Question about Directed Electronics 479V Remote Gen 2 Responder
My 479V remote keeps beeping and the RX symbol pops up. By what I've read it means my car is paging me about a possible door ajar etc. I have checked everything and not the problem. It started out beeping a couple times a day but is now going off non stop and I have had to remove it. Is there a way to silence the beeper or find out why it is going off?? It came with the car and I have no manual. I'd really like to de-activate it so I can start using it again! Thanks...
  • deborah1735 Nov 09, 2010
    I did as you suggested by changing battery and cleaning the contacts. The RX still flashing but no more beeps! Hopefully the issue resolved. Thanks! Deb
  • 3,083 Answers
It does sound like your car is paging you. I ran across a 479V manual, and perhaps it will help:
http://www.directedstore.com/manuals/479V.pdf
Here is the installation manual for a 791VX, which works with the 479V, as does the 591, 690, and 790. Not that this in the installation guide, and there are many options when the device is installed. Hopefully, there will be a method of resetting the unit. Here's the manual:
http://www.scribd.com/doc/21662681/791VX-Installation-Manual
Bad grounds can cause havok with a system, as can bad wiring or sensors/'switches. There are alarm installation shops that could probably help you, but it could be expensive since they have to spend the time figuring out the installation wiring, etc.
Try going over some things in the manuals first, and lastly, make sure you have a good battery in the remote, and clean it's contacts- they can become slightly oxidized over time.
Good luck, and hope this helps.
Posted on Nov 09, 2010
2009 Jeep Wrangler Unlimited..remote start only honks and flashes lights once and does not start! How do I reprogram this to work?
If the door is slightly ajar it will beep once and not start.
It is not likely a program problem. It is likely a door ajar or tailgate open etc.
the car first locks prior to starting. If the car cannot secure the doors etc it will only beep and flash once.
Check the lock the car function and confirm it is operating.
Hope this helps? 2012 Jeep Wrangler Factory Remote Start
Nov 18, 2016 | 2009 Jeep Wrangler
Door ajar alarm keep beeping every 5 minutes and door is shut
was the replaced control panel a used unit
are the door hinges and seals ok
still maybe a faulty door sensor
Jun 17, 2016 | Refrigerators
Auto start shuts off within 10 seconds?
you have 2 choices
get car serviced,
or
read below. (pick one?)
sure, this is easy, (system logic not)
but you forgot to say , car starts with key, and runs perfect.
right. for get remove start toy.
certified , = warranted, or some bs.?
runs perfect means zero if the CEL glows running,
does car run perfectly you in seat starting with key and driving?
my guess you mean car stalls, 10second (ONLY ) remote started.
sure.
"engine light" means not running right, on all cars 1988 to now.
the XBM remote start will never work , with any errors from
ECU
PCM
BCM
or TCM
ever.
or if it sees doors ajar or alarms of any kind
by logic and federal laws.
scan it 1st and correct all DTC errors first.
that is what to do. if you are savvy and have a scan tool.
$10 to $100 tool, sold in all autostores usa.
think for 1 second how dangerous this FEATURE, can be.
hummmmmmm (a driverless moving car...)
why not read the FSM book on the 2013?
it covers most the logic, there.
quoted, so you can learn "complexity extreme"
verbatim
the following table below is a list of possible causes for the inoperative Remote Start System. If any of the following conditions exist, the Remote Start System will not work. Use this information as a guide to the diagnosis of the Remote Start System. ABORT BATTERY VOLTAGE HIGH BATTERY VOLTAGE LOW BRAKE PRESSED COOLANT TEMPERATURE HIGH CRANK NO START DRIVER DOOR AJAR PASSENGER DOOR AJAR LEFT REAR DOOR AJAR RIGHT REAR DOOR AJAR TRUNK/LIFTGATE AJAR HOOD AJAR NO HOOD SWITCH (INOPERATIVE) FUEL LEVEL LOW EXCESSIVE GLOW PLUG TIME (DIESEL ONLY) FAILED COUNTER REACHED (START) HAZARD LAMPS (SWITCH PRESSED) IGNITION IN RUN/START IGNITION NOT IN LOCK IGNITION SNA (SIGNAL NOT AVAILABLE FROM OTHER MODULE) INVALID KEY KEY IN IGNITION LOW RPM SHUTDOWN MIL ON NO AUTOMATIC TRANSMISSION NORMAL TIME OUT CUSTOMER ACCESS NORMAL TIME OUT RUN MODE (15 MINUTES) NOT CONFIGURED NOT ENABLED NOT IN PARK OR NEUTRAL NOT PROGRAMMED OIL PRESSURE LOW PANIC MODE (ACTIVATED) POWER LOSS RKE OFF MESSAGE RPM TOO HIGH (EXCEEDS 2500) START COUNTER REACHED VEHICLE SPEED HIGH VTA ALARMING If all of the previous items checked OK, and the remote starting system will not operate, refer to the REMOTE START POOR PERFORMANCE diagnostic procedure.
good luck running the engine in your garaged
and everyone eating carbon monoxide in the home.
good luck with that....."the silent killler"
Feb 19, 2016 | 2013 Jeep Grand Cherokee
Viper 479V Viper Responder Remote how to program
open the door, turn the key on, press valet switch one time and press it again and hold it until alarm beeps if it dosent beep it means that alarm hasn't read the door open if it beeps press lock on the remote and it should beep again and its will be set. (if the alarm dosent beep you have to put the door trigger wire (green) to ground and repeat steps from beggining
Apr 02, 2014 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
2005 jeep wrangler when i turn lights on beeping starts
did you RTM read the operators guide yet,
it tells you why all beeps beep and what lamps flash, (warning) and why. did you?
you turn on, the head lights, (what about 1st click , parking lights"?)
and does the dash cluster, show warnings of any kind?
if a door is ajar the system will think, you are exiting veh. with lights on and tell you, buy beeping ,etc.
but on my jeep it says on the dash DOOR, or on EVICs, (not yours)
the newer car even tells what door IS AJAR.
mine on shows , "DOOR"
the operator guide will say, check all doors for ajar, and get warning clear before driving....etc.
if you lost the guide here it is for free
http://justgivemethedamnmanual.com/jeep/jeep-wrangler-owners-manuals/
click the 05 link
ignore beeps, there are just too many .. i look at the cluster and learn to read it..
my newer jeep 08 can produce 1000s of errors,,,,, possible.
in fact the intent it to beep to tell the driver to look at the cluster
for in depth, causes.
see chapter starting on page 136'
once sound it makes is Check gauges chime. so check them.
and headlamps left on
and door ajar.
page 63
NOTE: If the driver's door is left open, and the headlights
or parking lights are left on, the "High Beam
Indicator Light" will flash and a chime will sound.
Lights-On Reminder
If the headlights or parking lights are on after the ignition
is turned off, a chime will sound when the driver's door
its a crude system, and evolved to complex in 2007.
"DOOR" or RF-door , on mine.
or
NOTE: A tone will chime if the turn signals are left on
for more than 1 mile (2 km).
search manual for
"chime will sound"
Mar 21, 2014 | 2005 Jeep Wrangler
A read out of stop engine comes on on my odometer reading
This a warning that you may have low oil pressure or an overheating condition. Are any of the gauges in the instrument cluster reading out of ordinary position? Is the Check Engine light on?
Apr 13, 2013 | 2003 Chevrolet TrailBlazer
My viper alarm rpn 479v p x is not working. When i press the unlock or lock button it doesnt work it just beeps. The remote is also flashing rx. Whats wrong?
I got the Problem that my pager-function doen't work. I try it like the Manual saying (*-Button) but the two ways that gives doesn't work.
- Start the Programmmode while Pressing "P" on the Backside.
- Press the "STAR-Button or Panic-Button (Orange Key) on the Sender"
it Beeps 2 Times. (i try it again with 1 beep as reponse again)
i Wait 5 Seconds
it beeps 2 long times
i try the Responder, Activate the System, disarm the System. But the Pager don't change the state or receive any Signal.
The Transmitter is working perfect! No Problems to control the Viper 690XV.
What i do wrong?
Is there any hidden Feature or needable Programming in the Viper 690XV-Brain?
Thanks alot for any helpful Answer :)
May 02, 2012 | Directed Electronics 479V Remote Gen 2...
Viper remote car starter 479V
press and hold the ( P ) button until one long beep is heard, you now have 5sec to push the lock button to turn on or off the vibrate, wait another 5sec and it will automaticaly exit programming
Jan 27, 2010 | Directed Electronics 479V Remote Gen 2...
What do i need to do to reconect a viper 479v?
this is the instructions to programing your remote to your truck go this page..
Sep 17, 2009 | Directed Electronics 479V Remote Gen 2...
Back lighting for my viper 479v remote
you have to go in to the proramming mode of the remote to change this feature. you can access this by holding all 4 buttons on the remote at the same time. (or if you have the P button on the back you can hold it down by itself) you will hear 2 long beeps confirming the programming mode. at this time, you can change the settings by pressing 1 of the 4 buttons., each button will change a different function.
in no order------
1. Beep/vibrate or both
2. page or not to page
3.back light
4. hood, truck, or both
the remote will give 2 long beeps when it exits the programming
Aug 20, 2009 | Directed Electronics 479V Remote Gen 2...
Directed Electronics 479V Remote  Gen 2 Responder Logo
1,110 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
Tre Elkins
Shehu Pro
Shehu Pro
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
