Question about Frigidaire Dryers
GLEQ215EE 5.8 C.F. Dryer won't come on, no display nothing. Like it has no power. I worked fine yesterday, today nothing. I checked and reset breaker. Still nothing.
  • alanrausch Nov 09, 2010
    I will check all that when I get home. We may have had a power surge also, the electric power company was working on the pole outside, and we other circuits blow in the house while we were not home.
  • Frigidaire Master
  • 19,396 Answers
Hi.
You need to get to the back of the appliance and check power cord and wall socket. If power cord is fused, check fuse in power cord. Test the wallsocket.
If power inlet is OK, then more parts must be tested.
The door latch must be tested jumping its contacts. Wiring to motor and to control module must be tested using a volt meter or a multimeter set on impedance. Reading impedance is safer because it can be done with power off.
Below wiring diagram for this model. Click on the picture to enlarge:
Regards.
Ginko.
Posted on Nov 09, 2010
  • Ginko
    Ginko Nov 09, 2010
    The power surge is probably at source of problem. If a power surge damaged more appliances in the house, then the main controller board may be faulty. As you can see from diagram, in this model power cord goes straight to main control circuit and to motor, with no fuse in the middle.
    Remember to observe safety prescriptions when testing. Always disconnect power. Wiring can be tested in a safer way by reading Ohms on cables, so to check if there is continuity between to points( circuit closed, low impedance) rather than reading volts.
    Regards.
    Ginko.
Dryer will not start
It is possible the cord/pigtail connections were not tightened enough and have burnt off.
May 01, 2014 | Dryers
Frigidare dryer gleq215ee won't heat then shuts off after about 10 minutes. 4 lights on right flash. no error code comes on. I am pretty handy and can take apart and fix. would need to know what t
Hello John Sterns - First, try resetting the unit dryer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. Restart unit and if it proves to be ineffective then typically this is something that a professional would need to diagnose. Since it is such a complex unit, there are multiple possible causes; faulty power cord, house wiring, defective control board, thermal limiter or door switch.
Dec 09, 2012 | Frigidaire Electric Dryer
My Panasonic PT-47X54J won't turn on at all
The power indicator should blink 1-5 blinks when it wont power up. If you let me know how many blinks your getting I can assist with the problem.
Nov 06, 2012 | Televison & Video
My roper dryer worked fine yesterday. It won't work today
remove back cover then locate the blower housing in the back,its round on this is a thermal fuse appx. 1" X 1/4" with 2 wires from it,this is the thermal fuse test it,if its open on continuity its bad and the dryer wont operate the pat number is FSR# 3392519
May 21, 2012 | Roper REX3614KW Electric Dryer
I have a roper washer 5 years old and it won't drain or turn on now it was working fine yesterday ive unplugged replugged pulled out all the clothes checked power supply and hoses what now?
I looked up your model number. You particular machine allows for wash with the lid open. You nothing happens. On that case I would check the motor capacitor.
Nov 13, 2011 | Roper RAS8445KQ Top Load Washer
I have my PS3 plugged into my tv with an HDMI cable, and it was wroking fine just yesterday. But today I moved it back to my living room tv where it usually is but nothing shows up. It just says...
Please do the following to reset your display -
1. Turn the PS3 off into standby mode (red light on)
2. Press and hold the power button for 2 beeps (the first beep will be when you first press the button and the second beep will be around 5 seconds later)
3. Release the power button after you hear the second beep
4. Wait for the display to restart
Hope this helps and thank you for using FixYa
Jan 13, 2011 | Video Game Consoles & Games
The unit runs but no heat.
Your limit switch has tripped. You will find this small switch near the burner that is the size of a dime. Press the small button between the wires firmly to reset it.
Apr 16, 2009 | Dryers
Kenmore Dryer 62802 Doesn't Heat
sounds like the heating element has gone south
if you open up the dryer you can check continuity across the element but make sure power is unplugged
Apr 13, 2009 | Kenmore 62802 Electric Dryer
Dryers Logo
62 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
