Question about Dewalt DW746X 10" woodworker's table saw with rai
My d27105 is blowing the 13amp fuse in the plug ?
  • Dewalt Master
  • 7,733 Answers
If it continue to do it the machine had a "short circuit".So inspect the machine and look for any brake cable the is touch any metal part of it.
Posted on Nov 09, 2010
Awz8812 blows fuse
what 13 amp external fuse are you speaking about? if this is a power line fuse feeding the dryer then its way too small normally you use 2 30 amp fuses or a 30 amp tandem pole breaker to power the receptacle where the dryer plug plugs in
May 05, 2012 | Whirlpool GEW9250 Electric Dryer
Amperage required to run a 180 amp welder
If you mean the plug rating, you can run a 180amp mig welder on a 13amp plug, however above about 150 amps the fuse in the plug will blow, you then need to up grade to a 16 amp plug and wall socket, with the wall wiring going back to a fuse box with a 20amp fuse.
Jun 16, 2011 | Miller 041969 Secondary Contactor Kit
The microwave just stoped working.
check the fuse that's in the plug check it with a multi meter on continuity test bye putting the meter on both end of the fuse the meter should beep or you should get some sort a resistance from it if the fuse is ok other solution is taking a fuse out some other house hold appliance that you know works and try the fuse from that in it make sure its the same amp as the one you take out you microwave or close to it it will blow strait away if its to low a fuse rating think its 13amp
Feb 11, 2011 | Microwave Ovens
My dewalt d27105 saw keeps blowing a fuse, could it be the module
These saws have a rather large amount of draw on a 15 amp breaker... they should be able to operate on a 15 amp breaker, however nothing else can share that breaker.... and if it is an outside plug (GFI) it will be even more likely to trip. If possible, use a 20 amp breaker...they can be found in the garage where central vacuum plugs in. If this isn't an option then ensure nothing else is on a normal 15 amp breaker, use a heavy gauge extension cord, and the shorter the cord the better.
May 25, 2010 | Dewalt DW746X 10" woodworker's table saw...
Blown fuses
please check your fuse box, it must have 22amps fuse. if not than upgrade it.
if your fuse is of 22amps or above, than my friend you have to replace your switch...............thank you and have a nice day
May 14, 2009 | Hotpoint Ultima WF860 Front Load Washer
Sanyo EMS1000 microwave. Keeps blowing 13amp plug fuse.
New or older wiring to microwave? Is there a GFI circuit installed?
Apr 27, 2009 | Maytag MMC5000 Microwave Oven
Diplomat integrated oven- 13amp?
You need to get an electrician to wire it in to a 30amp cooker outlet. It is 30amp rather than 13amp (like most sockets). It should go to its own fuse in the fuebox
Feb 22, 2009 | Belling XOU592 / XOU593 Electric Double...
Plug amp
Yes it should be safe to use a 13 amp fuse.
The convention with fuses is up to 720 watts a 3 amp fuse should be used and above 720 watts a 13 amp fuse should be used.
To be precise you need to know the exact wattage of the kettle.
Sometimes maufacturers will fit 5 amp fuses but these are only good for a power rating of 1200 watts maximum (at 240 volts).
So as your kettle is rated at more than 1200 watts it needs a 13 amp fuse.
Hope this is a FixYa.
Oct 20, 2008 | Breville SK85XL Nova Cordless Electric...
Indesit washing machine wdg1295w blowing fuse
Proberly carbon brushes in motor,Can be supplied if req.grandadfixer
Oct 11, 2008 | Indesit W 123 Front Load Washer
Dewalt DW746X 10" woodworker's table saw with rai Logo
240 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
