Question about Tomtom GO 520/720 Remote Control
When I point my remote control at the sat nav display and press a button, the blue signal light at the top of the remote control flashes on and off and won't connect to the system, rendering it useless. I've tried changing the batteries but it's made no difference. Do I need to reset the system?
2 Suggested Answers
gopakumarg43
  • 75767 Answers
SOURCE: The remote control on the
Hello
Check your TomTom's remote control for its infrared emission. You can check it with a cellphone camera. The blue ligh flashes indicates that the circuit inside it is working, but it does not give you about the infrared emission form it. It is only an indication for its battery power and oscillation takes place inside it. The infrared LED in front of the remote control emits infrared radiation with different frequencies according to each function press. human eye cannot detect these rays, but an electronic camera can. Set your cellphone to camera option, place the remotes' front side towards its lens, at about one feet away or so, press each button on the remote control. if there is any infrared rays comes out of it, the phone camera will sense it and you can see its image at its screen. If there is no image at all, make sure that the remote control is not emitting infrared rays; and is faulty. If there is image on the camera screen and still your TomTom main unit does not respond to it, the infrared sensor inside it is faulty. You can't make it right. The unit has to be disassembled to repalce it.
If this is the condition, the set is new, as you say; must have guarantee. Replace the unit as far as possible I advice. Never make it open, as opening the unit void the guarantee. OK.
Posted on Jun 29, 2011
I changed the batterys in the reciever remote as the system sid batterys where low now I cannot get the remote to respond
Ensure that the batteries are inserted the right way, if they are not the remote will not get power.
Make sure to hit the STB button and then press the POWER button.
Hope this helps!
Mar 07, 2011 | Bell Televison & Video
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
Need remote control code for dish network along with how to instructions. I can't locate my manual for my Zenith
Try this...1) turn on your tv set manually.2) on you dish remote..press and hold the "TV" mode button next to the "SAT" button.when all of the other mode buttons light up, let the "TV" button go...it should be flashing.3) Press the blank power button(The top red button in the top center of the remote).4) press the UP or DOWN button at the rate of about 1 per second until the tv turns off.4) When the tv turns off...press the # key on the bottom right of the remote...this stores the code and you should be ready to go...please try this first..It should work.If the scan doesn't work...The only code for Orion is "694".I hope this was helpful....
Jun 15, 2010 | Zenith C32V37 32" TV
Looking for dish network codes for the Philips SRU3003 remote...
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the Mode button( sat,tv,dvd,aux) on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Jan 01, 2010 | Philips SRU3003 Remote Control
TV or control doesn't work need help know
ok my tv is doing the same thing and i need help if you found a solution please email me at pieces41096@aol.com
Jul 06, 2009 | DISH Network 322 DTV Receiver
Tv2 light does not come on
hi hammonhph! I will be more than glad to assist you in this concern. Lets program the remote for tv2, lets make sure that the battery's are brand new, please go to the front panel of the receiver, make sure that u have the remote2 with, turn on the the tv1, you got picture, on the front panel of the receiver, you got 1 green and the blue light is off.. push the power button on the front panel of the receiver once to turn off the green light, once its off the tv will show a black, blue or snowy screen, push the up button on the fron panel of the receiver until it shows the system information screen, look for the primary and secondary remote address, primary and secondary remote address should show a number on the white box ex.. 1 and 1 on the green box, secondary is ex 2 on the white box and 2 on the blue box, how to reporgram the remote to the receiver.. press and hold the sat button and wait until all lights lit up, once it all lit up, release it and press any number from (1 to 15) but for this ex is press 9, then press the pound button (#) that is under number 9, once you press the pound button the sat button will flash 3 times and then press the record button once, record button is under the cancel button or view tv button, once you are done check the secondary remote address, it should be 9 on the white box and 2 on the blue box, save the settings by using the remote 1, selct done on the screen and it will go back again to black, blue or snowy screen, press the sat button once on the remote 2 and the big red power button, the blue light should turn on, just in case the blue light dont turn on, press the power button on the front panel of the receiver for 10sec to reset the receiver, it will acquire the sat signal and go to a progress, and it will download the programming guide, check if blue light is not on, press the big red power button on the remote2 to turn on the blue light and it should work. if just incase the blue light dont turn on, the remote is bad and you need to call 1-800-333-3474 for the replacement of the remote..please feel free to get in touch if you have any query..
Contro;
We will need to set the remote address again. Using the front panel buttons on the receiver press the menu button twice. This will put you at the system info screen. You will see the remote addresses for tv 1 and 2. They will probably both be set to 1 if the receiver reset. Press and hold the SAT button on the TV1 remote until all lights across the top light up and release. Now key in a two digit number between 1 and 16 (for 1-9 precede that numeric with a zero) now press the pound key at the bottom right of the remote numeric keypad. The SAT button will flash three times and press the record button until the remote address on the screen displays the one you entered. The receiver should now be able to be controlled by the remote. If you have further issues let me know. Thanks for using Fix Ya.
Apr 04, 2009 | DISH Network IR Remote Control
I would like to know how to pro. 103602 ir remote
In order to program the remote to the TV turn the TV on and put the remote in SAT mode by pressing the SAT button in the upper left hand corner of the remote.Now press and hold the TV button Next to the SAT button until all buttons light up across the top of the remote and release. Now press the small red TV button and release. This should result in the top clear TV being lit constantly. Now press the arrow up key slowly until the TV turns off. Once it does press the arrow down key once and then the arrow up key. The TV should turn on. Now press the pound symbol at the botttom right of the remote. The TV button on the top should flash three times. Now you can use the remote to control the TV. If you are unable to get the TV to turn off then the TV is not compatible with the remote. Thanks for using Fix Ya.
Mar 15, 2009 | DISH Network IR Remote Control
What button is the address button
3.1 DishnetWork remote problem
I suspect that the remote address got changed somehow. Pree and hold the sat button on the top left hand side of the remote until all buttons light up across the top and release. Now key in 0-1 on the numeric keypad and press the pound sign. The SAT button will flash three times. After it the SAT button is done flashing press the small red dot record button. Now try to operate the remote. You should be able to control the system now. Thanks for using Fix Ya.
Mar 13, 2009 | DISH Network IR Remote Control
Tomtom GO 520/720 Remote Control Logo
93 people viewed this question
Top Tomtom Televison & Video Experts
Marvin
Marvin
Are you a Tomtom Televison and Video Expert? Answer questions, earn points and help others
