unit. However if you choose to do this on your own, you will have to climb on top of the RV and remove the cover from the a/c unit to do this. It might be safer to take it to an RV repair shop.
Posted on Jun 16, 2008
  • Noah Outlaw Feb 11, 2011
    It would be safer, as would anything you got someone else to do, but this is not brain surgery and should easily be accomplished by anyone.
Quantum hi-tech web cam softwair
I have a duo therm model 57915 522c1 air unit on my camper. Turned it on and was working fine. Then it shut down. Doing nothing now. Any ideas?
water draining from condensate hole ??? if not its shut off on high water level (you don't want water dripping into your nice camper right ?)
bees are my nemesis on these they love to build mud nests in the drain holes and stop em up !!
Aug 25, 2016 | Heating & Cooling
Why is my Duo-Therm 57908 rv air conditioner dripping water?
Is it dripping in the inside of the rv? You may have a plugged filter or the air filter is missing and the cooling coil is blocked with a mat of dirt. If its running down the outside of the vehicle you might find that the condenser coil is blocked with a mat of dirt collected while running. I would say you will need to go up top and pull the cover and inspect the coils. Be careful not to bend the fins while carefully brushing with a nylon brush. Hope this helped and good luck.
Oct 09, 2014 | Heating & Cooling
Duo Therm dripping water in camper when shut off. My Dometic Duo Therm Ducted AC drips quite a bit of water when shut off after running for several hours on hot humid days. The condensate lines are open....
Remove the filter at ceiling and run the AC on cool etc, and see if you can feel cool air leaking across to return air inlet where the divider between cold and return is. Check along all edges, etc for any cool air . Careful of wiring, but you should be able to get hand in there and feel especially around the edges where it should be sealed tight. Quite often a leak in that area causes cold air to enter return air and causes excessive condensation. Another thing to check is look way up inside opening for return air, with a flashlight and see if any dirt/dust on coils and fins of evaporator, and if so, needs to be cleaned off with a vacuum, and brush attachment. Let me know what you find.
Jul 10, 2010 | Dometic Rooftop RV Air Conditioner
I have a whirlpool refrigerator which is running cold freezer or and regrigerator is fine but we are finding water inside regrigerator and seems to be dripping from a cooling box what can i do to resolve...
check the drain hose in the rear area for breaks in the hose or maybe plugged up with mold in the drain line and not able to drain to the lower pan near the floor
Apr 19, 2010 | Refrigerators
Duo Therm Fan Blows, No cool air. Worked yesterday, not today?
most likely compressor running could be capacitor, breaker,relay,or compressor it self start by checking power to unit
Aug 22, 2009 | Heating & Cooling
Ice forming on inside of unit air not cold
clean the filters and check the drain, to clear the drain run a jug of warm water down the pipe
Aug 19, 2009 | Dometic Rooftop RV Air Conditioner
Dometic air conditioner blowing cool air
When the cooling slows down, but water is still running off, usually something is icing up. You can turn the unit off, and let it thaw, and try again. Sometimes, if the humidity is high, this is more pronounced. It sounds like you are low on refrigerant. That implies that you have a slight leak. You should have the unit serviced, and the leak repaired.
Best regards, --W/D--
Aug 01, 2009 | Dometic Rooftop RV Air Conditioner
I have a duo therm brisk air model 57915-001 leak
Could be the drain path is clogged.. Take the cover off & see if you can get it cleaned..
Jul 09, 2009 | Dometic Rooftop RV Air Conditioner
Location of Drain holes on Duo-Therm Model 630035.321
Good place to start is up on the roof. Look way under the unit (hard to see some times) along the bottom, between where the gasket sits on the roof and metal bottom of unit. Should see small round or similar sticking down from unit. There will be a hole in the side of them. Poke around with a wire or something to open them up. If you don't see water/condensation running across your roof from unit when it's operating, (usually in 2 directions, 1 each side of unit) then yup, there plugged.
Aug 05, 2008 | Dometic Rooftop RV Air Conditioner
Rv air conditioner leaking
I have the same problem....it is a negative pressure problem holding water inside the unit until it overflows the pan and runs into the duct system. why this occurs....I don't know....I cant find a problem with my air return, but as soon as you turn in off, the water comes gushing out the drains on the unit. I resolved this....temporarily....by twisting up a paper towel into a wick, and placing one end up into the drain tray, with the other end lying well out into the exterior case. This lets the water wick out and keeps the tray drained. I don't understand the problem and don't know what the permanent fix will be, except maybe cutting a hole and placing an intake vent directly below the unit.
Jul 16, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
1,229 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
