Question about Tomtom ONE XL GPS
I go to open up my Tomtomhome 2.7 and I get this: TomTomHomeRuntime, exefailed with error 0: Process failed to start up correctly.
I have just purchased a Tomtom GO 750 Live. Tomtom home 2.7 does not run on Windows 7 ultimate (32 bit). When I try to open up my Tomtomhome 2.7, I get this:
Posted on Dec 11, 2010
Error 08,045,43:42128
Hi Here are some codes for you
8,009.4x:CAP_FAULT_MP_NO_ CLUTCH_STALL:
  • The media path motor has stalled while moving without the clutch engaged.
33,001.4x - TM_DEV_FAULT_MPT_WIDTH_VALUE_TOO_LOW
  • Tray 1 status:
1. Check the wiring and connectors from the front door to the I/O board.
2. Run the Test Tray 1 Width Sensors.
3. If the test fails replace the front door.
4. Replace the I/O board.
08.055.44:
  • The media path drive module has stalled while engaging the head tilt.
37,008.44:
  • The Preheat preheater is not drawing the expected power from the supply.
Run the Preheat Heater test, check the wiring. If test fails and no apparently problem is evident, replace the preheater.
05,002.42:
  • Problems with the Y-axis. It could be the belt,motor or the drum.
7,008.4x: PM_FAULT_HEADTILT_NOT_ ENGAGED
  • The printhead tilt is not engaged, so it didn't tilt back properly or the printhead is stuck in the tilted position by the tilt lock arms. The process motor gear train getting out of sync can also cause this error.
1. Try rebooting the printer.
2. Check for an obstruction or damage in the process gearbox.
3. Ensure the gears are correctly aligned and homed. If faulty replace the process gearbox
assembly.
4. Run the Tilt Axis Drive test to test the headtilt.
5. Run the Head Maintenance Wiper Clutch test. If the test fails, replace the wiper drive clutch.
6. Run the Wiper Axis Drive test.
7. Replace the exit assembly.
7,010.4x: PM_FAULT_HEADTILT_HOME_ERROR
  • The printhead is stuck in the tilt position by the tilt arms. The process motor gearbox being out of sync can also cause this error.
1. Reboot the printer.
2. Verify the lock arms rotate correctly.
3. Check for spilled ink around the printhead.
4. Check the process motor gears for damage. Ensure the process gears are correctly aligned and homed.
5. Verify the process gear box, process shaft, and drive module shaft are at home position.
6. Verify the headtilt gear will engage, see the home positioning procedure on page. You can manually engage the headtilt gear.
7. Run the Tilt Axis Drive test.
8. Run the Process Motor test.
9. Run the Head Maintenance Clutch test, if the test fails replace the clutch.
10.Run Wiper Drive test. If this fails inspect the wiper drive system.
All Best: Pineworks
Jan 04, 2010 | Xerox Phaser 8400 Laser Printer
Unable to update Tom Tom in windows vista keep getting error 1060 any solutions?
perform the following:
type the following three lines in to the Command window:
%SystemDrive%
cd "%ProgramFiles%\TomTom HOME 2"
xulrunner\HOMERuntime.exe -app xul\application.ini
To avoid having to type these lines every time you start HOME:
Right-click your desktop and choose New > Text Document - enter the commands provided above and then save the file as RunTTH.bat
copy this file to the TomTom HOME 2 folder in C:\Program Files (you will require Administrator rights to do this)
in the Start menu, right click on the TomTom HOME 2 icon.
select Properties
in Target, change "C:\Program Files\TomTom HOME 2\TomTomHOME.exe" to "C:\Program Files\TomTom HOME 2\RunTTH.bat”
The icon will change and HOME 2 should now run normally on your PC.
Please note that links like "Send to TomTom device" or "Add to TomTom" won't work because they rely on TomTomHOME.exe (which this workaround by-passes).
A full fix for this error will be implemented in a future HOME update.
NOTE: for 64 bit Vista change the second line of code to:
cd "%ProgramFiles(x86)%\TomTom HOME 2"
Jul 22, 2009 | Tomtom ONE 125 GPS Receiver
I cannot get tomtom home .The message Home runtime.exe failed with error 0 appears. Please help
i cannot get tomtom home the message home runtime.exe failed with error 0 appears please help before i have to return and get a different make my tomtom tels me to update but want conect , thanks . sean
Jul 09, 2009 | Tomtom GO GPS Receiver
Problem of TomTomHomeRuntime.exe fail at 1058 error. Impossible to run at Vista
check to see whether secondary login service is disabled via services.msc - if it is set it to manual and start it. Problems sould go away - if not unistall and reinstall tomtomHome with this service started.
Jun 11, 2009 | Tomtom ONE XL GPS
Xerox C2424 Error: 07.010.44:152562
Hi design811:
Here is your problem.
7,010.43: The printhead is stuck in the tilted position, or is not tilting properly over
the CAM, due to problems with the process motor gearbox.
1. Reboot the system.
2. Did this correct the problem?
Go to Step 2. Complete.
2 1. Do the printhead lock arms rotate correctly? Go to Step 3. Repair or
replace the lock
arms.
3 1. Is there spilled ink around the printhead? Clean the
printhead area.
Go to Step 4.
4 1.
Check the process gearbox for obstructions
or damaged.
2. Ensure the gears are correctly aligned and
homed.
3. Verify the process shaft and drive module
shaft are at their home positions.
4. Did this correct the problem?
Complete. Go to Step 5.
5 1. Verify the headtilt gear will engage. You can
manually set the headtilt gear.
2. Is the gear engaged properly?
Go to Step 6. Set the headtilt
gear.
6 1. Use service diagnostics to run the Tilt Axis
Drive
test.
2. Did the test fail?
Replace the
process
gearbox.
Go to Step 7.
7 1. Use service diagnostics to run the Process
Motor
test.
Replace the
process motor.
Go to Step 8.
8 1. Use service diagnostics to run the Head
test.
Replace the
wiper drive
clutch.
Go to Step 9.
9 1. Ensure the wiper is properly aligned.
2. Use service diagnostics to run the Wiper
Drive
Test.
3. Did the test fail?
Go to Step 10. Replace the
exit module
assembly.
10 1. Use service diagnostics to run the Load
Maintenance Clutch
test.
Inspect the maintenance drive
system, replace any defective
parts.
Hope this helps
May 21, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Error code 07,010,43:13829 xerox c2424
Hi sales1stsupp:
replace the lock
arms.
printhead area.
Go to Step 4.
or damaged.
homed.
gear.
Drive
test.
Replace the
process
gearbox.
Go to Step 7.
Motor
test.
Replace the
process motor.
Go to Step 8.
test.
Replace the
wiper drive
clutch.
Go to Step 9.
Drive
Test.
exit module
assembly.
Maintenance Clutch
test.
parts
Hope this helps
Apr 22, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
On installing tomtom home on my computer this message comes up homeruntime.exefailed with error 0 process failed to start up correctly
These instructions worked for me with WinXP SP3, how they fair for Vista I can't say.
To solve any issues with Connecting to TomTom Home and/or using the 'Operate my device' feature of TomTom, please do the following:-
STEP 1 Uninstall TomTom Home
- Disconnect your TomTom from your computer.
- Click on Start -> All Programs -> TomTom
- Uninstall All versions of TomTom Home from your PC
- Once Uninstalled, Open 'My Computer'.
- Right click on your 'C' drive and click on 'Search'
- in the boxes below where it says 'All or part of the filename', type 'Navcore' in this box.
- Further down, click on 'More Advanced Options'
- Make sure 'Search System Folders' and 'Search Hidden Files and Folders' are ticked.
- Click on Search
When the search has completed. Delete any files or folders that are found in the search results. Once complete, we need to remove any items on your PC that refer to TomTom, to do this:-
- Open 'My Computer'.
- in the boxes below where it says 'All or part of the filename', type 'TomTom' in this box.
- Click on Search
Once done, reboot your PC.
STEP 2 Perform Some PC Maintenance.
- Empty your Recycle Bin, on your desktop, right click on the recycle bin and choose 'Empty'.
Note: I chose not to perform the Disk Cleanup and Defragmentation, I didn't think that it was a necessary step, but perhaps I am wrong.
- Go to Start -> All Programs -> Accessories -> System Tools
- Do a Disk Cleanup, in the disk cleanup options, make sure all the items are ticked. You will see this after it has analyzed your PC.
- Once finished, do a Disk Defragment.
- When the Disk Defragment has finished, please reboot your computer.
These procedures can take a while to complete, depending on the status of your computer.
STEP 3 Install TomTom Home 2.3
- Click on http://download.tomtom.com/sweet/app...2winlatest.exe
- You will now be prompted to download and install TomTom Home 2.3
- Once Installed, please reboot your PC
STEP 4 Open TomTom Home
- Open TomTom Home without the device connected. Do you get any error messages at this point?
- Connect your TomTom to one of the USB ports on the back of your PC
- Switch the TomTom on. Do you get any error messages at this point when you open TomTom Home?
Hopefully these steps should resolve a majority of the issues encountered when starting TomTom Home and getting the "HOMEruntime.exe failed with error 0: Process failed to start up correctly" error message.
Regards.
Oct 06, 2008 | Computers & Internet
PHASER 8550D error report 07,010.43:217298
replace the clutch.
drive system.
Sep 24, 2008 | Office Equipment & Supplies
Tomtom ONE XL GPS Logo
344 people viewed this question
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
